bowtieuser Posted April 12, 2013 Share Posted April 12, 2013 I've got good pins and no more cable Link to comment Share on other sites More sharing options...
Jeep Meister Posted July 8, 2013 Share Posted July 8, 2013 Oh yeah been there done that. Except i screwed mine up trying to adjust metal rods so it would open easier and then would not open at all. Had to get the guy at the 4x4 shop down the street to fix it for me.Thank god he did not charge me for it. Thanks for the topic. The hood pins sounds like a good idea though. So I think ill do that at some point in time. in the mean time I'm gonna lube my hood latches and hood release with some good old vaseline i have a big jar of it so... :cheers: Link to comment Share on other sites More sharing options...
88mjblue Posted October 5, 2014 Share Posted October 5, 2014 Been using Dri-Slide on my motorcycle cables for years and tried it on the hood cable. It has a needle applicator that you can insert into the cable sheath and squirt it in until it flows out the other end. Can pull the hood release cable with two fingers now. Good stuff. Would you recommend this product for lubricating the mechanical speedometer cable? Mine's a bit wiggly, and I was hopping to kill two birds with one stone with this lube. Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 5, 2014 Share Posted October 5, 2014 Yes, it's a dry graphite-based lube, doesn't gum up, and works great for mechanical speedo cables. Used it for years on all my bike speedo cables. Link to comment Share on other sites More sharing options...
Motorcharge Posted October 15, 2014 Share Posted October 15, 2014 Found this thread looking for something else and didn't see the other way to do it in here though I may have missed it. If you lay under the front with your legs facing out the front and look up directly between the motor and radiator and in between the electric and mechanical fans you can actually see the rod that connects both latches. Pull yourself up by the crossmember with one hand and grab the rod with the other and pull straight down and the hood will release. Takes a little effort to pop it out the plastic clips but it works and it's easier than taking a headlight out. Link to comment Share on other sites More sharing options...
ComancheChic Posted December 10, 2014 Share Posted December 10, 2014 My release wouldn't budge at the handle. My buddy was able to get the p/s to release. I pulled the grill off & saw the skinny rod/linkage that opens latches. I tried pulling down on the d/s one w/one finger & it broke! Used the channel locks to grab the d/s linkage & open latch. The linkage had come out of the plastic holders & gotten slightly bent, possibly when I was cleaning the inside of the hood last week. Repaired d/s rod w/ 5 min epoxy & Gorilla tape. So far so good... Link to comment Share on other sites More sharing options...
Paul Bruchal Posted December 12, 2014 Share Posted December 12, 2014 Mine broke and I ordered hood pins asap.... year later I just found this thread lol Link to comment Share on other sites More sharing options...
JeepsOLot Posted January 5, 2015 Share Posted January 5, 2015 This is what's on my MJ: Image Not Found Two hood pins. I have the handle, but, all of the other cables have been pulled out. Jerry Link to comment Share on other sites More sharing options...
FrankTheDog Posted January 5, 2015 Share Posted January 5, 2015 Ex son in law traded a kindle for a 98 XJ. It's rust free and mostly straight except where the PO hammered down the fenders and pried open the hood when the hood release handle broke. So now he's looking for clean fenders and a hood for it. Link to comment Share on other sites More sharing options...
skerriltj Posted April 16, 2015 Share Posted April 16, 2015 Does anyone know of any good write ups on the hood pins? This post will be helpful. Been fighting with my hood for the last little while! Link to comment Share on other sites More sharing options...
Comanche 87 Posted July 20, 2015 Share Posted July 20, 2015 The hood release latches/ spring mechanism on the inside of engine compartment of my 87 'Manche apparently are missing. I have to reach through grill to pull the center catch back to open hood. Is there a part I can order to replace this and how much are they usually? Thinking about installing hood pins as well they look awesome to me. Link to comment Share on other sites More sharing options...
Pete M Posted July 20, 2015 Author Share Posted July 20, 2015 no idea if they are still available new, but any 87-01 XJ at a junkyard will have the parts you need. :thumbsup: Link to comment Share on other sites More sharing options...
Comanche 87 Posted July 21, 2015 Share Posted July 21, 2015 I'll see if I can find some online. If not I'll resort to scrap yards. What exactly are the underside hood clips/latch things called so I don't sound like a retard trying to explain it over the phone lol Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 21, 2015 Share Posted July 21, 2015 Link to comment Share on other sites More sharing options...
Wildman Luke Posted November 8, 2015 Share Posted November 8, 2015 mine is stuck also. open. Link to comment Share on other sites More sharing options...
Dzimm Posted November 21, 2016 Share Posted November 21, 2016 I didn't see anyone mention this so I figured I'd let everyone know that there is an easier way than disassembling the front end if your release handle breaks off close to the lever. You can cut the rubber sleeving back on the cable and expose the cable. Hold the still sleeved part of the cable with one hand and pull the cable with pliers with the other and it will pop the hood. This will only work if it breaks within a few inches of the release lever. Did this on my friends XJ and he left it like that cause he was too cheap to buy the cable. Link to comment Share on other sites More sharing options...
gogmorgo Posted November 22, 2016 Share Posted November 22, 2016 Why is this pinned in For Sale? Has it always been here? Link to comment Share on other sites More sharing options...
Pete M Posted November 23, 2016 Author Share Posted November 23, 2016 good question... :dunno: moving it back. Link to comment Share on other sites More sharing options...
Minuit Posted February 26, 2017 Share Posted February 26, 2017 White lithium grease (or similar) every second oil change. I can open my hood with one finger :D Link to comment Share on other sites More sharing options...
Zambeezy Posted February 26, 2017 Share Posted February 26, 2017 White lithium grease (or similar) every second oil change. I can open my hood with one finger :D Applying it on the rods under the hood? Link to comment Share on other sites More sharing options...
Minuit Posted February 26, 2017 Share Posted February 26, 2017 White lithium grease (or similar) every second oil change. I can open my hood with one finger :D Applying it on the rods under the hood? Yes - all of the moving parts under there. Also keep in mind that I don't drive my trucks much, so two oil changes ends up being about every 8 months or so if it seems like an awful lot of hood hinge greasing. Link to comment Share on other sites More sharing options...
gogmorgo Posted February 26, 2017 Share Posted February 26, 2017 I also try to shoot some down the cable as well, but that fancy bike cable lube would probably work better. Link to comment Share on other sites More sharing options...
gogmorgo Posted December 27, 2017 Share Posted December 27, 2017 Well, this thread to the rescue. Its -30°F today so of course this is the day I choose the resurrect the XJ sitting in my parents' driveway that hasn't been touched since March. Day started off great, my parents daily's battery is on its way out and the immobilizer the insurance company had installed doesn't like the cold... So that was interesting. Fortunateky the remote starter bypasses that garbage so it would start after some time on the charger but it took a half hour before the junk was warm enough to behave. Then finally I can get it around to boost the XJ but I'm guessing the XJ's hood latch is frozen, cause as hard as I can pull on the handle, she won't budge. Inside for a cup of coffee, then it'll be back out there for some alternative strategies. Link to comment Share on other sites More sharing options...
Skorpyo Posted December 27, 2017 Share Posted December 27, 2017 7 minutes ago, gogmorgo said: Its -30°F today so of course this is the day I choose the resurrect the XJ sitting in my parents' driveway... I'm not gonna lie, it's 60* warmer here and I'm miserably cold... I dunno how you cold weather folks do it, but kudos to you.... Is it the Tim Hortons Coffee? Good luck with the XJ! Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 27, 2017 Share Posted December 27, 2017 Damn. Mercury freezes at -37.89 °F and you're not far from that. You'll need an alcohol thermometer if it gets any colder. Brrrrrr- Link to comment Share on other sites More sharing options...
