TheMaddTitan13 Posted July 29, 2025 Share Posted July 29, 2025 Rate my engine bay! Curious to see it compared to others! (The oil on my valve cover was from before replacing vacuum lines & my battery plate rusted out 😞 ) Link to comment Share on other sites More sharing options...
ThatJeepGuy Posted July 29, 2025 Share Posted July 29, 2025 Loom your custom wiring additions and get a factory shroud for your mechanical fan I surprised myself by finding a picture of everyone one of my vehicles engine bay besides 1... Link to comment Share on other sites More sharing options...
TheMaddTitan13 Posted July 29, 2025 Author Share Posted July 29, 2025 44 minutes ago, ThatJeepGuy said: Loom your custom wiring additions and get a factory shroud for your mechanical fan I surprised myself by finding a picture of everyone one of my vehicles engine bay besides 1... Would you say the heat pad on the hood is worth it? It gets pretty warm on the trail. & I am definitely going to find a shroud. You got some good looking engines! The ones with engines, do they run? Link to comment Share on other sites More sharing options...
fiatslug87 Posted July 29, 2025 Share Posted July 29, 2025 If you want to see some spectacular engine bays check out Gjeep’s and HOrnbrod’s. Link to comment Share on other sites More sharing options...
ThatJeepGuy Posted July 30, 2025 Share Posted July 30, 2025 1 hour ago, TheMaddTitan13 said: Would you say the heat pad on the hood is worth it? It gets pretty warm on the trail. & I am definitely going to find a shroud. You got some good looking engines! The ones with engines, do they run? On that hood meh, idk its vented pretty well and the pad is like a kilmat soo its stuck there and I'm not ambitious enough to remove it. I long swore against the mech shroud because most of mine would break and then fall into the fan and lock it up. However after installing brand new shrouds vs salvaging 30yr old ones, I wouldn't run one without it! 1st picture is not a running and driving vehicle - yet. Motor does run but there's no exhaust, cooling system or established fuel system. Otherwise yes the rest with engines are running and driving vehicles Link to comment Share on other sites More sharing options...
89 MJ Posted July 30, 2025 Share Posted July 30, 2025 Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 30, 2025 Share Posted July 30, 2025 11 minutes ago, 89 MJ said: Way to sneak the Eagle in. Link to comment Share on other sites More sharing options...
89 MJ Posted July 30, 2025 Share Posted July 30, 2025 20 minutes ago, eaglescout526 said: Way to sneak the Eagle in. In my defense, there were some SJ ones before that! Lol Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted July 30, 2025 Share Posted July 30, 2025 Link to comment Share on other sites More sharing options...
ghetdjc320 Posted July 30, 2025 Share Posted July 30, 2025 This is the way Link to comment Share on other sites More sharing options...
TheMaddTitan13 Posted July 30, 2025 Author Share Posted July 30, 2025 11 hours ago, fiatslug87 said: If you want to see some spectacular engine bays check out Gjeep’s and HOrnbrod’s. Ill have to look for it! I'm love a nice clean bay! & i may or may not be secretly looking for ideas to clean mine up lol. Link to comment Share on other sites More sharing options...
TheMaddTitan13 Posted July 30, 2025 Author Share Posted July 30, 2025 10 hours ago, 89 MJ said: What kind of thermo housing is that?! & that blue 💙 😍 gorgeous!!! My first xj was blue! You can't tell in the picture, but ill dig one out later! Link to comment Share on other sites More sharing options...
TheMaddTitan13 Posted July 30, 2025 Author Share Posted July 30, 2025 9 hours ago, Strokermjcomanche said: This is one of the cleanest bays I've ever seen in any car, definitely the cleanest jeep!!! It looks brand new! How many miles? Link to comment Share on other sites More sharing options...
AreWeThereYet Posted July 30, 2025 Share Posted July 30, 2025 This is definitely nice for reference as I’m sorting through mine. I don’t know much about the current engine other than it’s not original, most likely came out an 88, and it runs smooth. Link to comment Share on other sites More sharing options...
89 MJ Posted July 30, 2025 Share Posted July 30, 2025 1 hour ago, TheMaddTitan13 said: What kind of thermo housing is that?! & that blue 💙 😍 gorgeous!!! My first xj was blue! You can't tell in the picture, but ill dig one out later! The top picture is a stock housing from a 258 powered Jeep. The second pic is a stock one for a 96 XJ. I bet that XJ was pretty fun! Link to comment Share on other sites More sharing options...
Pete M Posted July 30, 2025 Share Posted July 30, 2025 my torn apart 86 Link to comment Share on other sites More sharing options...
Pete M Posted July 30, 2025 Share Posted July 30, 2025 and my completely stock 88. this thing is a fantastic resource for answering questions (both mine and other peoples') Link to comment Share on other sites More sharing options...
ThatJeepGuy Posted July 31, 2025 Share Posted July 31, 2025 18 hours ago, ghetdjc320 said: This is the way You sir! Nicely done!! Making my LS engine bay all kinds of sweaty Link to comment Share on other sites More sharing options...
pizzaman09 Posted August 1, 2025 Share Posted August 1, 2025 Lots of stuff all over the place but all factory setup. I didn't quite install the cruise control actuator the way it was supposed to be. Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 1, 2025 Share Posted August 1, 2025 2 hours ago, pizzaman09 said: didn't quite install the cruise control actuator the way it was supposed to be. That looks like one of the 3 correct spots for it to be mounted and in the correct spot for that style of bracket. Link to comment Share on other sites More sharing options...
pizzaman09 Posted August 1, 2025 Share Posted August 1, 2025 13 minutes ago, eaglescout526 said: That looks like one of the 3 correct spots for it to be mounted and in the correct spot for that style of bracket. After reviewing a few other installs, I don't think the bracket is setup the way the factory would have, that said, it fits well and doesn't interfere with anything. Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 1, 2025 Share Posted August 1, 2025 17 minutes ago, pizzaman09 said: that said, it fits well and doesn't interfere with anything. That’s the important part. Link to comment Share on other sites More sharing options...
Gojira94 Posted August 1, 2025 Share Posted August 1, 2025 In honor of Cruiser54's posts about running an HO on Renix, here's an example. Cruise servo has been positioned to use the HO throttle bracket setup. Air cleaner and fuel rail are aftermarket, obviously, neither Renix nor HO... Link to comment Share on other sites More sharing options...
