So I am collecting parts again.....
The oil leak from the head gasket is getting the better of me.:brickwall:  I started with the idea I would just change the head gasket and be done.  Well I have now decided I might as well change out the seeping radiator.  If I'm into it that far I might as well change the hoses and water pump too.  And while the system is drained maybe a heater core.  I do need to put a new heater box in to replace the cracked drafty one, guess a new blower motor is in order.  Oh and since I'll have the ac open changing the box I might as well change on all the seals in the system and replace the broken line.  I am missing a couple of intake bolts and have an exhaust leak that I might as well take care of with a much needed new exhaust..... :holdwrench::holdwrench::holdwrench::holdwrench::holdwrench::holdwrench:
So here I sit.  Collecting parts.  Any suggestions on where to find my needed intake bolts, more especially the washers.  And I need to find the ac line from the bottom of the drier to the condenser.  I am assuming (yes i know) that those parts are going to be sourced used but haven't really searched for them.
Sounds like we are in the same boat. Jegs has everything you need. Rock auto has most if it. Amazon does too but good luck finding it. The parts stores have most of it as well but require ordering. I've got parts from all.
89 Comanche
Eliminator
2wd
4.0L
5 speed PukeGoat
Factory Original
JEGS and some of the on-line speed shops will have those conical manifold washers.
I would recommend using studs with nuts in place of the bolts in as many locations as possible.   (Particularly on the bottom row of bolts.)
8 hours ago, eaglescout526 said:
Don’t you just love that? Sometimes we’re more paying for the Mopar/Chrysler name than the part.
Factory will always be factory and fire a few bucks more and the convenience of knowing it right it's worth it.
I always buy the dorman bolt kit when I do manifold stuff. It’s like $8 on Amazon I think. Dorman 03408B. I have tons of those semi circle washers from various 4.0s I’ve disassembled and would be willing to part with some if anyone needs some. They’re used, but still solid.
On 12/18/2020 at 4:33 PM, watchamakalit said:
We call it "shop glitter"
Bolts are easy to source but what about the fancy washers.
Search for "bellville washers" aka conical washers.  They are kind of important in that application.  They help spread the clamping force of the bolt head across the manifold.  I've used a small stack of regular flat washers in a pinch before when a bellville went missing.  They worked, but weren't really right.
