EdJarHead Posted August 27, 2020 Share Posted August 27, 2020 Really - my horn just stopped working. I changed the relay with a new one, and that didn't fix it. Before I start digging around to find all of the ground wires, thought I'd ask if there are more common ones to check first? Link to comment Share on other sites More sharing options...
89 MJ Posted August 27, 2020 Share Posted August 27, 2020 Does your horn itself work? Mine has failed before. Link to comment Share on other sites More sharing options...
EdJarHead Posted August 27, 2020 Author Share Posted August 27, 2020 Did not think to test that first...(duh)... probably should have before I bought a new relay! Thanks! Link to comment Share on other sites More sharing options...
Pete M Posted August 27, 2020 Share Posted August 27, 2020 on mine the wire somehow worked its way free of the horn. always test and diagnose before firing the parts cannon. Link to comment Share on other sites More sharing options...
89 MJ Posted August 27, 2020 Share Posted August 27, 2020 3 hours ago, Pete M said: always test and diagnose before firing the parts cannon. I assume you don’t want to see my most recent Rock Auto bill then (over $300 just for my MJ) Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 27, 2020 Share Posted August 27, 2020 Whatever you do, do not add blinker fluid (sometimes confused with beeper fluid) or your horn will cycle ON/OFF. Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 27, 2020 Share Posted August 27, 2020 4 minutes ago, 89 MJ said: I assume you don’t want to see my most recent Rock Auto bill then (over $300 just for my MJ) Lol, you don't want to know how much I spend on NOS stuff then. Link to comment Share on other sites More sharing options...
Pete M Posted August 27, 2020 Share Posted August 27, 2020 47 minutes ago, fiatslug87 said: Whatever you do, do not add blinker fluid (sometimes confused with beeper fluid) or your horn will cycle ON/OFF. Link to comment Share on other sites More sharing options...
Minuit Posted August 27, 2020 Share Posted August 27, 2020 Do not use blinker fluid in the horn. The correct fluid should be right next to the blinker fluid on the shelf. Look for a bottle of beeps - that'll restore proper horn function. Do not overfill the horn with beeps. With the horn cold, the reservoir should be approximately half full of beeps. Overfilling can cause damage and premature failure. Link to comment Share on other sites More sharing options...
Torq_Shep Posted August 28, 2020 Share Posted August 28, 2020 On 8/27/2020 at 1:28 PM, 89 MJ said: I assume you don’t want to see my most recent Rock Auto bill then (over $300 just for my MJ) That's it? My cart on RA is at like $800 of stuff I should purchase for my daily, my partners saturn, and the MJ... Way too cheap to buy it all though. Link to comment Share on other sites More sharing options...
Minuit Posted August 28, 2020 Share Posted August 28, 2020 I separate all of my projects into "groups" that are more or less self-contained and can be done individually. I keep a parts list for each. Not a single one of those parts lists is under $300. Link to comment Share on other sites More sharing options...
89 MJ Posted August 28, 2020 Share Posted August 28, 2020 2 hours ago, Torq_Shep said: That's it? My cart on RA is at like $800 of stuff I should purchase for my daily, my partners saturn, and the MJ... Way too cheap to buy it all though. Wow! I’m cheap too Link to comment Share on other sites More sharing options...
zomeizter Posted August 29, 2020 Share Posted August 29, 2020 OP, if and when you do some more troubleshooting, remember to turn the ignition switch on, this fooled me for a good 30 mikes. Link to comment Share on other sites More sharing options...
MancheKid86 Posted August 29, 2020 Share Posted August 29, 2020 you can easily bench test your horn, run a + and - from the battery to the horn and that will rule out if the horn functions. a. horn beeps. - run multi meter on power wire and see if you detect a voltage whilst pressing beeper -if power, replace ground. -if no power check all fuses and trace wire back to see if there is any chafing/breaks/corrosion of wire b. horn no beep - replace horn let us know what you find! Link to comment Share on other sites More sharing options...
EdJarHead Posted August 30, 2020 Author Share Posted August 30, 2020 Thanks... that's very helpful... turns out it is a bad horn. Link to comment Share on other sites More sharing options...
1989commanche Posted September 2, 2020 Share Posted September 2, 2020 My horn keeps going out. I have replaced it three times so far. It just quits honking. I need to find that bottle of honks they were talking about. It get to sound like a sick duck then fails completely. Link to comment Share on other sites More sharing options...
amsuco Posted September 3, 2020 Share Posted September 3, 2020 On September 1, 2020 at 10:49 PM, 1989commanche said: It get to sound like a sick dick then fails completely. That started my day with a smile. I'm pretty sure "duck" is the word you had in mind. My sense of humor may be a bit juvenile, but Beavis and Butthead would be proud of me! Link to comment Share on other sites More sharing options...
1989commanche Posted September 5, 2020 Share Posted September 5, 2020 Fixed it Link to comment Share on other sites More sharing options...
fiatslug87 Posted September 5, 2020 Share Posted September 5, 2020 9 hours ago, 1989commanche said: Fixed it and...? Link to comment Share on other sites More sharing options...
jdog Posted September 5, 2020 Share Posted September 5, 2020 Make sure you have the covering and or there's not a way that water is getting inside of the horn Link to comment Share on other sites More sharing options...
