89 MJ Posted August 22, 2020 Posted August 22, 2020 I am starting to get a parts list for things that I will be ordering when I do my engine swap in my Comanche. Right now, my Comanche is terribly slow (12+ seconds to 60). I am not looking for V8 power levels, but I am looking for some little parts that can help boost my power a little bit. One thing I am considering is some performance fuel injectors? What ones do you all recommend? Are there any other little power adders that you recommend (not talking about forced induction, V8s, or strokers)
Pete M Posted August 22, 2020 Posted August 22, 2020 gears but for the engine: bored TB, 4 hole injectors, and maybe a mild cam
89 MJ Posted August 22, 2020 Author Posted August 22, 2020 52 minutes ago, Pete M said: gears Already at 4.10s
89 MJ Posted August 22, 2020 Author Posted August 22, 2020 53 minutes ago, Pete M said: but for the engine: bored TB, 4 hole injectors, and maybe a mild cam Do you have any brand recommendations?
89 MJ Posted August 22, 2020 Author Posted August 22, 2020 58 minutes ago, jdog said: Bored throttle body Thanks. Any particular brand?
Pete M Posted August 22, 2020 Posted August 22, 2020 far as I know there is no brand for the renix. only custom bored ones (and the guy that was doing it here on CC no longer does). there are a lot of reasons why you should fully convert to the HO stuff. availability of upgrades is big one.
jdog Posted August 22, 2020 Posted August 22, 2020 But some Googlefu shows this guy's still does it http://strokedjeep.com/renix t-body.html
JMO413 Posted August 22, 2020 Posted August 22, 2020 4 Hole injectors and a bored throttle body. I have both in mine and have never timed to 60 MPH but I know it s not that long. Mine will hit close to 60 coming off an on ramp.
fiatslug87 Posted August 22, 2020 Posted August 22, 2020 As an option you can try contacting MeanLemons, he was selling his boreing jig, someone may have bought it.
89 MJ Posted August 22, 2020 Author Posted August 22, 2020 2 hours ago, Pete M said: far as I know there is no brand for the renix. only custom bored ones (and the guy that was doing it here on CC no longer does). there are a lot of reasons why you should fully convert to the HO stuff. availability of upgrades is big one. 54 minutes ago, JMO413 said: 4 Hole injectors and a bored throttle body. I have both in mine and have never timed to 60 MPH but I know it s not that long. Mine will hit close to 60 coming off an on ramp. 1 hour ago, jdog said: But some Googlefu shows this guy's still does it http://strokedjeep.com/renix t-body.html Thanks. 48 minutes ago, fiatslug87 said: As an option you can try contacting MeanLemons, he was selling his boreing jig, someone may have bought it. Sounds good!
rokinn Posted August 22, 2020 Posted August 22, 2020 Go to MeanLemons last post the Vendor section for his throttle bodies. He sold it to Skankfoot or something like that. Info is there.
omega_rugal Posted August 22, 2020 Posted August 22, 2020 some say removing the crush in the exhaust pipe helps a little which makes me question: is it worth it to replace the OEM 6-1 exhaust to with a custom 3+3 -> 2 -> 1 exhaust?
JMO413 Posted August 22, 2020 Posted August 22, 2020 26 minutes ago, omega_rugal said: some say removing the crush in the exhaust pipe helps a little which makes me question: is it worth it to replace the OEM 6-1 exhaust to with a custom 3+3 -> 2 -> 1 exhaust? I guess technically I did this also. I replaced my exhaust manifold with a HO version and used the HO down pipe that doesn't have the crushed spot.
omega_rugal Posted August 22, 2020 Posted August 22, 2020 1 hour ago, JMO413 said: I replaced my exhaust manifold with a HO version and used the HO down pipe that doesn't have the crushed spot. any difference?
JMO413 Posted August 22, 2020 Posted August 22, 2020 9 minutes ago, omega_rugal said: any difference? I would like to say yes per the butt Dyno. But with a side note of it was just a part of fixing multiple issues. I also replaced the whole exhaust. Cheap stainless exhaust manifold, Walker down pipe, added a piece of flex pipe, Thrush muffler,& Walker tail pipe. The manifold was also replaced because it was cracked and one of the students was broke. With all that who really knows if the pipe made a difference?
omega_rugal Posted August 23, 2020 Posted August 23, 2020 16 hours ago, JMO413 said: I also replaced the whole exhaust. if you cahnged the lenght and/or size of the pipe you changed its properties too
Ωhm Posted August 23, 2020 Posted August 23, 2020 On 8/22/2020 at 9:13 AM, 89 MJ said: Right now, my Comanche is terribly slow (12+ seconds to 60). Do you have a RENIX Engine Monitor (REM) or some other way to look at ECU serial data? Make sure you're getting the most with what you already have (baseline).
Eagle Posted August 23, 2020 Posted August 23, 2020 On 8/22/2020 at 9:13 AM, 89 MJ said: I am starting to get a parts list for things that I will be ordering when I do my engine swap in my Comanche. Right now, my Comanche is terribly slow (12+ seconds to 60). I am not looking for V8 power levels, but I am looking for some little parts that can help boost my power a little bit. Thanks for making me feel my age. I'm old enough to remember the days when a zero to 60 time of 10 seconds flat was considered to be FAST! That was once sort of the automotive equivalent of a 4-minute mile.
89 MJ Posted August 23, 2020 Author Posted August 23, 2020 8 hours ago, Ωhm said: Do you have a RENIX Engine Monitor (REM) or some other way to look at ECU serial data? Make sure you're getting the most with what you already have (baseline). I do not. Where do I get one?
89 MJ Posted August 23, 2020 Author Posted August 23, 2020 7 hours ago, Eagle said: Thanks for making me feel my age. I'm old enough to remember the days when a zero to 60 time of 10 seconds flat was considered to be FAST! That was once sort of the automotive equivalent of a 4-minute mile. Geez. Sorry about that.
Ωhm Posted August 23, 2020 Posted August 23, 2020 5 minutes ago, 89 MJ said: I do not. Where do I get one? Renix Engine Monitor (REM)
ghetdjc320 Posted August 23, 2020 Posted August 23, 2020 I don’t know how far you want to go with bolt-ons but stand alone efi is really a good way to make sure your mods actually add anything. My 4.0 has an Edelbrock aluminum head, bored .060, shaved deck, mild cam, roller rockers, 99+ intake, JBA TJ down pipe, 24# injectors and many other bolt ons but my biggest “power adder” was my 4.56 gears and Detroit truetrac out back. Stand alone efi is my next plan after hydroboost brakes.
