early comanche owner Posted June 19, 2020 Posted June 19, 2020 I just purchased a 1990 comanche pioneer. 5k 4wd auto on the floor runs and drives good(drove it three hours home ac works and drove great down highway sensor or something for part time light that just came on very little rust and small dent. new tranny and tires and wheels. just looking for opinion need some tlc. bed stablizer for breaks sensor or something for part time light that just came on very little rust and small dent. new tranny and tires and wheels. just looking for opinion
Pete M Posted June 19, 2020 Posted June 19, 2020 the price matters not as long as you're happy with your new baby. She's a great looking truck!
MiNi Beast Posted June 20, 2020 Posted June 20, 2020 Better then a rusted out ranger. 👌 welcome to Comanche ownership.
early comanche owner Posted June 20, 2020 Author Posted June 20, 2020 lol... thanks yall. I have always said I would replace my first one. I got one brand new in 87 when graduated highschool.. but oops totally, so now 32 years later i have my second.
Ωhm Posted June 20, 2020 Posted June 20, 2020 Your missing the rod for the rear brakes porportioning valve. Its held up with a tyrap. Welcome to the CC forum. Add your VIN to the registry. Also, LOG-IN. Upper right hand of screen. Click on Username. Click on Account Settings. Find and click on Signature. Add vehicle information here (YR, ENG, TRANS, etc, etc) and save. This helps everyone. This information will be available every time you post.
early comanche owner Posted June 20, 2020 Author Posted June 20, 2020 mj junky, Yes i am i have started looking for ways to bypase that , breaks have been replaced but slow stopping was told that was the cause, thoughts?
Ωhm Posted June 20, 2020 Posted June 20, 2020 Under Browse/Forum there's a MJ TECH: DIY project section. Here's example: https://comancheclub.com/topic/45839-mj-height-sensing-brake-proportioning-valve-adjustment-procedure/
Eagle Posted June 20, 2020 Posted June 20, 2020 44 minutes ago, early comanche owner said: mj junky, Yes i am i have started looking for ways to bypase that , breaks have been replaced but slow stopping was told that was the cause, thoughts? No.
early comanche owner Posted June 20, 2020 Author Posted June 20, 2020 eagle, that wouldnt affect stopping>? when i brought it home pushed almost to the floor to get brakes engaged?
Pete M Posted June 20, 2020 Posted June 20, 2020 in the link in my signature you'll find the bleeding procedure for MJ brakes. it's different than other vehicles
Eagle Posted June 20, 2020 Posted June 20, 2020 1 hour ago, early comanche owner said: eagle, that wouldnt affect stopping>? when i brought it home pushed almost to the floor to get brakes engaged? There can be many reasons for a low brake peddle. The height sensing valve may be one of them. Deciding to eliminate the height sensing valve (which serves an important purpose) before knowing what the problem is is not a logical approach.
Minuit Posted June 20, 2020 Posted June 20, 2020 36 minutes ago, Eagle said: There can be many reasons for a low brake peddle. The height sensing valve may be one of them. Deciding to eliminate the height sensing valve (which serves an important purpose) before knowing what the problem is is not a logical approach. The LSV is ziptied in the "correct" position which allows normal rear braking pressure - as long as the LSV isn't broken. Start with completely bleeding and flushing the entire brake circuit, inspect all components, and replace if necessary. Chances are that needs to be done anyway. If that doesn't seem to help, look to the rear drum brakes. In cars with rear drum brakes, them being properly adjusted and functional has a huge effect on how the pedal feels.
JustEmptyEveryPocket Posted June 20, 2020 Posted June 20, 2020 1 hour ago, Minuit said: Start with completely bleeding and flushing the entire brake circuit vehicle! Any vehicle that I buy (regardless of how good it looks and yours looks quite nice) gets all the fluids flushed and refilled. I recommend you do that as well as refresh all grounds ASAP. Brake fluid, coolant, diffs, engine oil, tranny, everything. That way you know whats in there, and hopefully you are putting in the good stuff. Grounds can always be better on these vehicles. So start with those maintenance items before chasing anything else. Once you get them all done, report back on how the pedal feels, and if anything else came up during your inspection.
early comanche owner Posted June 20, 2020 Author Posted June 20, 2020 Thanks for all the great input. Flushing and bleeding sounds like great first step
Ollie Posted June 20, 2020 Posted June 20, 2020 I think you made a good buy on your "new" Comanche. I just got my first one a couple of weeks ago., paid $6K For the past couple of days my friend and I have been playing with it at his shop. I am not sure if you have the switch on the dash to change the transmission from power to comfort. Mine does and I did as suggest here at the site to hot wire it to power. WooHoo..........want a difference. We also changed the filter and fluid. Its like a NEW trans. I am a car guy and the first step is to change all the fluids, at least in my book. Ollie
early comanche owner Posted June 20, 2020 Author Posted June 20, 2020 thanks ollie, the tranny was replaced 6 months ago, and yes i have the comfort power switch. so your running power all the time? lol
JMO413 Posted June 20, 2020 Posted June 20, 2020 I would say you did good! Very nice truck you have there.
Pete M Posted June 20, 2020 Posted June 20, 2020 9 hours ago, early comanche owner said: thanks ollie, the tranny was replaced 6 months ago, and yes i have the comfort power switch. so your running power all the time? lol eventually Jeep made "power" the default and deleted the switch. apparently "comfort" really didn't do much of anything worthwhile.
75sv1 Posted June 23, 2020 Posted June 23, 2020 The price of XJs and MJs have gone up. No or little rust, I'd say you did good. If you don't have to replace a bunch of parts, then you factor that into the price. If you drive it for 3-5 years with only maintenance, pat yourself on the back. And it looks good just sitting there.
early comanche owner Posted June 23, 2020 Author Posted June 23, 2020 lol thaks 75, I plan on keeping it more than 3-5 years... I waited 30 plus to by my second Comanche, so plan on keeping it.
Zambeezy Posted June 23, 2020 Posted June 23, 2020 Seems like a good price and, more importantly, it sounds like you're happy with it!
early comanche owner Posted June 24, 2020 Author Posted June 24, 2020 lol thaks 75, I plan on keeping it more than 3-5 years... I waited 30 plus to by my second Comanche, so plan on keeping it.
early comanche owner Posted June 24, 2020 Author Posted June 24, 2020 I appreciate everyone's input regarding my brake pedal going to the floor before engaging, Turned out rusted/bad brake lines going to the back after replacing the rear brake lines I have a brake pedal . Work as they should now.
jdog Posted June 24, 2020 Posted June 24, 2020 @Pete M can you move this to the original thread? glad to hear you got it figured out
