just put down the hammer and back away slowly...
  • Replies 747
Posted Images
15 minutes ago, Pete M said:
needs longer brake lines
Stopping that will require a solid, immovable object.
fairly common down south to have normal weekday tires and then giant weekenders.  ya gotta be rollin' in dough to put a bunch of concrete miles on those 40s.  :D
  • 3 months later...
On 7/9/2023 at 1:36 AM, Smokeyyank said:
it's a grand caravan running some mudders.
Think they can still open that slider? :laugh:
Doing dumb stuff at work again.
IMG_5973.jpeg.e8dbbf4aed473966e4c71c02f12246fb.jpegIMG_5975.jpeg.5df46f32167af15ec16ac7f9521a1147.jpeg
Ever have someone tell you the fitting you wanted doesn’t exist?
M6x1.0 to 1/8” npt to relocate three grease nipples out from under a cover plate that’s a pain to remove so maybe the bearings might occasionally get some grease. Easiest way to do this is to use a grease gun hose which means 1/8” npt fittings.
I’m sure these fittings already exist but our supplier never called back and we wanted the machine done by the end of the day. So a bolt with a hole down the middle welded to a union’s going to have to do the job.
Normally I’d prefer to drill out and tap the part to accept the 1/8” npt hose directly, but there wasn’t quite enough thickness in these bearing housings for that.
