Driving on the street to street truck
  • Replies 504
I have to look over it today and I'm gonna have insurance look it over to see if I'll get anything. I know they are probably going to total it out unfortunately but I'll see.
Good thing is atleast I can buy a whole front end new and it still runs and drives so I think the drivetrain is okay. New radiator I know for sure.
  • 1 month later...
Bright side...Definitely looks fixable. Shame it has a title mark now, but not the end of the world. There are also ways to amend that.
If you can't find a good front section near you (for a cut and replace) I have access to a parts XJ with a good front frame section.
Will be glad to see this one on the road again, maybe use some of the funds for some upgrades! (I did when I rebuilt my truck that got totaled in March)
9 hours ago, 70barracuda said:
Hit the steering wheel hard enough I bent it pretty good so I wanted to get a new column and well I have to rebuild it from scratch.
If you didn't already know, these are a treat.
I recall the "Jazzman" name... very helpful document regarding Saginaw columns.
On 12/31/2024 at 7:39 PM, 70barracuda said:
Well i was able to get the front end back into shape. More than I thought I was going to get it. Bought a harbor freight body work hydraulic press. Worked amazing.
I got some steel plate I'm going to weld up to strengthen it too.
Heck yeah, that looks great! I had a dent in my front member too (the previous owner did not disclose the tree stump he had a disagreement with). I ended up using a chain-fall, eye hooks, ratchet straps and a few hammers to straighten mine. Oh and a big 'ol 15ton lathe was used as the anchor point.
My original plan was to pull it all out like that with something to anchor but that hydraulic ram worked like a charm.
31 minutes ago, Eagle_SX4 said:
Looks good. How does that install? Does it attach to the header panel or the hood?
It's got these funky brackets that bolt to the header panel and come out between the stainless trim and grill. 2 out of 3 got pretty crushed in the accident so I have to try make some.
  • 3 weeks later...
