Comanche Dawn
On 11/20/2020 at 10:04 PM, Limeyjeeper said:
Well, I am getting 17mpg. I am in the process of wrapping the harness. Been really busy with work. I will get a full update out later this weekend.
To be honest, I expected better mileage out of the swap. On the other hand, this much power is probably a ton of fun and it is hard to keep your foot out of the pedal.
Had to deal with a leaking injector seal. Got that fixed. Finally got the Engine harness wrapped and finished.
Next I will be pulling the dash because I have this beauty. Scored a reasonable deal.
Once I get the dash back in. I am left with interior panels and carpet. Hoping to get her finished by Christmas.
Did you decide not to use the re-covered dash?
Dash is back in. All the dash harness is wrapped and secured. Sealed the Bulkhead connector and made sure the harness routed properly. Next up getting the interior lights fully working. Adding headliner, interior trim and carpet, and she still starts and runs!!
11 hours ago, Limeyjeeper said:
Managed to get the carpet in today. That is not a fun job. Got the carpet from stock interiors. Fit was pretty poor. But I made it work.
Why do they give you so much excess carpet!!
Next on the list headliner.
I ordered a new vinyl floor for my MJ from ACC. I hate it. It is ablsolute garbage. I've had it in my truck for over a year, and it still doesn't fit how I want it to. ::shaking:
  • 4 weeks later...
So the interior is done.
2 gauges AF and Engine/Trans oil temp
Headliner is also in
Also got the wheel well liners in. Fitted pretty well.
One of the last jobs to do is relocating the intake to behind the radiator. To do this I need to swap out the 2001 Corvette pump for a 2008. That has a much smaller pulley so it will give me the opportunity to drop the intake directly down. Where it is now there is no airflow and I am running IAT of around 180 consistently which is way too high. At the same time I will install the electric heater cut off valve.
New pump
Existing pump
