Anyone ever splurged for this starter...
I don't have a stroker, but I'd imagine yes. If for a stock motor and if your experiencing slow cranking speeds due to elec problem like battery, cables, and grounds I doubt it,  probably wouldnt be good for any starter, even a high torque one, to be operated with than less than optimal available amperage. Elec motors don't like being asked to work without enough juice, causes them to heat up, eventually fail sooner.
It is a starter you would use to start the vehicle while in gear quite regularly. Common practice by some when wheeling a manual in the rocks. The procedure was even mentioned in the TJ owners manual and provided instructions on how to bypass the clutch. interlock.
Paid less for whole Jeeps, even an MJ for$100 bucks...
Honestly, unless I was running a stroker...
Unless the stroker motor has a considerably higher compression ratio than stock, the difference in amp draw will be negligible.
That's on my list,if i kill another stock starter I'm going to get one.
It's also nice because they don't have a nose cone like factory,currently i run a modified nose cone to clear my inertia ring,the mean green doesn't interfere with it.
I got one a few years back for my Cherokee and then when I sold that I transfered it to my Comanche. Been running strong for 6+ years now without an issue even with accidently forgetting to disconnect the battery before removing the starter.
Good to hear that.  Pushing me further towards getting one!
^^ This. Also, if necessary, replace your tired old OEM starter with a good quality new or NOS unit for $50-$70. I just replaced my original 25 year old starter with a NOS unit and the motor spins at twice the RPM as before when starting.
They are smaller and lighter than the stock starters, si? Also it looks like you can use different holes for mounting? That would be nice so the solenoid could be rotated a bit away from the larger oil filters I use.
Not really. About the same weight. Yes they are able to be clocked in different locations depending on how much clearance you might need.
