benjy_26 Posted May 15, 2016 Share Posted May 15, 2016 I have had a Yellow Top for over 8 years (has gone from Jeep to Jeep) and it's running strong. That said, when it does die, I'm going to go to Oreilleys to get one of their AGM series batteries. I read somewhere that Deka makes those for SuperStart and Deka gets great reviews everywhere. Also, the one I've been seeing is going for around $180, which is much more palatable than the $250 Optima wants for their product. Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted May 17, 2016 Author Share Posted May 17, 2016 Got the PA system mounted. I like this spot a lot Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted May 20, 2016 Author Share Posted May 20, 2016 I'm going to finally Herculine my floorboards today. I've had a kit since December but just haven't gotten around to it Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted May 21, 2016 Author Share Posted May 21, 2016 Waking up in the middle of the night to do the last coat but this is what it looks like So far. I really like it. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
ggcnash Posted May 21, 2016 Share Posted May 21, 2016 Same stuff I used looks good! Sent from my SAMSUNG-SM-G890A using Tapatalk Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted May 22, 2016 Author Share Posted May 22, 2016 Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
MancheKid86 Posted May 22, 2016 Share Posted May 22, 2016 diggin it, looks like you have your sway bar attached! i bet it would have flexed alot nicer if it was undone for stuff like that, you undo it for offroading right? keep up with the awesome progress man!! Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted May 23, 2016 Author Share Posted May 23, 2016 diggin it, looks like you have your sway bar attached! i bet it would have flexed alot nicer if it was undone for stuff like that, you undo it for offroading right? keep up with the awesome progress man!! Ya I try to but I forget a lot haha Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted June 5, 2016 Author Share Posted June 5, 2016 Well today I picked up a 89 renix and over this summer very slowly I will build it up into a 4.7 stroker. Can't wait. Motor has 121000 on it and it came with everything. Got it for only 150$!! But loading it was very tough because the cherry picker was broken. Took 2 hours lol The kids dads wrangler was dope too Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
KyleSVT Posted June 8, 2016 Share Posted June 8, 2016 Great Build! Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted June 10, 2016 Author Share Posted June 10, 2016 Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted June 10, 2016 Author Share Posted June 10, 2016 I need to do some research because I don't know what I need to keep and what needs to stay in order. I'm labeling everything very well so that I can put it all back if needed though. I've never been inside any engine so this is all new. I know what everything is but I still feel lost lol. It's a lot of fun though Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted June 10, 2016 Author Share Posted June 10, 2016 Trying to stay organized Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted June 12, 2016 Author Share Posted June 12, 2016 Everything out The first cylinder has 2 groves in it. Doesn't look good so hopefully they can be fixed Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted June 12, 2016 Author Share Posted June 12, 2016 Also blew up my rear drive shaft. I was crawling over 2 rocks and then next thing I know my rear tires aren't spinning. My drive shaft just gave up. When I got home after a 5 miles drive in front wheel drive my rear end was dripping atf so somehow the atf from the transfer case ended up on my ford 8.8 Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
MancheKid86 Posted June 12, 2016 Share Posted June 12, 2016 looks like you hit that rock pretty good! as for the rock rash spiral for an indication that starts faintly at the front of your shaft. acted like a can opener. my truck had a gnarrrrly one that went the full length of the shaft. it took out every output seal i put in within a week of installation until i replaced it it makes sense your rear end was dripping the atf, i bet you didnt have the slip yolk installed while limping it home, so it was shooting out the back while driving and your rear diff was directly in the way of its path, check your fluid levels for fluid loss! and those groove's in the #1 cyl look pretty deep. your going to have some serious over bored pistons or have to get it resleeved. isnt this stuff fun? i love wrenching and building stuff. my $500 4wd conversion beater needs a engine rebuild so I'm thinking about stroking it for fun, or atleast throwing a lumpy cam in it keep it up bud, you should go to bigger tires for more ground clearance you defiantly have enough gears to do so. more pics! Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted June 13, 2016 Author Share Posted June 13, 2016 looks like you hit that rock pretty good! as for the rock rash spiral for an indication that starts faintly at the front of your shaft. acted like a can opener. my truck had a gnarrrrly one that went the full length of the shaft. it took out every output seal i put in within a week of installation until i replaced it it makes sense your rear end was dripping the atf, i bet you didnt have the slip yolk installed while limping it home, so it was shooting out the back while driving and your rear diff was directly in the way of its path, check your fluid levels for fluid loss! and those groove's in the #1 cyl look pretty deep. your going to have some serious over bored pistons or have to get it resleeved. isnt this stuff fun? i love wrenching and building stuff. my $500 4wd conversion beater needs a engine rebuild so I'm thinking about stroking it for fun, or atleast throwing a lumpy cam in it keep it up bud, you should go to bigger tires for more ground clearance you defiantly have enough gears to do so. more pics! I would've got 35s but i was scared id lose to much power, but i regret it now lol. someday hopefully! Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted June 22, 2016 Author Share Posted June 22, 2016 So I had a new drive shaft made. I only had 200$ in my account so I told the shop that I want the cheapest thing they could make but because it took them so long to make it, the owner hooked me up with beefier tube so this shaft should hold up real well! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted June 22, 2016 Author Share Posted June 22, 2016 Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 22, 2016 Share Posted June 22, 2016 Should have painted it silver. :yes: Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted June 22, 2016 Author Share Posted June 22, 2016 It only costed 167$ too! Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted June 27, 2016 Author Share Posted June 27, 2016 For the last couple of weeks my trucks been running weird, like it hasn't been getting enough fuel, and I asked a mechanic at work about it and he told me to change my plugs. When I was changing them, I found that my plug wire was split and so I think I was runnin on 5 cylinders for awhile lol Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted June 29, 2016 Author Share Posted June 29, 2016 So my block I got is junk. The grooves are too deep Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 29, 2016 Share Posted June 29, 2016 So my block I got is junk. The grooves are too deep Sucks. There's lots of them out there though... Link to comment Share on other sites More sharing options...
Reddout Posted June 29, 2016 Share Posted June 29, 2016 Really nice transformation, man Link to comment Share on other sites More sharing options...
