Location
Louisiana
1579 profile views
ggcnash's Achievements
Comanche Addict (5/11)
Love the build could you update the pics pls? doing my an ls swap now interesting stuff! Sent from my SAMSUNG-SM-G890A using Tapatalk
- 17 replies
I will be pulling the 4.0 this weekend and I will verify what I need and don't and go from there Sent from my SAMSUNG-SM-G890A using Tapatalk
LS style throttle bodies??
ggcnash replied to DirtyDeeds's topic in MJ Tech: Modification and Repairs
Dbc or dbw Sent from my SAMSUNG-SM-G890A using Tapatalk -
Don he is basically wanting to convert his 89 to h.o I will not be needing the engine harness and will be using aftermarket gauges in the ls swap. I am not as diverse in the renix jeeps so I just wanted to make sure he has what he needs, I'm sure he can pull minor generic stuff at JY from xj just wanted to make sure their is nothing specific I'm missing Sent from my SAMSUNG-SM-G890A using Tapatalk
Hi guys I have sold the 4.0 in the 91 with harness, to a fellow member to swap his 89 to h.o. wanting to make sure I get everything the young man needs any tips or advice would be appreciated, I'm assuming the main harness, and gauge harness with pcm is all that's needed? Sent from my SAMSUNG-SM-G890A using Tapatalk
Diesel (TDi) conversion discussion & research
ggcnash replied to A-man930's topic in MJ Tech: Modification and Repairs
I agree I beleive it will be fine behind the tdi, I was just referring to the comment that they hold up behind a sbc, not the case in my personal experiences. Sent from my SAMSUNG-SM-G890A using Tapatalk -
As you can see, South of the border shaving the cab vents is popular along with the 2500 front-end and ls swaps! Sent from my SAMSUNG-SM-G890A using Tapatalk
I also will add you don't have to worry about your comanche being air tight lol if you decide you like the looks and shave them Sent from my SAMSUNG-SM-G890A using Tapatalk
With 2500 front clip This thing is sick with an ls1 and shaved vents looks good but I just prefer the vents Sent from my SAMSUNG-SM-G890A using Tapatalk
Comanche SS - LS, Locked, Long Arms...
ggcnash replied to Comanche SS's topic in MJ Hardcore Tech: Epic Journeys to Greatness
my tires are a bit small to make 4:10s as useful as they can be...So i run a little higher than I want to when I get 33-35s. I also don't have the speedo accurately calibrated yet, just one of those things I put off, but I will get an app and give you an estimate soon enough.I'm running 32's which I will keep when running the numbers on the chart it says 2500rpm at 70 in OD with 4.56's seems lower than I thought it might be? Sent from my SAMSUNG-SM-G890A using Tapatalk- 80 replies
- Metalcloak
- MJ
- (and 8 more)
