Britt Posted August 2, 2013 Posted August 2, 2013 I hope the link works below to take you to a couple of pictures of my almost completed (95%) Jeep Comanche Crew Cab pickup (X/MJ). It has been a dream of mine ever since the MJ Comanche disappeared in 92 and I finally got the time and funds to complete it. Started with a low mile 2001 rust free XJ 4x4 Sport 4 door Cherokee (one of 2.85 million made) and a rust free 87 Comanche short bed base truck and after about 3 years of part time work and lots of it, the end result is even better than I expected. I never thought the proportions would be so good and I think the overall look is about as factory as if Detroit made it (which they should have). The wheelbase was stretched from 101" to 147" in the process and it rides like a dream - the overal length is 19.5 '. Learning to park is a whole new process tho as it seems the rear of the truck does not go where the rear of the Cherokee went or not at the same time at least. The unibody frame junction is in the middle of the back door of the Cherokee and is reinforced on each side with 3x3x42" long angle iron with 1.5" holes drilled every 6 inches and rosette welded to both the Comanche and Cherokee side of the unibody frame. A new drive shaft tunnel was fabricated and rolled with new sheet metal and ties the rear of the two driveshaft tunnels together. The floor joints and rocker boxes are either butt welded or plated and welded 100% side to side. The drive shaft was 27.5" long for the Cherokee and a new 5" diameter x 72.5" long aluminum driveshaft was made and balanced by a local suspension shop in Evansville IN. I took the Cherokee trans crossmember and the Comanche trans cross member (now empty and about 30 " behind the Cherokee's) and made a single cross member by cross bracing and plating the two together. It bolts to the bottom of the frame rails in the original places using four bolts into the Cherokee and four bolts into the Comanche portions of the crossmember and frame rails. The bottom back corner of the Comanche doors were cut and welded to the bottom back of the Cherokee back doors to fill in the former Cherokee wheel well cut out in the back doors. The Comanche door post slanted back while the Cherokee rear door post slanted forward so there is a 3" wide x 15 long triangular piece of metal welded in to tie the two posts together. Th roof of the Comanche was 1" taller than the Cherokee so I made a rear spoiler with the height difference at the very back of the cab top - looks like it belongs. From the rear door latch up is Cherokee while below the latch is Comanche on both the door post and the door itself. The local trim shop found the original cloth material to match the front buckets and recovered the Comanche bench to match the front buckets for a five passenger capcacity (all the mounting points for the original bench seat were still with the Comanche portion of the truck floor). I used the plastic gas tank from the Cherokee and the metal floor / gas tank mounting area from the rear of the Cherokee and placed it where the Comanche spare tire was located behind the rear axle - an easy fix for the gas tank. Then I had to fabricate (not so easy) gas fill and vent lines from the new tank location up to the original bedside fill door as I did not want to move the gas filler door to the back of the bed side. I used the Comanche Dana rear end for now since the 3.55 ratio matched the front of the Cherokee but still have the 8.25 Chrysler unit if the Dana gives out (more fabrication needed at that time). The top rack is from an 02 Nissan Frontier (fits like a glove) and the nerf bars are from a Toyota Tacoma four door long bed - OK does Johnny Cash come to mind? After much body work and block sanding, I painted the back doors, cab top/sides/back and bed with the original 2001 Cherokee Stone White base coat / clear coat but am not thrilled with the match and will likely end up painting the rest of the truck at some time down the road. Its OK for now as I will be driving the Crew as my daily driver as soon as the headliner in installed and a few more things are worked thru. I have a PowerPoint picture group of the build starting with the two vehicles if anyone is interested - I would be glad to share. I did not keep track of hours but am guessing I have between 400 and 500 hours invested but as of now that time pretty much has disappeared in my mind especially after seeing what the result was. Thanks Britt - From Southern Illinois and a Southern Illinois University Engineering Graduate way back in 1974 - yes I am older than dirt!
robsimmons Posted August 2, 2013 Posted August 2, 2013 That is one awesome "Cheromanche" / "Comanchokee"!! I'm not far away in Elizabethtown, KY. I would love to see it in person! Thanks for sharing!
buffalob Posted August 2, 2013 Posted August 2, 2013 Would love to see your build pics on this. You built a winner sir. and yes it does look factory. awesome truck.
onlyinajeep726 Posted August 2, 2013 Posted August 2, 2013 This looks awesome! Very professional job. Come to NC with that thing, I'd love to see it up close.
FrankTheDog Posted August 2, 2013 Posted August 2, 2013 Beautiful job, I would love to see the build pictures also. Especially of the grafting of the two chassis.
johnny quest Posted August 2, 2013 Posted August 2, 2013 i love it. its beautiful. if you ever want to sell it, i'll start the line right over here.....
johnny quest Posted August 2, 2013 Posted August 2, 2013 pics are certainly needed! Beautiful job, I would love to see the build pictures also. Especially of the grafting of the two chassis.
onlyinajeep726 Posted August 2, 2013 Posted August 2, 2013 Next up, crew cab dually with a Cummins diesel!
johnny quest Posted August 2, 2013 Posted August 2, 2013 Next up, crew cab dually with a Cummins diesel! :brows:
Dadinator Posted August 3, 2013 Posted August 3, 2013 I also am pretty close to E-town. I would also love to see it in person. That is one awesome "Cheromanche" / "Comanchokee"!! I'm not far away in Elizabethtown, KY. I would love to see it in person! Thanks for sharing!
martin809 Posted August 5, 2013 Posted August 5, 2013 That is Beauty at it's best. I would love to see the build thread on this.
buxmj Posted August 6, 2013 Posted August 6, 2013 That is so impressive. I can't believe how "right" it looks. Thanks for sharing!
jonb8 Posted August 7, 2013 Posted August 7, 2013 Very impressive job on this truck, I've also thrown this idea around for years. I'm also interested in looking at the truck and I'm alot closer in WV. I'm in the process now of marrying a xj front unibody with a AMC eagle, so looking at your work helps inspire me for the endless hours of spot welds..LOL
onlyinajeep726 Posted August 7, 2013 Posted August 7, 2013 Very impressive job on this truck, I've also thrown this idea around for years. I'm also interested in looking at the truck and I'm alot closer in WV. I'm in the process now of marrying a xj front unibody with a AMC eagle, so looking at your work helps inspire me for the endless hours of spot welds..LOL That will be a very unique setup. Do you have any pictures?
Herc Posted August 7, 2013 Posted August 7, 2013 That is awesome Britt!! We all would like to see more pics of the build process
ftpiercecracker1 Posted August 8, 2013 Posted August 8, 2013 A master piece, truly it is. We must know more about the build process.
H3RESQ Posted August 8, 2013 Posted August 8, 2013 WOW! I really want to see some more pictures of the process. PM me when your ready to sell it!
yellaheep Posted August 8, 2013 Posted August 8, 2013 Wow, this Britt guy is a massive tease..........
jonb8 Posted August 9, 2013 Posted August 9, 2013 Very impressive job on this truck, I've also thrown this idea around for years. I'm also interested in looking at the truck and I'm alot closer in WV. I'm in the process now of marrying a xj front unibody with a AMC eagle, so looking at your work helps inspire me for the endless hours of spot welds..LOL That will be a very unique setup. Do you have any pictures? There's some pics in this build thread of Copper the hound dog, don't want to Hijack this guy's thread. http://comancheclub.com/topic/39506-copper-the-hound-dog/
Britt Posted December 10, 2013 Author Posted December 10, 2013 If any of you want to email me at britt.mcneely@gmail.com, I do have a Powerpoint presentation with dozens of pix that I will try to get back to you. I am finishing the truck now after driving it for several months. New heavy off road bumpers, trim, ID badges and new matt black screen print hockey stripes that you see on some 2013 FX4 F150 crew cabs which I think will really make the truck standout. The ID badges on both front doors will be "Cherokee - Sport Trac XLT" with the XLT standing for an "XtraLongTruck". Going to cut and fit and put the factory rubber sport trim back on the lower door ridges,B pillar and bedsides as well. Thanks for all the great comments - never thought that it would turn out this good - never fails to draw a few observers with lots of questions and picture takers when it is parked for any time at all. What an awesome truck which is equipped with the very unique Illinois vanity truck plate "IMADEIT".
Pete M Posted April 19, 2018 Posted April 19, 2018 “Comanche Crew” by Britt McNeely (and friends) 2001 Jeep “Comanche Crew” crew cab hand built pickup (model XMJ) – the one that Detroit should have built but did not – McNeely Enterprises made it happen(with some help from friends) Starting with a red 1987 Jeep Comanche (MJ) short bed truck and a white 2001 Jeep Cherokee (XJ) 4x4, 4 door loaded “sport” both very straight /rust free (the 2001 was purchased in white for a reason – hides bodywork well J) Project planned since the early 90s - began 3/27/10 and finished 8/1/2013 OK – I did cut two perfectly good vehicles into four pieces not knowing with 100% confidence that I would end up with one new vehicle (and 2 extra pieces) – but it did work! Wheel base of the new 4 door Comanche Crew stretched about 45”. Overall length after all modifications to be about the same as a 2004 Dodge Dakota Quad cab but the Jeep will have a full 6’ bed. The Jeep Comanche pickup was made from late 1985 until 1992 and was only available in a regular cab with a 6 ft or 7 ft bed. It was offered in 2x4 and 4x4 with many different trims and drive train options. The truck was based on the already existing Jeep Cherokee sport utility vehicle (identical from rear of front door (4 dr) forward) and maybe the only pickup ever to have a uni-body front frame and rear frame rails to bolt a separate bed to. Let’s take a rust free 1987 Comanche 2 x 4 short bed truck built by Jeep
Pete M Posted April 19, 2018 Posted April 19, 2018 2001 was the last year for production of the Jeep Cherokee (box version). There were millions made during the production run from 1984 to 2001 and they were very good vehicles (2 dr and 4 dr versions were built). This one is a fully loaded 2001 4x4 classic with only 78K miles and is in very good condition. 4.0 (242 cu in) in line 6 with auto trans and 231 transfer case. Then add a rust free 2001 Cherokee 4x4 sport utility built by Jeep
Pete M Posted April 19, 2018 Posted April 19, 2018 1987 Comanche Preparation Rear of 87 Comanche – Note frame rails formed from under cab unibody rails
Pete M Posted April 19, 2018 Posted April 19, 2018 Frame rail and rocker box cross-section cut – Cut in front of transmission cross member – will reuse x member for strength Crew cab will have both Cherokee and Comanche transmission cross members
