DrThunder Posted December 18, 2007 Share Posted December 18, 2007 went to advanced auto and got one of those lights because they only had one but can't wait until tomorrow to do it! Link to comment Share on other sites More sharing options...
Tonedef131 Posted December 18, 2007 Share Posted December 18, 2007 Well I just finished installing all of the lights discussed in this thread and it makes a huge difference. I had about $15 into it total and the only one not working right now is the ashtray light, that one is burned out. I haven't had interior light since owning this jeep, so I didn't even know when turning the light lever it kept them on! Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 22, 2007 Author Share Posted December 22, 2007 No AAP Stores out here on the Left Coast... anyone found an on-line source for these? SW2 Look in my original post. I put a link to the company that makes the lights...just click on the name in blue and you may be able to find a resource through them. Link to comment Share on other sites More sharing options...
Comanche91 Posted December 29, 2007 Share Posted December 29, 2007 just got done doing this. thanks for the info. the lights cost $3.79 each at AAP and it does make a substantial difference. Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 29, 2007 Author Share Posted December 29, 2007 just got done doing this. thanks for the info. the lights cost $3.79 each at AAP and it does make a substantial difference.Very cool. I am always happy to be able to help if I can. :cheers: Link to comment Share on other sites More sharing options...
tjbliley Posted December 29, 2007 Share Posted December 29, 2007 Here is an online source for the pillar lights. Partsamerica http://www.partsamerica.com/ProductDeta ... ber=UL71CS can ship to you. Link to comment Share on other sites More sharing options...
feerocknok Posted December 30, 2007 Share Posted December 30, 2007 This should get moved to the DIY forum, for sure. And that part number should work at any Advanced Auto, Checkers/Schucks/Kragens/Murray's, and (I think) O'Reillys. Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 30, 2007 Author Share Posted December 30, 2007 This should get moved to the DIY forum, for sure. Yea...I agree. That forum was not there when I wrote this, but it should be in there now. Link to comment Share on other sites More sharing options...
WahooSteeler Posted February 4, 2008 Share Posted February 4, 2008 Just thought I'd add to this, because it is an awesome thread that a lot of us did not know about. Below is a pic of the ashtray light, i.e. w/the blue cover. In addition, while i had the dash apart, i noticed there is a light that clips on to the cig lighter. it lights up a green glow ring around the lighter on the dash and also shines down in to the lighter socket to illuminate that. i noticed its the same assembly as the ashtray light, just a different end on it. and since i had just replaced the ashtray light, luck me, they came in a 2 pack, so now i'm just about all lit up. i still need to figure out the hvac light and i will have gone from completely dark at purchase in sept. to fully lit now. Sorry for the bad res on this pic, at night w/camera phone. I detached it from the lighter socket to show a little better. by the way, the bulb part # for the ashtray is an 1891, and for the kick panel lights is a 194. Hopefully I've contributed a little something here.......... Image Not Found Image Not Found Link to comment Share on other sites More sharing options...
DansGreyMj Posted February 6, 2008 Share Posted February 6, 2008 ive got a problem with my interior lights not turning off, its not the dimmer switch and i already replaced the door switches, i have no idea what it could be. Link to comment Share on other sites More sharing options...
DansGreyMj Posted February 6, 2008 Share Posted February 6, 2008 i think maybe some fluid from the clutch leaked onto the panel, the dome fuse is on top. has anyone encountered this before? Link to comment Share on other sites More sharing options...
jtdesigns Posted February 6, 2008 Share Posted February 6, 2008 Just thought I'd add to this, because it is an awesome thread that a lot of us did not know about it.... Image Not Found I have a set of those under dash lights for sale if anybody needs them...(The yellow ones in Wahoo's picture) shameless plug Hey Dan you sure you got the right door switches??? Link to comment Share on other sites More sharing options...
chicofuentes0224 Posted February 8, 2008 Share Posted February 8, 2008 JT I'll take the under dash lights. PM yuor paypalinfo and total tp CAmphill, PA 17011 Link to comment Share on other sites More sharing options...
GosaGT1988 Posted March 10, 2008 Share Posted March 10, 2008 Here's the link to Advace Auto Parts for the lights. http://www.partsamerica.com/ProductDeta ... yCode=3154 Link to comment Share on other sites More sharing options...
Pete M Posted January 9, 2009 Share Posted January 9, 2009 bump so I can find it and move it to the DIY forum Link to comment Share on other sites More sharing options...
phenryiv1 Posted January 10, 2009 Share Posted January 10, 2009 Then you simply put some male spade connectors on the ends of the wires on the new light fixture and plug them in to the apprpriate connectors on the wiring harness in the Jeep. The red wire is the hot and the black with white stripe is the ground. What does the third wire do? Link to comment Share on other sites More sharing options...
BLHTAZ Posted January 10, 2009 Author Share Posted January 10, 2009 That is a ground wire from what I understand. I guess the original lights had a feature where you could push them or move them to turn them on & off independently and it used that wire. The set up I used works fine with both doors and with the headlight switch too so I saw no need to use whatever it is. Link to comment Share on other sites More sharing options...
jeeptruck86 Posted April 30, 2009 Share Posted April 30, 2009 Thanks for the info. I installed mine today! I tried to get the originals working but every time I messed with them another piece would break off. HA! It's nice to be able to see in the dark. Sweet! :D Link to comment Share on other sites More sharing options...
WahooSteeler Posted April 30, 2009 Share Posted April 30, 2009 Thanks for the info. I installed mine today! I tried to get the originals working but every time I messed with them another piece would break off. HA! It's nice to be able to see in the dark. Sweet! :D Wow, blast from the past! Welcome back.... :cheers: Link to comment Share on other sites More sharing options...
Deleted user Posted May 29, 2009 Share Posted May 29, 2009 man thats slick. mine were missing when i bought it, I just checked Advance's website here's the link, the name seems different but the part number matches the one in your pics. and for $7 total can't beat it.. guess i gotta go to the parts store again ;) http://shop.advanceautoparts.com/webapp ... RP2044____ Link to comment Share on other sites More sharing options...
Jeepcom23 Posted June 7, 2009 Share Posted June 7, 2009 I did the same thing but used LED's instead. Link to comment Share on other sites More sharing options...
COMANCHE45 Posted June 26, 2009 Share Posted June 26, 2009 This was one of my 1st mods and works great for $4 a light (Advance Auto,I think). Great idea for kick panel lights, think that might get done this weekend. :brows: Link to comment Share on other sites More sharing options...
bigalpha Posted July 28, 2009 Share Posted July 28, 2009 you can see how much they actually do light up. the bulbs are the same as your corner marker bulbs and gauge bulbs. you'll need to get the lights and harness from 1989 and earlier if your truck is earlier than 89, or 1990 to 1994 if your truck is a 90 through 92. the harness is different. I have a spare set from 1990 if anyone wants them[/img] What do you mean get the lights and harness? In my 88, it should have the wiring all the way up to the connector, right? I just need the light and pigtail that comes off the light? Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted July 29, 2009 Share Posted July 29, 2009 Right, at least thats all I needed in mt '89. CW Link to comment Share on other sites More sharing options...
