Everything posted by DansGreyMj
First project, 89 Pioneer rear axle
DansGreyMj replied to R1.'s topic in MJ Tech: Modification and Repairs
Your best bet is to cut everything off of the axle and start fresh. Barnes4wd sells complete perch setups for around $100. Sent from my SM-G930T using Tapatalk- 3 replies
- #rearaxle
- #leafsprings
(and 1 more)
Tagged with:
TJ Rubicon front 44. Xj dana 30 outers and brake will bolt to it. Sent from my SM-G930T using Tapatalk
Flipping Leafs Backwards To Gain Wheelbase?
DansGreyMj replied to fmaster7's topic in MJ Tech: Modification and Repairs
Over -
I recently installed 97-03 F150 leaves on the back of my truck. They're 2/1 leaves and I added an extra Mj 3rd leaf (the leaf with the clamps) I had lying around. I installed them with RE2705 boomerang shackles. The center pin is roughly 3/8s rearward and the springs are about an inch longer overall. The wheels came out kinda centered. The only issue I had installing them was the front bushing uses a 3/4 bolt so you'll have to get creative and the rear bushing is slightly wider than the Mj so I had to spread open the shackles. Those are 35s -
FF is convenient, but for this truck the way its setup is more than enough. If i were to build another wheeler it would be something a little bigger like an Explorer/4runner on 05+ Superduty axles. The front is roughly 65". I did move the front flare up to the body line shortly after this pic was taken, The truck had been sitting and that's the first time it moved in a while, that's why it was filthy.
5 lug. It's 35 spline and its almost identical to the rear end in the white Mj posted above, he built it.
I have a custom 60 in the rear of my Mj. It started out as a full floater from a 78 f250 converted to semifloat. It's got 5.13s and a locker. The shocks are temporary. The front is a full width hp44 with Flat top knuckles.
I've had some issues with rear springs wrapping instead of compressing. My last set of springs had completely flattened out so I ordered an antiwrap bar kit from Ruffstuff. I swapped in some modified 97-03 F150 springs, which are nearly identical to Mj Leafs, and rather than destroy these springs I'd like to install the antiwrap bar prior to driving. I did some online searching, but the more I read the more confused I got, lol. I ordered the kit with a 5ft lower bar because as I understand it the lower needs to pivot at the same point as the driveshaft and at the same angle. I was hoping someone had some experience installing one in an Mj and could point me in the right direction. I have the parts to build a crossmember, but space will be tight. The truck is a shortbed 4.0 5spd 231 w/SYE. Any pointers and pics would be greatly appreciated. Thanks, Daniel
1988 Jeep Comanche Aka The Penny Sniffer ,pic Heavy
DansGreyMj replied to Zebvance's topic in Member Projects: Your Comanches
Are you still going to run factory style steering? -
2WD 88 Eliminator (ROCK FROG)
DansGreyMj replied to dragordie's topic in Member Projects: Your Comanches
I don't know what the number means, but my 87 says 259 in that spot. -
My Herculined 90 Comanche
DansGreyMj replied to manche_mane's topic in Member Projects: Your Comanches
I've been running Rough Country drop brackets without braces since they came out years ago and I've had zero issues. -
1987 comanche first car
DansGreyMj replied to Jackrabbit41's topic in Member Projects: Your Comanches
The tabs weld to the bumper and mount to the brackets to make it easier to install/remove the bumper. -
I wonder if they finally solved the frame issues with this gen.
Where to get Dana 44 front
DansGreyMj replied to Jacob Ochs's topic in MJ Tech: Modification and Repairs
The Jk internals are slightly stronger than a regular 44, but the housings themselves are junk without sleeving and trussing. -
Feeling bad about how much $$ you have in your MJ?
DansGreyMj replied to RochesterMJ's topic in The Pub
That's way too much money for it to still have Chrysler spec'd axles under it. -
Look up Adams Driveshaft in Vegas. They gave me a better deal than any local shop did, hundreds less, and shipping was free.
Project "Eliminator"
DansGreyMj replied to 89eliminator's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Post up how they fit. My front end is already plated and I'm very interested in doing the rest. -
Did you get your stiffeners from these guys? http://www.t-mfab.com/store-3/cherokee-xj-comanchee-mj-parts/ -
Non MT springs. I think they were off a 2wd.
So I was getting ready to refresh some springs for my mj, when I took them apart the rear retainer bolt and sleeve had left quite the impression on the main leafs. The deepest point is probably around 1/16". I looked at getting new mains made up at a local spring shop, but even the guy running the front desk thought the price was ridiculous. Here are a few pics. Do you think they will be okay to run?
8.8 Brake line questions
DansGreyMj replied to Jackrabbit41's topic in MJ Tech: Modification and Repairs
When I did my 8.8 I used two passenger side caliper soft lines from an explorer and used off the shelf parts store hardlines and connected them to an extended xj rear stainless brakeline. -
Qbombs build thread part II
DansGreyMj replied to cody.quattlebaum.16's topic in Member Projects: Your Comanches
You might be able to fix that one using a sending unit from the same era Cherokee. -
1990 Comanche Daily Driver Build
DansGreyMj replied to Francesco's topic in Member Projects: Your Comanches
Lower as in numerically higher, ie 4.56+ -
Banging when coming to a stop... drum brakes?
DansGreyMj replied to SBpunk's topic in MJ Tech: Modification and Repairs
Check your front caliper bolts. I had one back out and the caliper would lift up and bang the inside of the wheel upon braking while driving forward. -
I would go lower than 4.10s for 33s. I've been running that for years and it's too high.
