Post A New Picture You Took Thread!
Jeepcom23
15 hours ago, mbred0609 said:
Asked my son to swap some tires off my daughter's tj to my new to me cheap jeep so I could get the inspection done. I should of checked, but he either stripped the old lugnuts or the studs. To be fair they were probably already junky. Either way 1/2 mile from home and.... 45 mins later it was back home and getting a royal front end treatment.
Ouch!
  • Replies 672
If the lug nuts aren’t tight on the left side of the vehicle, the wheel wobbling around will spin them off. On the right side of the vehicle loose lug nuts spin themselves sorta snug but still loose enough the studs will bend enough to fatigue and eventually snap, or wear the nuts through the wheel.
It would pay to double check the torque on the rest of the lug nuts before driving after the wheel that came off gets corrected. Usually if one wheel was loose the rest will be too.
Wheels and lug nuts that have been on the same vehicle for a long time tend to wear into each other, and might not play nice when paired with a different wheel or lug nut, and require quite a few frequent retorquings before they’ll stay tight for you. This is especially true if you used lug nuts that had been used with steel wheels on an aluminum wheel. The steel wheel wears a stronger pattern into the steel nut, where a steel nut will wear itself into a much softer aluminum wheel. Aluminum wheels don’t usually like the shape that a steel wheel wears into a lug nut.
On 10/14/2024 at 1:09 AM, TurboedMJ said:
Did a sunrise hike at dirty Harry's peak in Snoqualmie pass yesterday morning and found a big drop off that overlooked Interstate 90. PXL_20241012_151404201.jpg.9cb0d5bf7d5eb18671e2856ebb9f09ce.jpg
jesus h chri....not a spot for anyone who doesnt like heights! I'm jealous. I do an annual backpack trip for week up in Maine each year, but our drop offs on this side of the country are nothing like that
  • 3 weeks later...
  • 4 weeks later...
On 11/19/2024 at 11:37 PM, WranglerMangler said:
A mount Rainier morning on the way into work.
Found a big rock at work recently.
Komatsu PC360 can’t move it. Not the biggest machine but respectable in size and power. Bottom of the pit is 20’ across.
Now that's a rock!
