The MJ screw/bolt size thread. Help gather the info...
Anybody have the specs for the caliper bolts on a 90 4x4 swb? I have read thread on here that was over this, but my bolts are totally different. The heads on these bolts are a tiny 12point head, 5/16 socket which nobody seems to carry.  I want to replace them with a plain jane hex.
ftpiercecracker
  • Replies 75
5/16 12 point should be readily available, although it is more likely it is a metric 8mm which is about identical in size. I have a few of them.<br /><br />IIRC stock should be 7mm (or was it 9) Allen on older ones (pre 90?) and 10mm hex head on newer ones.
  • 1 year later...
  • 3 months later...
  • 8 months later...
  • 11 months later...
  • 8 months later...
  On 7/15/2017 at 4:04 PM, Double Six said:
Anybody know the size of the bolts that hold the fan shroud on the radiator of a 2.5 ? it's an 86 model.
Don't know the size but the p/n is J3189013 and they were used on XJ/MJ fan shrouds up to 1996.
  • 3 years later...
Crankshaft position sensor is M7X1.0, but good luck finding that somewhere other than the dealer since it's an uncommon size, and half of the shank is an unthreaded shoulder, to precisely center the sensor. If you lose 'em, I found out that big conical head Phillips screws of the right size work perfectly to self-center the sensor. Found them in my bucket-O'-bolts from when I worked at a body shop, and IIRC, they're for a door jamb striker, can't remember what car though!!!
Anyone know the size of the bolt holes about the middle of the bottom of the block just above the oil pan. I have a oil pan skid that bolts there. Can’t figure out what the thread is. Want  to run a tap through to chase but there’s too munch junk in the hole. Don’t want to screw it up.
Expand
you should probably post that in the Tech forum so more eyes will see it. :L:  and a pic might be handy.   be sure to bring the answer back though so it's in the proper thread :D
Expand
I guess I just need to pull the knock sensor out and measure that. It is in one of the holes I need to use anyway. It should be the same as the other side I would think.
Expand
Well I was wrong. Both bolts are different sizes. The one on the passenger side ended up being a regular 3/8 coarse thread bolt. The driver side is the knock sensor. It’s a finer thread and a little larger. I think m10-1.25.
  • 2 years later...
