Everything posted by DirtyJeepGuy
Project RHD
DirtyJeepGuy replied to DirtyJeepGuy's topic in MJ Hardcore Tech: Epic Journeys to Greatness
I've clearly failed to keep this thread going. However i have the full 97+ swap, 4x4 swap & RHD swap mostly complete. Fine tuning the LS that's in it now & getting everything buttoned up. If i remember I'll add a ton of the progress photos here. If not, i have a page on Facebook called "Project Wrong Side" with my progressive post. -
Project "Black Betty"
DirtyJeepGuy replied to shelbyluvv's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Just so you know. I'm the new owner of Black Betty. I went 5 hours southwest for it yesterday. My goal is to finish what you started. I already have an LS Comanche. So 2 v8 Comanches will be lovely. -
Project RHD
Been a bit busy stripping xjs, working & such. But made a goal to have this done by May. Even if it's 7 different colors. Installed bumpers. Located a 241 drivers drop. Few leads on a TH400. I don't want no electronics attached to the shifting. Reason I chose the TH400. -
Project RHD
Set the 5.3 in for clearance testing. Manifolds will definately be on the list. As well as alternator relocation. -
Project RHD
Project RHD
Project RHD
Sadly I am not. -
Project RHD
Project RHD
On Thanksgiving morning I went out & got my donor for the motor. 2004 Chevy Suburban. 5.3 V8. I'll pull it apart & sell what I don't need to recoup some funds. -
Project RHD
I decided against the normal 4.0 install. With the cost of rebuilding a 4.0, rebuilding into a 4.6 stroker or a rebuilt 4.0 & adding supercharger/turbo. A LS would be the best with cost & gains. Ordered the Novak Adapters LS Mounts for XJ/MJ. -
Project RHD
Both seats installed. I also installed the snek gauge kit from Azzy Design Works. Front seats bolted in with the Hawley Performance mounts. Obviously had to drill the holes for the rear. -
Project RHD
Patched the "drivers floor". There was tons of small hole's all around it. Also installed the Hawley Performance seat mounts. -
Project RHD
Dana 35 removed. 8.25 Installed with SOA. Perches aren't welded in yet. Removed rear bumper & installed my 7s Motorsports steering. -
Project RHD
Yes -
Project RHD
Project RHD
Project RHD
Picked a 1999 Jeep Cherokee up to strip. Front clip was in decent shape. Drivers fender will need to be replaced. But for mockup it'll work. Front clip updated. -
Project RHD
Project RHD
Project RHD
The 1997 Jeep Cherokee Donor. Dash pulled. Driveline pulled. I planned on using this 4.0, aw4, & 231. But plans changed. -
Project RHD
Project RHD
Pulled the 4.0 & ba10. Ended up selling it off. As well as sold the front bumper/header panel due to not needing it. -
Project RHD
Ended up picking a 6.5" Long Arm for $550. Turned around and sold the leafs & trackbar for $300 because it won't work with my build. -
So I've finally decided to do a build thread over here. Picked a 1988 Jeep Comanche up few months back. 6 hours round trip. Originally from Arizona. I bought it outside Detroit Michigan. Had the 4.0 5 speed 2wd setup but was pretty clean. I had a 1997 Jeep Cherokee Right Hand Drive sitting around with a rotten unibody. So I decided to make a 1997+ Right Hand Drive Comanche.
