Double Six
Everything posted by Double Six
  1. Will it run ok,or do you have to do anything else to it ? Thanks.
  2. Hi,EGR valve bad on 2.5 ,can you just block it off and that fix it or what do you have to do short of replacing it.It is backfiring bad and acceleration is terrible and missing ,sometimes running good .
  3. Can someone tell me the correct size clutch to order for 86 model with 4 cyl 150 c.i. with 4 speed trans 4 wheel drive 207 transfer case.?Thanks
  4. No,the only ones that are shiny are the ones that are connected to the battery. Starter is old. I;ll try clening up cables ,but i'm thinking it may be the starter . I have had truck for a year and a half and I know it sat up for 3 years before that.
  5. Hey Guys, I have a new battery ,when you first turn on the ignition to turn over engine it is real slow almost like a dead battery but then kicks in and spins really fast like it suppose too. any ideas as to what my problem may be ? thanks :???:
  6. Okay,thank you !!
  7. Hi,I tried to find this elsewhere but no luck ,I need to know the size and type of screws or bolt for the fan shroud on 2.5 86 model Thanks !!
  8. Anybody know the size of the bolts that hold the fan shroud on the radiator of a 2.5 ? it's an 86 model.
  9. Where can you buy new head bolts for Amc 2.5ltr.150 ci. 86 model ? Thanks
  10. okay thanks a lot, not much room down there.
  11. What size socket is used on the oxygen sensor on a 2.5 4cyl.? Thanks!!
  12. Ataki, Sorry about that,I see after further research that the ax-4 is a manual trans like mine. I'll be glad to take it off your hands ,let me know how much for shipping ? Thanks.!!
  13. Thanks, Ataki,but I need one for a manual trans. they are programmed different .
  14. sorry I have to have one for a MT. thanks though.
  15. I was told at the parts house that if you have an automatic you have to get one for automatic,if you have a manual you have to have one for a Manuel trans.
  16. Looking for a good ECM for 86 Comanche 2.5 ltr 4 speed 4x4 .Thanks.
  17. Thanks HornbroD !!!
  18. Does the 2.5 ltr. 4 banger have a distributor sensor in it ? or is it controlled with the ICM ?
  19. THANKS FOR THE INFO,I will update in about a week or so when I go back over there.
  20. Yes I have the 2.5 ltr. it has 144,000 MI on it,no noises ran great ,not much power but they never had much power. I don't believe the timing chain broke while it was sitting there overnight,it just did all this from running great when I shut it off to this when I started it up the next time.
  21. I'm sorry ,but what do you mean by that?
  22. It had .05 on the ac scale.
  23. That was what the multi meter said.
  24. Hey guys, still need help figuring this one out.A few weeks ago, I posted about my truck putting me down when I took a 200 mile trip in it ,the only good thing about it , it put me down at my mom's house so it's in a safe place. First of all it's not firing, I have put new CPS, checked it today it's putting out .05 volts when you crank over engine. Also put on new ICM still won't start. new coil still want start. It's getting plenty of fuel, has new pump and new gas tank and is full of gas also new fuel filter. It has new distributor cap, rotor button and new plugs and plug wires. When problem occurred it ran great going over there,was parked for the night ,started the next day and it ran like crap,then became worse missing so bad it barely made it to her driveway. It quit there and hasn't started since. Any ideas ,I really need my truck and to get it back home. thanks.
