3
Everything posted by 88whitemanche
External slave cylinders
88whitemanche replied to 88whitemanche's topic in MJ Tech: Modification and Repairs
When I mentioned the rod...I meant the rod of the Slave cylinder that goes into the bell housing -
I tried that but the washer on the older one doesn't fit into the new one.... So I redrilled the hole to fit my pedal assembly it's a 1/2 size drill bit -
What's up fellas So I'm close to halfway through my ax15 swap and I had gotten 2 used clutch master cylinder and clutch slave cylinder kits from the jy and followed "factory" procedures to bleed them.... But when I go to install everything in place the rod pops off when I press the peddle and falls into the bell housing Is it easier to just buy a whole new pre-bled set or Is there anyway to prevent this....?
SWB Rollbar NW DC... $700
88whitemanche replied to Bonkers's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
For $700 it's a steal with the roll bar.... Plus tail gate, tail lights, sending unit, could have the Dana 44, skid plate package, -
MJ/XJ stuff ... Taillights!
88whitemanche replied to NHMJXJ's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Are they NOS lights? -
stock gear ratios for '86 2.8 5spd 4x4?
88whitemanche replied to shawn's topic in MJ Tech: Modification and Repairs
This 86 had the 2.8 and had the amc 20 with 4.10s non posi.... -
4.10s for dana 30
88whitemanche replied to Jackrabbit41's topic in MJ Tech: Modification and Repairs
It will be fine if you stay in 2wd, But like shelby said, Pull the driveshaft just in case.. You don't want to deal with repairing it if the shifter gets pushed into 4wd on accident. Also, it might just be cheaper to pick up a d30 with 4.10 gears already in it, And just swap the entire axle. You could also probably find a non cad 4.10 (Not sure what years/etc had 4.10) Stupid rare! I've been looking for 3 years... Sorry to thread hi-jack -
4.10s for dana 30
That's where I bought mine...He has his eBay store with free shipping -
4.10s for dana 30
USA standard paid about 220 shipped on eBay with a master install kit -
Try tapping the starter relay...
That's perfect! I think lol....
Well since doing the ax15 swap there's no complete kit for the 2.5.... So I had to peice it completely... I originally bought a luk clutch kit for mine but for that year and it did come with one but it's not the correct one.... I ordered one from rock auto...should be here at the end of the week.... You wouldn't happen to have a transmission jack do you? Floor jack and a block of wood just isn't cutting it....
Advance adapters free shipping coupon code PNSHIP2015 Just ordered a np231 sye and just saved $67....I'll take it any day....
Ax5 is out and was a pain trying to get the stock pilot bearing out...4 hours to say the least...until I gave up and borrowed an impact gun to get the fly wheel off... Forgot to get a clutch alignment tool so gotta wait until the end of the week to get one...parts stores don't sell them separately
gearing question for the metric ton
88whitemanche replied to comanchebuilder21's topic in MJ Tech: Modification and Repairs
Ok 88 means b/a 10 transmission....and 3.07 gears And you have 3 rear axle options Dana 35, dana 44, and amc 20.... Since it's an 88 amc 20 is out of the picture.... Unless that truck has already been modified.... Stock Comanches with an auto came with 3.55 gears and manual had 3.07 gears....if you had a 4.0 2.5 Comanches auto (rumored) came with 4.56 gears and the manual came with 4.10s -
Any other way? I don't have one or anyone that does.... Also after replacing the pump... I noticed after idling (30 mins), and restarting it the idle would shoot down to 50-200 rpms and it will stay there for about 30 seconds then start hunting for an idle to bump it back up to 500-700 rpms... Could this be tps?
Will check that out Friday when I get back to the tRuck....
Welp replaced the pump and it still happens... I'm at a loss fellas...idk what to do
I see he has grabbers.... It's time he updates his build thread!!! Congrats!
Several trans questions
88whitemanche replied to Strokermjcomanche's topic in MJ Tech: Modification and Repairs
I'm not sure...the one with experience would be xjrev10 That he has it on his with the nv3550.... http://comancheclub.com/topic/32908-the-wyomanche/page-5 -
Check out the rustys ax15 1" drop HD crossmember -
Not Another One!!?? '88 Eliminator
88whitemanche replied to JeepsOLot's topic in Member Projects: Your Comanches
I've seen it... Weren't you and outlaw planning a mini camper with that one?..... Obviously you need it now more than ever -
There's a Comanche close to where you picked up this one up that would be a great parts truck....
