fiatslug87
Moderators
    8
Everything posted by fiatslug87
  1. You have a Pearl White Pioneer Metric Ton
  2. On eBay in Kingsport, TN $22K Buy it Now, 4.6L stroker
  3. That’s only 620,517 real distance.
  4. I like it Do you have the link for it?
  5. What did they charge, if you don’t mind me asking? Seems like they really enjoyed working on your truck.
  6. Same gears in the two?
  7. At Copart in North Charleston, NC
  8. Bugs? You know this MJ will never see bugs!
  9. Added a couple Rough Country MOLLE panels, they’re meant for the left and right rears of a Tacoma but they fit end to end in our long beds, they need trimming if they’re set behind the bed rails (they will also fit our short beds as intended for the Tacomas). For the bottom standoffs I installed nutserts into the bed and used 1” plastic rod cut into 2” lengths that were drilled and countersunk for the nutserts.
  10. Dimensions are listed in this post.
  11. I put mine in a plastic dropper bottle with a piece of tygon tubing on the end. Polypropylene and polyethylene can handle the acetone.
  12. There’s also a plastic spacer in there, don’t loose it.
  13. Have you loosened that return line? It should just pull off when squeezing those tabs. The regulator just presses onto the fuel rail with an o-ring.
  14. Just put them there for the pic, they’ll be in a dry place.
  15. Thanks Pete, just got mine.
  16. Welcome to CC, post its VIN in the registry section for info on it.
  17. February 2023 update, see first post. 19 new additions this month for a total of 2073.
  18. Welcome @Steven Harden, you got yourself a nice truck.
  19. Looks like it will interfere with the spare tire winch handle hole if that matters to you.
  20. I fill them to the top and use the 2.5L overflow tanks.
  21. I’ve had Mac tanks on all three of my MJs with all stock heater tube plumbing for over 15 years and do not go through radiators.
  22. There are 13 in the registry (including this one), only 6 posted by members the other 7 by eaglescout526 from the Chrysler database.
  23. Is your water pump weeping and the coolant is running down and towards the trans? What year? Open or closed system?
  24. Will you ever finish one of them?
