8
Everything posted by fiatslug87
What is this wire behind front bumper?
fiatslug87 replied to robfg67's topic in MJ Tech: Modification and Repairs
My ‘90 also has that connector, but my ‘89 and ‘88 don’t. ‘90 was a transitional model year, for example the knee panel courtesy light connectors changed and are the same as ‘91 on. -
Hi Jesse, heard of your accident a couple months ago, I was wondering where you had been. Glad to hear from you and hang in there, looks like a great bunch of people around you.
I don’t know but they all seem to have ‘97+ front ends.
To me it looks like the temperature sensor plug found in XJs. Aren’t fog light plugs weatherpack? -
Installed front AMC splash guards to match the rears. Mounted them behind the fender flares like the rears with custom brackets. Here's the DIY write up.
I never liked how the front splash guards attach to the MJ/XJ so I made a pair of brackets that will locate them behind the fender flares similar to the MJ rear set up. I made both from a single piece of 6”x18” 16g steel sheet (stainless would be nice) easily found at Home Depot, cut in half lengthwise. Thicker stock may be better but I have sliders and the splash guards touch them so there's no chance of the brackets bending. The left and right are mirror images and use the same template, the difference is the direction of the bends. I used a jig saw with a carbide blade to cut everything and a flap disc to smooth things out, then sanded any sharp edges. The brackets mount using the fender rear most attachment Torx bolt by inserting the bracket between the pinch seam and U-nut, a single hole drilled in the frame and screw secures the other end. The brackets have a slotted hole so they can be adjusted fore/aft as necessary. The splash guards then need trimming to fit the profile of the body and drilling for the brackets. I used MJ rears as templates to get the same radius for the outward section. A jig saw with a carbide blade made really nice cuts that were then kissed with a torch to finish them. For those of you squeamish at the thought of NOS AMC splash guards being butchered please look away. Here is the installed finished product. I opted for the splash guard in front of the bracket but behind “should” work. Bracket diagram (pdf attached) Brackets.pdf Disclaimer: Your measurements may vary; I suggest making a cardboard template to fine tune your fitment. If anyone uses this for commercial purposes, I ask you make a donation to ComancheClub.
1981 Coleman Maverick fold out camper.
fiatslug87 replied to coheed's topic in Member Projects: Other Cool Stuff
That will be a fun project. Congrats!!! -
Approximately 31” for the SWB bar.
280ZX Hood Vent Install
fiatslug87 replied to Comanche County's topic in MJ Tech: DIY Projects and Write-Ups
@Sugarfootdo you still have those AMC rear louvers? -
Did you put your grill upside down on purpose?
Anyone have this manual for sale? Looking for hard copy. 91 pages
fiatslug87 replied to Ωhm's topic in Wanted
I have a hard copy printed off the internet (single sided), free just pay postage. PM me if interested. -
December 2023 - The YouTube Comanche
fiatslug87 replied to 89 MJ's topic in Comanche of the Month (MJOTM)
Congrats! Love what you two do. -
All I want for Christmas is ...
fiatslug87 replied to NC Tom's topic in MJ Tech: Modification and Repairs
I assume you can. You can even cut off the bottom panel portion. -
https://comancheclub.com/topic/72872-compatibility-of-parts/
VIN Registry List: September 2026 Update
fiatslug87 replied to fiatslug87's topic in Comanche Registry (VIN decoding)
November 2023 update, see first post. 13 new additions this month for a total of 2226. -
For what it’s worth, wasn’t the OEM hidden winch only 6k or 8k?
Today is the Happy Camper’s one year anniversary of being here in California, it’s been a great year! Today I removed the propane storage box shelves so I could add a fire extinguisher and have enough room for the dual propane valves/hoses and the sink brackets. I also made a liner for the bottom from a piece of the other half of the bed mat that’s in the camper. Before (Ben’s pic): After:
…or at least cut off the zip tie tails!!!
I don’t have any first hand experience with the 12K winch from HF but a lot of people like it for the price point.
Squirrelly Dan: Coheed's 86 Custom
fiatslug87 replied to coheed's topic in Member Projects: Your Comanches
Very nice, can’t wait to see your progress on it. -
Comanche full exhaust options, sans header
fiatslug87 replied to knever3's topic in MJ Tech: Modification and Repairs
I’ve used exhaust band clamps and haven’t had any leaking, did they just use the u-bolt type of clamps? -
