8
Everything posted by fiatslug87
Jim's 88 Mj Pioneer, "the Beast"
fiatslug87 replied to thejim42's topic in Member Projects: Your Comanches
Welcome back! -
Emergency Brake Front or Rear?
fiatslug87 replied to 88 Cry-slr's topic in MJ Tech: Modification and Repairs
MJ e-brakes are at the rear wheels. A single cable goes from the pedal to a splitter bracket that the two rears attach to. -
My ‘90 had short, the ‘89 has long.
@Remim create a post in the Registry with VIN as the title to get the info. https://comancheclub.com/forum/32-1989/
Routing of factory antenna cable?
fiatslug87 replied to EUREKA's topic in MJ Tech: Modification and Repairs
In my ‘90 (original owner) that’s never been modified. Hole 4 in the center of the side panel to the left and up from the kick panel mounting hole is where the antenna cable enters the cab. and @Pete M the large connector courtesy light is also in the picture. -
years for courtesy lights?
fiatslug87 replied to Pete M's topic in MJ Tech: Modification and Repairs
Yup, my 88 and 89 have the smaller plugs and my 90 the larger ones. -
Hole #4, obviously you need a grommet and make a loop so it’s lower than the hole before it enters the cab. -
Yes, that’s correct, the change happened in 1990 models. -
60 MPH max speed?
fiatslug87 replied to Salvagedcircuit's topic in MJ Tech: Modification and Repairs
What rpm are you pulling at 60mph? What gear ratio do you have? What size tires are you running? -
CRL rear windows have been discontinued.
The circle of life; KeyParts is making some great stuff and others are discontinuing theirs. -
anyone having trouble with CC sending you email alerts?
fiatslug87 replied to Pete M's topic in The Pub
I never get emails -
1989 MJ Rear Step Bumper Hardware
fiatslug87 replied to AMCyaLater's topic in MJ Tech: Modification and Repairs
Thanks for the info and pictures. That’s a nice looking truck, is it in the registry? -
Lifted big block MJ - light bar, stacks and blower
fiatslug87 replied to GonzoTheGreat's topic in The Pub
That is awesome!!! The stock version: @Red Mistress check this out. -
Thanks for the pictures, if you could get a shot down the bed rail to the support I would really appreciate it. I want to see how it sits on the rail. That’s the 18” one, correct? -
That’s a really nice looking bumper. Do you know what brand bed rack that is? Looks like RCI. Can you please post a couple pictures of the attachment points, above the rail and the side rail? Thanks. -
I think it’s 45mm, I dug out the original but am guessing. But remember these may be slightly longer to accommodate the hitch and spacers. -
See if the diagram in post #7 helps. -
You can remove it or just leave it there. It just wraps around the exhaust manifold.
Door Card Hole Measurement Needed
Doesn’t the door itself have a hole where the upper handle mount goes? Can’t you mark off of that?
