If I get an external slave AX15 for my '88 MJ from a 93 XJ do I just need the different pilot bushing, matching t-case, new slave cylinder and throw out bearing? Do I need a different master cylinder?Anything else except t-case linkage?
Thanks
I remember seeing a thread on NAXJA many years ago also. I've tried finding it but have also been unsuccessful. I can still see the pictures in my mind.
The emission/vac diagram on the firewall stated conforms to California emissions requirements for 1988 model year and the diagram stated 173 cubic inch engine and showed a carburetor. I should have snapped a pic of it and the VIN.
O. K., I was at the Pick 'n Pull last weekend and saw a 1988 Cherokee with a 173 ci carbureted V6, straight from the vac diagram sticker. I did not think the 2.8 L (I assume) used past '86 or '87, when was it discontinued? Thanks.
The easiest thing is to find an XJ with fogs, pull the entire front light harness (which contains the relay) and switch and use those. The rest of the wiring for the switch is already there and they will turn off when the highs come on.
Harness looks like this:
It disconnects at the 10 pin connector right by the air box and the relay attaches to the hole in the upper left in the picture.
I was thinking of getting a hidden antenna and remove mine, so was wondering if an OEM plug existed. I can easily make something but would like it to look stock.
