Gojira94
Everything posted by Gojira94
  1. You might want to step back for a minute and make a troubleshooting chart through fuel and spark. I don't have a stock pre-1991 rail to look at but if yours has a Schrader valve go ahead and see if you get fuel to the raIl and what the pressure is. Double check fuel pump ground, fuel pump ballast resistor, relay, etc. if not. See if you get spark from the coil wire during cranking. If you have good fuel pressure and spark but still no start- get going through the sensors testing guides on this site and Cruiser 54's site. At the very least so far, you've discovered and corrected an unsafe fuel condition you didn't know about beforehand. You'll get it!
  2. Upside down pic, but here's mine. It's not in the corner, now that I'm looking at it, my bad. That raised hole should be there, though some aftermarket tanks may not have it, I suppose.
  3. I have no use for any of it, except maybe the headrest-equipped bench seat, but this showed up at the LKQ near me. 2.5l engine with AX-15... *E1: Cloth Bench Seat; -D5: MEDIUM QUARTZ; 167: Zone 67-Charlotte; 1AA: U.S. Dealer Retail; 21B: Customer Preferred Package 21B; 2TB: Customer Preferred Package 2TB; 3VD: Customer Preferred Discount; 44H: T-300/AN Allocation Tracking; 4RT: Southern Discount Promotion; 4XH: Power Windows Bypass; 634: North Carolina State ; 934: North Carolina State ; AGG: DO NOT USE - SE application; APA: Monotone Paint; BAU: 117 Amp Alternator; BCE: 600 Amp Maintenance Free Battery; BGJ: Pwr Disc/Drum Rr Anti-Lock Brakes; BKE: 9x2.5 HD Rear Drum Brakes; CBA: Straight Back Bench Seat; CBW: Highline Door Trim Panel; CDE: DO NOT USE - See JWF in C6 Class; CGT: Driver Air Bag Only; CKE: Front Seat Area Carpet; DBB: All Manual Transmissions; DDQ: 5-Speed Manual Transmission; DMD: 3.55 Rear Axle Ratio; DRA: Corporate 8.25 Rear Axle; EAA: All Engines; EPE: Engine - 2.5L Power Tech I-4 Cyl.; GAC: Tinted Glass Windows; GBB: Tinted Windshield Glass; GCB: Front Door Tinted Glass; GNA: Rear View Day/Night Mirror; GRU: Left Manual Mirror; GSU: Right Manual Mirror; GTU: Open; GVA: All Vehicles W/O Power Mirrors; HAA: Air Conditioning; JAZ: DO NOT USE - See JP, KA classes; JCK: 110 MPH Primary Speedometer; JHA: Var Intermittent Windshield Wipers; JJA: Cigar Lighter; JKA: Locking Glove Box; KKE: No Description Available; KSE: GOLD METALLIC - DIMENSIONAL GRAPHIC; KTX: STRIPE/BADGE/MOLDING/COLOR; LAP: Shift Indicator Warning Lamp; LMB: Halogen Headlamps; LPS: CHMSL Lamp; MBA: Painted Front Bumper; MBD: Argent Rear Bumper; MDA: Front License Plate Bracket; MFN: Grille-Body Color; MHA: Black Windshield Moldings; NAA: Federal Emissions; NBK: EVAP Control System; NFS: 15.3 Gallon Fuel Tank; PR4: Flame Red Clear Coat; QR4: Flame Red Clear Coat; RAA: All Radio Equipped Vehicles; RAS: AM/FM Cassette Radio; RCD: 4 Speakers; RDD: Fixed Long Mast Antenna; SBA: Power Rack and Pinion Steering; SCD: Luxury Steering Wheel; SFA: Standard Duty Shock Absorbers; SGA: Rear Shock Absorbers; TBB: Full Size Spare Tire; TBM: Tire Carrier Winch; TME: 215/65R16 LBL All Season Tires; TZA: Goodyear Brand Tires; WJT: 15X6.0 Aluminum Wheels; WLZ: All Aluminum Wheels; XBS: Pickup Box; YAA: Build To U.S. Mkt. Specifications; YGE: 5 Additional Gallons of Gas; Z1A: GVW/Payload Rating; ZAC: Spring - Left Front; ZDR: Spring - Left Rear; ZNB: Spring - Right Front; ZSR: Spring - Right Rear
  4. Facing the hole in the tank, the float goes to the left in the ‘basin’ in the bottom of the tank and the rubber foot on the return pipe goes in the hole at the right corner of that basin. Shine a light in one vent hole and eyeball it through the other to get it seated. A very light smear of Vaseline on the o-ring and back side of the lock ring helps get that seated once the sending unit is in place.
  5. because regular ‘fuel line’ is only good for low pressure fuel delivery < 20psi and our trucks make 39psi. FI hose is rated for a lot higher than our pressure but better safe than leaky.
  6. The rollover valves serve 2 functions: 1) they prevent fuel flow out of the tank into the evaporative emission lines and toward the engine in the event of a vehicle rollover; 2) their 'normal' job to allow fuel vapors to get to the canister when the fuel temperature rises and the fuel vapor content of the tank needs a place to go. The valves aren't expensive and Dorman makes a replacement. Mine were ok after 35 years. I cleaned them off and blew them out gently. Flipped them upside down and blew through them and no flow. The grommets are not hard to find either. 7/32" emissions hose (1 bar rating) is what you want to replace the lines. Available at most parts stores by the foot. You won't need clamps on the lines to the valves, they're not going to go anywhere. You'll notice on the tank there is a recess around both valves. You can run new lines, the idea is to route them away from the tank in a way they don't get pinched with the tank secured. The front one can go toward the outboard side of the vehicle and come around the front of the tank. The rear one can drop inboard toward the driveshaft and then forward from there. Use a T junction to join both lines into one. Then the single line from the two joins the fuel feed and return lines' routing. There is a small plastic loop attached to the bottom of the bed from the factory that holds that line secure just above the front strap hole. That may be gone, just zip tie the line somewhere secure and up away from harm. Filler hoses are hard to find but it seems XJ hoses can be modified to serve the purpose. Dorman also makes the straps - Dorman 578-054, about $40-$45 on Amazon, etc. The j-bolts probably will clean up. I went to town with a wire brush on my filler neck, taped over the ends and hit it with engine enamel and then baked it with a heat gun to preserve it. 18 gallon tanks are easy to find, I think you already know about the MTS pump/sending units if you need one of those. Lock ring/ o-ring kit is same as GM stuff. If you replace the soft fuel lines from tank to hard lines, get fuel injection hose and use fuel injection clamps, not worm clamps, obviously. Sorry I'm not closer, I'd be happy to come help if I was!
  7. Since I'm not installing a winch (at least for now), I wanted some kind of plate to put on the front bumper. Front tags aren't issued/ required here in NC, so we can put whatever we want on the front. I looked for something with the AMC and/ or Comanche logo but kinda came up dry in that regard. Then I saw this plate and thought "why not?" Before anybody says 'cultural appropriation' let me say this- AMC, Daimler/Chrysler have borrowed the names of 2 Nations and never thought to pay a dime to either; it wasn't in the national consciousness then. I think it's entirely appropriate to give a nod to the people whose name was borrowed to give the MJ a name badge. It is what it is with these vehicles, we can't go back and pretend the SJ/XJ/KJ/KK/KL/MJ/ZJ/WJ/WK/WL are called something else, but sometimes a simple acknowledgement, at least, is called for. If when my rig becomes conversation-worthy, as these vehicles inevitably are, I wouldn't mind if someone thinks for a moment of the Comanche Nation and wonders how they're doing today. My mom's side has Cherokee (and African) in it, not uncommon in the southeast US. I'm not calling for any measures you see discussed in the news these days, but it might be nice for the Daimler automotive group to move on to other names for the remaining 2 platforms. I'm not choosing people vs. automobiles, I'm embracing both.
  8. Finally had another XJ show up in the local yard last week. I scored a pair of bumper guards for $20- not perfect but very decent condition and cleaned up nicely. New ones are > $50/pair. I'm in a transient period of limited funding for this project so I'm picking off inexpensive odds and ends and doing mostly labor tasks for now. Also grabbed the underhood light. It's the 2-wire later version. I'll either ground it on the underside of the hood next to the light like early ones or ground it at the fender wall with the relocated blower motor ground. It has a mercury switch in it. I broke it all the way down to clean and test, and then reassembled it.
  9. I might have, but the only XJ (98) I'd seen in the local yard in ages had a broken tank, and I wanted to explore other options available while I was there.
  10. Ignition coil resistance test and specs: Primary winding test is ohms resistance between the bottom 2 round posts. Secondary winding test is ohms resistance between either bottom round post and coil output (top). 87-90 2.5l and 4.0l both use the same coil (and ICM, btw). The 1990 FSM, on p.8D-17 states: primary should be 0.4 - 0.8 ohms secondary should be 2500 - 4000 ohms. On an auto-ranging digital multimeter like my Fluke 87, secondary will read as 2.5 - 4.0 k (thousand) ohms. Non auto-ranging meters will need to be set to k ohms range for secondary, 0 - 40/ 0 - 400 ohms for primary. My coil in the pic above tested 0.9 - 1.0 ohms primary, 5.68 k ohms secondary, too much in both windings (NFG). Testing the ICM is difficult without the factory DRB II. About all you can do is verify reference 5V ECU voltage going to it, and its ground. If I find more helpful info on testing the ICM, I'll update this post.
  11. Since I've done the 96 XJ brake booster upgrade, I wanted to explore options for the washer tank, other than moving the old tank forward or going with the later style inside the fender. I started looking at the late 80s - early 90s Dodge Dakota, ZJ, WJ and nothing I thought to look at fit the bill. Then I stumbled across a 2002 Crown Vic/ Mercury Grand Marquis. The fit is almost as perfect as could be asked for. The downsides: 1) the wiring and washer fluid line will have to be extended; 2) the fuel pump ballast resistor will have to be relocated, probably to the area where the old tank was; 3) electric fan and fog lamps relay mounting points need to move; 4) EGR purge solenoid would have to move. My rig never had options for issue #3, I was going to put those somewhere else anyway. I'm deleting #4 due to the fact that I'm missing everything except that solenoid and it was for a 2.5l engine anyway (may be the same, don't know/care). There's plenty of room for the front lighting and engine harness to pass between the bottle and the air cleaner, more than you can tell by the pics below. The air box in the pics is from a 96 XJ that had the short inlet aperture and a block off plate in front of it. I'll be adding a hole to the back of the lid to accept the canister purge line when it all goes back together.
  12. 1st one is C115, all having to do with auto trans control. Tape it up out of the way. I ran into this one early on when I bought my rig. Second one I've seen but can't recall what it is. C115 BLK/YEL pin H - TCU fuse to auto trans gear selector switch and power/comfort switch TAN pin J - power input signal between TCU and power/comfort switch LT BLU w/TR pin K - power/comfort switch ground from G102
  13. I gotta get my rig running so I can quit talking and guessing about these problems and start enjoying them myself.
  14. Heater circuits do indeed burn out but I don't think that's going to be your problem. For an 89 3-wire sensor I want to say red and black are the heater and grey is the 0-5V signal. I think the 89 electrical manual is around here somewhere, but should be the same as 88 & 87 and I know I've seen those manuals here. Cold weather and injector faults at cold start - not to send you down a rabbit hole, but it suggests to me a slim possibility of moisture in the fuel, especially if you're running any ethanol blend these days. Not to rant (again) about wishing to see the contents of the factory Renix calibrations, but I'd like to see if there is a cold start enrichment and corresponding stall saver IAC routine in there. IAC, TPS closed throttle, and idle screw relationship can jerk that cold start routine around if they're out of sync. The fact that your problem goes away when warm would suggest to me it's not sensors, since those would be out of the equation before closed loop. I have an IAC tester for the old GM pintle style IACs but you can test it manually with a lawn tractor battery and a couple 14 gauge wires. You can run the pintle off the gear with the GM IACs of old, not sure about our Renix system IACs. Wouldn't hurt to just pull it and clean it with electronics cleaner to be on the safe side, make sure it isn't trying to move and getting stuck from buildup that acts worse when cold.
  15. We have THREE Volvos... 2005 V50 2.4i - wife found for oldest daughter's first car; I did timing belt service kit, struts/ upper bearings, oil breather/PCV unit, tires, interior leather recondition, engine mounts, rear sway bar links, overhead interior lights unit, vanity lamps wiring repair. It has the exterior fuel pump control module, that went a few months ago; found one at LKQ for 29.00. Good car, reliable. 2008 V50 T5 - I found this one on Craigslist with a broken t-belt; 110k miles. Got it for 1,100.00 Guy and his mother went to Sweden and bought it and had it shipped back (that was a thing apparently, then). 530.00 for head work including all new valves/ guides/ seats/ light resurface/ pressure test. Pistons that got hit only had light kisses. 155.00 top end bolt & gasket kit. Tow was like 125.00. I recall that for < 2000.00 all in minus tires, it was back on the road. I did an interior restoration so it would be perfect and prepared to put a sign on it for 6500.00... until my oldest daughter saw it and wanted it. Since my middle daughter now also needed a car, I gave her (oldest) this one and middle kid got the 2005 2.4i. 2010 XC70 - wife's car. She calls it "Sharky" because of the fin antenna. bought at private sale for 11,000.00 with 62k miles on the clock. She's driven through 2 additional sets of tires and 2 all-around sets of brakes. Ironic my first car was a '74 Volvo wagon (thanks ma!). Now I'm maintaining 3 Swedish wagons lolol. The 2008-12 P1 (C30, C70, S40, V50) platform shares the turbo B5254T7 that's in your model year S60. Very fun engine. Your S60 is a beauty. I've always wanted a white car, never had one lol. The 80 is top notch classy. My compliments.
  16. The horn contact ring has 2 nubs on it that work the 2 plastic plates that rotate against each other that make all the clicking inside you hear when signalling/ turning. There are tension springs wedged in those plastic plates that can break or fall out. That's problem #1. Problem #2 may be caused by bits of problem #1 interfering with the leverage point at the stalk. You'll have to get in there to determine how far both issues go. All of it is pretty well available GM stuff. The writeup in a post above has all the pics and details of how to get it apart:
  17. Actual fuel weights (tank not included), for the curious: 16 gallons of .740 specific gravity pump gas= 98.568 lbs. 18 gallons of .740 specific gravity pump gas= 113.96925 lbs. 23.5 gallons of .740 specific gravity pump gas= 144.7718 lbs.
  18. One sanity check suggestion, flip the rear wheels. Tire inflation and treadwear might ought to be eliminated. Or if you prefer the jackass answer (I'm good for those) put 180 pounds in the driver's seat and measure again (just joking there but ideas are ideas). EDIT: If it didn't have a cap on it I'd say get in the back and bounce the hell out of it with a couple grown dudes. Otherwise maybe load it with another 200# of stuff and do some speed bumps at low speed to get the leafs to settle and see how it looks in a week or two. If you have concerns, alert the vendor NOW and follow up after settling can occur.
  19. My door panels were already blemished where a PO used drywall screws to mount 5.5" speakers so I expanded the holes a tad and went with Sony XS-R1646 6.5" 4 way speakers. Found rear speaker mounts and am putting Sony XS-R4646 4"x6" 4 way speakers in the back with bass blockers at 300Hz for cleanliness/ distortion blocking. Completing the trifecta with a Sony DSXA415BT ("Digital Media Audio Receiver with Bluetooth & Satellite Radio"). I wanted decent sized door speakers for that big mid-range punch, a lot of bass not so much. I used 4 of the Sony Walmart 4x6 speakers and a Dual TBX10A powered sub in my '92 C1500 a while back and have been very pleased with a system that cost a hair over 200.00 USD 3 years ago. Sturgill Simpson's 'Ronin' and 'Remember to Breathe' sound AMAZING through that setup cast over Bluetooth, even with the cheap Dual head unit. But that's a much larger extended full size Chevy cab... If you need speaker options that fit like factory in the doors, get the best quality 5.25" you can for that midrange/ top of bass range, add 4x6 in the rear with 300Hz bass blockers and see how you like it before bothering with a sub in the small cab of an MJ. As stated earlier, you can always add an 8" under the seat sub later. Crutchfield sells head unit u-wire-it to the head unit adapters to plug aftermarket into the factory harness so you don't have to cut up the dash harness. They also sell front and rear factory speaker connector to speaker wiring for a clean install.
  20. I've lusted after many more than I've had... Had/ gone now: 1974 Volvo DL145 wagon 1982 Chevy Malibu wagon (V8 donut-mobile) 1981 Volkswagen Rabbit 5-door diesel (manual) 1984 Toyota Corolla hatch (damn I miss that car) 1987 Honda Accord DX hatch (great f'n car) 1993 Pontiac Firebird base (L32 V6 auto) 1988 Buick Skyhawk Custom 2-dr notch (2.0 OHC I4 auto) Still have: 2003 Honda Accord EX manual (my daily, owned since new, 320k miles) 1994 Firebird Formula M6 (looks stock, highly modified, 443FWHP, 77k miles) 1992 Chevy C1500 (412FWHP highly modified TBI build) 2008 Volvo V50 T5 (oldest daughter's car, 237HP, rebuilt Craigslist basket case, 110k miles) 1987 Jeep Comanche (current project)
  21. But I've also got the C punched out... And there's 1 in the grid section. Could be the C stands for March, which would be the correct month, if the 1 stands for 1st half of the year, with a 2 possibly indicating the 9th month on another truck. And production beginning in 86 (G). And maybe the grid wasn't used and it didn't matter where the 1 or 2 got punched. Except Classy Comanche's pic shoots all this down. I've got 2 diamond punches and a 1, he's just got 2x E. And my plate doesn't seem to dovetail to any of these paint/ body codes specific to my truck: APA MONOTONE PAINT PACKAGE PE4 Colorado Red QE4 Colorado Red Body code TL61 So the A-P is a 16 character sequence and the grid is 6 grouped but separated characters, and not sequential. Maybe they're chassis/ drivetrain option designations assigned to the body, designed to be read from the bottom of the body hanging overhead on the assembly line, I don't know... whatever it is it was installed prior to paint.
  22. I'll start- Probably a good idea to post saved pics instead of links for posterity, since you know the internet is ephemeral. 1969 Ford Galaxie 500 Coupe VIN # 9N60Y148826, LKQ Raleigh/ Clayton, NC 02/27/2023
  23. I bought a bent one on Fleabay for $40 and had a local fab shop straighten/ brace weld it for me for $20. It was hell finding one in any condition for less than the crazy prices mentioned above.
  24. I inquired about this a while back, nothing came of it. Mine was at the junction of front lower edge of left sender and sub-brace behind the headlight.
