Gojira94
Everything posted by Gojira94
  1. I needed to get into my wiper cowl to see what's going on with the wiper transmission (really, really loose). The arm release tabs were so badly corroded I had to cut apart the old arms to get them off. I see that generally the Cherokee lists compatible arms from 84-96 and 97-01. Did they change the wiper transmission mounting stud size for the arms in 97? Anyone ever try transplanting a 97-01 wiper trans, motor and arms into an MJ?
  2. I can go to my local pack & ship and send them off to you. You can pay whatever that is via PayPal. Obviously I’d do the cheapest option to ship. PM me with an address and I’ll get em cleaned up and on the way.
  3. 2 sets of (5) wheels like yours down here, too. One set 17" and another 18" though I can't speak to the PCD or backspace measurements without knowing what they came off of. https://raleigh.craigslist.org/pts/d/raleigh-jeep-rims-like-new/7514112043.html https://raleigh.craigslist.org/pts/d/raleigh-jeep-rims-18s/7505138193.html and this radio with lower dash speakers has been listed for at least a month for $10.00 https://raleigh.craigslist.org/pts/d/cary-oem-jeep-am-fm-radio-cd-player/7489295750.html
  4. Craigslist spot, posted July 25, 2022: https://raleigh.craigslist.org/cto/d/franklinton-89-jeep-comanche/7513275900.html Front end damage, somewhat repaired. Says "manual" and rear tailgate says 4.0 but you never know. For $600 I'd hit it if I wasn't already a$$ deep in my current MJ project.
  5. Oakland county, Michigan? No idea. It’s 2 sections, maybe 15-18 lbs. USPS or FedEx home delivery would be 3-4 days, probably. Wild guess in the neighborhood of $40-45? If you’re serious I’ll clean it up, separate it and see what packing and shipping would cost if you really would like to have it.
  6. I'm going to sell the 2.5 and AX-5 for local pickup if anyone within driving distance might want them. Selling as cores since I've not run either. Will post in for sale section after I get a couple pics.
  7. About done working through the engine bay wiring. Ignoring/ working around the 2.5 that sits there at the moment. Sorted and loomed all the strays on the passenger side, repaired the orange wire from the fuel pump ballast resistor at the starter relay. Pulling and cleaning everything as I go, down to the engine bay sheet metal. Now that the wiring on this starter relay is repaired and verified, I'll pull it and clean it and its wire leads. Cleaning the wires themselves takes the mystery out of wire colors and helps to spot chafed wires looking to start fires.
  8. Interior panels all cleaned and reconditioned as well as possible. Dome lights are Euramtecs. Old ones were dust held together with electrical tape. Still have to pull and condition the driver's door panel and drop the dash to clean it and under it. Considering shaving down the cracked portion and doing a vinyl over foam layer or something. Worst case a carpet dash pad... All 4 crappy aftermarket fog lights ("Blazer!!") pulled off, all associated wiring cleaned from factory harnesses, repairs made where needed. Hacked in 4 flat trailer lights connector also gone, repaired and split loomed the plate lights and rear lamps harness. All factory connectors in the dash restored to factory. Procured a correct clock. Added ash tray light, courtesy lamps/ brackets for them. Sony head unit, 6.5" door speakers, 4x6 rear speakers acquired. Using Metra modular connectors so as not to hack up the factory harnesses again. Cargo lamp and dome lights wiring will be modified cleanly with spade connectors, best course at this point.
  9. 4WD shift linkage from a 96 XJ; cleaned and painted. Plus the plate for the trans side. Think I goofed since I now know the trans side plate is for an auto. Think I changed my mind anyway and am going with stouter linkage between the factory handle and TC: https://www.boostwerksengineering.com/231-HD-Shift-Linkage-Manual-Trans-V20_p_29.html Also pulled a 2 lamp harness piece from the shift console of that 96 XJ. One lamp for the transfer case position indicator, plus an extra for something else (96 XJ was an auto).
  10. A little progress made. In trying to figure out what year the 4.0 harness and computer came from, I've determined it's from an 89-90. It has the B+ latch relay feed pin in pin 12 on the diagnostic connector instead of 5 like an 87-88 would have. Front lights harness repaired and cleaned up. Missing the passenger side horn... Floor panels arrived, looks like the fit will be good. Haven't started cutting anything out yet. It'll need an extra patch on the driver's side behind the clutch pedal. May be able to use a leftover piece of the rear portion of the new floor pan.
  11. I'm finding I have no appetite for doing the floor pan work. For lack of a welding rig of any sort, and the time that's passed since I last tried to weld sheet metal, I'm thinking I'd rather pay somebody to do it properly. Local fab outfit does on-site work, quoted me about 250-300, which I can live with. Been cleaning up all the dash parts that show, stripped down the column, cleaned and lubed the ign switch and high beam rods. Also installed a new key cylinder. Will have to do the door locks as well. It came with no keys at all but it does have a title lol. All dash wiring labelled and accounted for, ordered ctsy lights/ brackets from an Ebayer who's a member on here as well, and a clock (didn't come with either). Repaired the hacked radio wiring and ordered speaker connectors for the doors and cab corners. I did a Dual AV head unit, TBX10A sub and Sony Walmart speakers in my 92 C1500, like the way it came out for the price, so I'm going to do the same for this MJ, minus the sub. And a stock radio can go right back in with no wiring hackery in the future if ever needed/ wanted. Harness to speaker connections and the radio harness to aftermarket are Metra, from Crutchfield. Main dash is ready to pull so I can clean up under it and get into the HVAC box and clean it out, too.
  12. Pulled the interior to see how bad the floor pans are. This one had a vinyl floor liner over jute padding with fiberglass matting along the exhaust route on the passenger side. Passenger side, there's a big hole by the rocker just behind this (where did that pic go?) Driver's side - holy crap... look how far it goes up toward the firewall.
  13. Craigslist find in Raleigh, NC. POs were trying to take 2 MJs and make 1 good one. Originally a 2.5l / AX-4 / 2WD. At some point in the past a 4.0 swap was started but didn't get far. The engine and engine control harnesses were swapped, along with a Renix 429 ECM. That seems to be as far as they got. Currently has an early era 2.5l bolted to the mounts with an AX-5 behind it. The 2.5 I say must be early era because it has provisions for a mechanical fuel pump on the passenger side of the block. It does have a single popper TBI intake on it right now. I briefly considered pulling the 2.5, light hone & rings, recondition the head, fix all the leaks. But to have any fun at all with it, I'd need to invest in converting the AX-5 to 4WD and end up with a weak combo not capable of doing much more than pulling itself up a steep hill. Plan: 1) complete 95-99 drivetrain swap and run it on the Renix ECM. 2) (re)build fuel system, kind of suspect at the moment 2) acquire HP 3.55 Dana 30 front axle Goal: light duty factory-ish (to start) good, reliable runner 4WD for climbing/ hiking access roads on trips in western NC/ beyond. Shopping list: 1) complete 4.0l / AX15 / NP231 drivetrain (acquired 93 YJ 4.0/AX15/NP231 July 2022) 2) late HP Dana 30 from an XJ, front shaft 3) figure out rear DS length, cut & balance old one or have a new one made
  14. I found a logo on one end that says VDP. I googled them and apparently they still make stuff and sell through NAPA, maybe some others. "Vertically Driven Products" wheel well storage. So not an 'uncommonly surviving vintage dealer accessory.' If it was, I'd have sold it here for basically shipping cost, lol. Still would if anybody wanted it. I'll probably just put it up for $10 on the local craigslist. https://icreativesandbox.com/dev/vdp/product/wheel-well-storage/
  15. This was mounted in the bed, passenger side rail when I bought my MJ project. Over-the wheel hump 2-section cooler/ box whatever. It has a drain hole at each end, so I'm obviously thinking cooler. I absolutely have no desire to keep it, whatsoever. Before I throw it on the local craigslist, I wanted to get some input as to whether this was made specially for MJs, or random crap somebody put in it... Keys are long gone but it's not locked and the locks can be changed out. That nasty roll of rubber mat is unrelated...
  16. Ok, so found a couple things where I wasn't looking, auto trans related (I'm manual). C115 is as follows, for both 2.5 and 4.0 setups with 4-speed auto trans: BLK/YEL pin H looks to be from TCU fuse to auto trans gear selector switch and power/comfort switch TAN pin J appears to be power input signal between TCU and power/comfort switch LT BLU w/TR pin K appears to be power/comfort switch ground from G102 C260 is: LT BLU W/TR pin A is cruise/ trans switch to TCU for interrupt cruise and torque converter unlock logic BLK pin B shares ground with C115 at G102. So both of these are auto trans related and won't ever be relevant to me. lol...
  17. Edit: I located the 87 electrical manual (thanks FiatSlug87), so the the 2nd connector numbers below are different between 87-88) https://drive.google.com/file/d/1XBkojfjOdkg7X9ittvYaL0bRUj6qKc0G/view I'll be doing a separate build thread on this basket case 87 MJ, but I have a couple questions as to where 2 connectors go. I've been going through all the wiring from firewall back and pulling out all sorts of other peoples' "great ideas" to get back to stock wiring. I'll make my own choices on what to add without hacking up the factory harnesses, with a more modular approach. Connector #1: C115 - "ECU to Instrument Panel" on p.77 (2.5) and p.80 (4.0) of the '87 electrical manual, as part of the "Engine Control Harness" diagram and "EEC to I/P" in the inline connector views on p.60. Where does this connect/ what does it connect to? I've been through the 88 electrical manual linked here (and now the 87 electrical manual as well). That answered everything else on I found going through the dash. C115 is pictured in a couple pages of exploded diagrams toward the end but no answer as to what it plugs to and where that is. I'd like the wire color/ pinout as well. Connector #2: I think it's C251 Cruise control clutch C260 Cruise Control Dump Valve Switch. The brake switch at C250 C249 is there on the brake pedal lever, connected. If there was a clutch switch on the stamped steel bracket 1/2" aft of the clutch pedal lever, it's gone now. If it had one, it would function (edit): possibly as 1) a clutch start switch and 2) cruise interrupt. Did these things from 1987 even have a clutch start/ neutral safety switch? (edit): Looking at the starter diagrams on p.14 it doesn't look appear so. This MJ doesn't have cruise, so I think I can tuck it away until I get sick of not having cruise and collect everything to add it lol. Thanks!
