Everything posted by White_Comanche
I'd say that's a justified purchase! Probably one of the straightest Comanches I've seen. It's been in good hands all these years. The trim level and color is unique.
1JTHL65F5GT131063 (&) 1JTHL65F6GT131063 'Big Ton'
White_Comanche replied to White_Comanche's topic in 1986
The Treasury office where I'm at had never dealt with this before, not the clerk or the Trooper I was working with. After a few weeks into the process the clerk showed me the title snapshot with many different colored sticky notes stuck to it. It was almost laughable. The course of action ultimately came from Topeka (KS capital). I'm led to believe it was the path of least resistance. I was informed that it "wasn't possible" to update the vehicle info in KS databases. Yeah right. -
There may not be a problem with accurate reading after all. Today I reinforced the ground, using the 8mm stud by the parking brake. Testing with a multimeter before and after gave the same results on both grounds. Continuity read 3.7 at the lowest. A friend thought I might have a 195° thermostat installed without my knowledge. He might be right because I've only owned my MJ for 1 year. After driving around I used an IR thermometer. The upper radiator hose was 183° and the thermostat housing was 193°. Temp gauge showed the same results with it reading about 195° IMPROVED GROUND
Thank you Cruiser. Will do tomorrow, result will be posted.
Ok, I see. Got that 110 by dividing 220 in half. I had a blind eye and didn't actually read the hotter numbers and their corresponding marks. Anyway Ωhm, this gauge suddenly worked differently after my "Intermittent Turn Signal" thread. You helped me out during that which involved removing the instrument cluster. Before that project it commonly read around the 220° mark. Now it won't go above 195° in the picture... except when shutting the engine off, and then it creeps up +1 mark. Surely the engine is running hotter than this? This seems way too cool.
RELATED TO THIS TOPIC Rather than creating a brand new temp gauge topic I'm hoping to get an answer on my own gauge issue. Below is a picture of my gauge with the engine at operating temp (upper radiator hose was hot). Just replaced my temp sender today and got no improvement. However, it was a STANDARD #TS-268 rather than the Mopar part indicated way above this thread. Here's some testing that I just did: • Grounded Sending Unit wire and the gauge pegged all the way to the right (key ON) • Disconnected the ground from the sending unit wire and the needle went full cold • 11.9V gets to the sending unit connector • With engine back at operating temp I measured resistance with CTS disconnected... got 165 ohm with the needle at this position: • Needle never goes above this 110° mark
Flipping sweet! Thanks for the clarification. Up until this point I've made only some quick armchair research on the matter. Glad to here this from a Comanche Club admin. -
Yep, that's a AMC 20 axle. Word on the internet says that it's a weak design. I don't know what to believe, but I know the one on this truck hasn't broke yet. -
1986 Jeep Comanche • 2.5L TBI • 5-Speed • 4x4 • Big Ton • AMC 20 Rear Axle • Long Bed My Comanche must have been made on a Friday, because there's two different VINs present. This truck has been flying under the radar since it landed on the shores of Kansas way back in 86. When it was due for insurance renewal I noticed inconsistencies across the board. After a full month of rigamarole, a patient Highway Patrolman got this truck on the straight-and-narrow with the state of Kansas. Back in the day this truck was driven all around checking oil wells on rough limestone country roads. 2nd owner used it like a truck, but had it garaged for the 20 years he had it. Under its current owner she remains garaged, and is slowly being taken to its next level. I personally go with the dash VIN, but Kansas has the engine bay VIN as their favorite When looking closely, another VIN plate is riveted underneath A full month of leg work, and all I got was this sticker: The previous owner got the seat reupholstered Redlinegoods.com made this custom shift boot. It looks great, but their stock Comanche sewing template is too long. In the future I may reorder this boot with 2 or 3 inches of height removed. In the shop for a much needed transmission overhaul A full-size spare snugs right in to replace the old doughnut 157,500 miles on this 2.5L
Step Side MJ?!
White_Comanche replied to jpnjake's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Gross, that Ranger bed is real cringe to look at... -
random informative picture thread
White_Comanche replied to maddzz1's topic in MJ Tech: DIY Projects and Write-Ups
'Continuous' photography lighting makes an excellent alternative to the usual worklights on the market. This fixture has 3 switches controlling 5 fluorescent bulbs… 1 switch controls 1 bulb, the 2nd turns on 2 bulbs, and the 3rd illuminates the remaining. This way you can control your light output. As you can see, there's no harsh shadows, large area is lit up very evenly. Plus, everything is so CLEAR. I bought this online at B&H Photo Video. Manufacturer is FOVITEC. Sometimes they can be bought in pairs, I got my single light for only $80. I’ve used it in a very hot garage, and even after hours of every bulb being 'ON' the diffuser shroud only gets slightly warm. Overall the build quality is “pretty good” for the price. The tripod is sturdy and height adjustable. The tent/light fixture is balanced. So it won’t topple over even if you extend it really high. -
I recognize this exact vehicle from earlier this year. The original owner was trying to get rid of it on a local classifieds site. I asked if I could buy only the blue center console, but it wasn't the correct shade. Afterwards I mentioned he list it on Comanche Club. Keep us posted on here, probably a cool lite truck after some care and parts.
Yes, it's a nice looking truck. However, I see its been sprayed all over with that cherry red. The over-spray can be seen on the door pin and the firewall. Plus, I gotta chuckle from the gloss that was sprayed thick in the engine bay Also looks to be on the tires too! I'd like to have a clean truck, but I very much dig the weathered and well-used look of many Comanches all around this site.
I'm the same boat you're in. I bought my 86 Comanche late last year and I didn't know jack. The guys on here are extremely helpful and I've been learning a lot. I find working on my MJ incredibly enjoyable. You might be pulling your hair out from time to time, but you're also learning too. Overall it looks like a nice clean truck. Like the red/black interior. Seeing a few exterior shots showing the whole vehicle will be cool...
Sweet moonroof bad Comanche too
ideas for taillight removal
White_Comanche replied to Pete M's topic in MJ Tech: Modification and Repairs
I see that you successfully got the screws out. Just wanted to add a method that might not be commonly known. Century Drill makes damaged screw removers and extractors. -
A few weekends ago I successfully reinstalled my instrument cluster. Much time was spent cleaning up the cluster as a whole. All new light bulbs were installed. I did repeated continuity tests on all electrical paths on the laminated circuit board until I was satisfied everything worked. Note: for anyone who has not removed/installed their instrument cluster I discovered the unit can slide back in much easier by removing its clear plastic 'lens'. It creates an extra 2 or 3mm of needed clearance. Also, removing the digital clock and cigarette lighter makes re-connecting the speedometer cable a breeze. During all of this I made sure both of the electrical connectors were properly seated into the cluster housing. I wanted to ensure all four clips were actually fully clipped in. When removing the cluster I may have noticed my C203 connector was not positively seated down in the first place. I'm happy to report that my left turn signal indicator light now WORKS! I'm cautiously leaning towards this issue is now fixed. If this reoccurs in the future I think there's only one other thing it could be. Big thanks to everyone who has helped me work through this.
Nice tires! Have not seen a Comanche at factory height with such large ones. At first thought the black wheels we're playing tricks on my eyes... pretty rad
I think you, and the others have given me great help to figure this issue out. Greatly appreciate you taking the time to consider it all, and explaining the testing procedure in a way that I could get it done. Highly doubt I would have got as far as I did without it. I'm gonna go ahead and assemble everything back together soon. Earlier in this thread I briefly mentioned that my C203 didn't seem positively seated when I was taking the cluster out in the first place. I remember the top-most squeeze clip seemed almost unclipped when shining a flashlight on it. If my suspensions are correct, after I get everything back together, proper pressure will always now be applied to the C203_10 & C203_11 (which are at the top of the connector)... and against the laminated circuit board.
Ωhm, Following up with the testing to diagnose my intermittent left turn signal bulb. I purchased a manual multimeter for testing — Performance Tool #W2974. Not a professional model, but it was affordable. TEST 1 C156_H ├———————————————┤C203_11 Disconnect C156. Disconnect C203. Check for continuity between these two points (GRY/BLK) on the IP Harness side. • Result: Continuity was strong, with a loud beep, 0.0 showed on multimeter. TEST 2 Connect C156. With C203 disconnected measure for voltage between C203_10(BLK) and C203_11(GRY/BLK) with KEY ON and Left Turn Signal ON. Looking for 12vdc_0vdc_12vdc_ect_ect. Try and select a 20vdc range on your DVOM. In other words, auto ranging OFF. • Result: Voltage maxed out on the display at 8.99V. A friend suggested that I use a circuit tester for a visual aid in case my cheap multimeter wasn't quick enough at detection. I'd say the circuit tester illuminated at max brightness. Afterwards I did a control test on the battery (it had equal brightness). As an aside, the day before I took apart my instrument cluster to give it a good dusting and cleaning. Replaced every bulb as well. Continuity is present across all electrical paths. I'd like to know your thoughts. Thanks for the help.
Thanks for spelling out how to properly do these tests. Appreciate you getting quite specific. Electrical testing is quite foreign to me. I might go ahead and get a more capable multimeter. That yellow one you see in the photo is quite basic—only has auto ranging. *************************************** Disconnect C156. Disconnect C203. Check for continuity between these two points (GRY/BLK) on the IP Harness side. I don't understand this testing. It was quite late when writing the update that you quoted. Just realized that I had a typo with identifying that connector. Thanks to you, I now know specifically what continuity test to do. I'll report back.
I was finally able to remove my instrument cluster this weekend. To recap, the reason for doing this is to get my Left Turn Signal Bulb (in the cluster) to work properly. Sometimes the bulb illuminates... but most of the time it does not. Work done prior to this consisted of refreshing the cabin instrument ground, cleaning up the front drivers side C102 electrical connector, and finally checked out if that C156 turn signal connector had any loose wire crimps (there were not). Everything went well taking the cluster out. Unbolting the speedometer cable clip from the suspension arm created enough slack for removal. Below are pictures detailing everything. 157,145 MILES C203 CONNECTOR C204 CONNECTOR EMPTY LEFT TURN SIGNAL SOCKET LEFT TURN SIGNAL BULB & SOCKET LOOKS 'OK' PARTIAL DE-LAMINATION DETAIL CONTINUITY TESTING For some background, I know the previous owner removed the instrument cluster. It was to replace the speedometer cable. If I'm not mistaken, my central C203 connector seemed a tad-too-easy to remove. It may not have been positively clipped in. Dielectric grease was present. I did many continuity tests to check the "bridge" between each light socket. Checked most, if not all of them. Everything beeped. 1 or 2 sockets needed to be removed to re-seat the bulb. After this, all electric connections now flow. I'm really unsure of what to do besides what I already have bullet pointed. Have next to zero experience with this stuff, but hey, I already have a few successful Comanche projects under the belt. Next to do... • Install all brand new bulbs • Burnish all the brass socket contacts • Do a continuity test between the turn signal connector (under dash) and the middle C102 connector Is there anything else you guys think I should do before closing this thing up? ...other than some polishing, dusting and lubing. Thanks a lot guys. This site is invaluable.
