Everything posted by olddude
I have used snapper mowers for about 50 years. very dependable.
Intermittent wiper module repaired
olddude replied to The86manche's topic in MJ Tech: Modification and Repairs
Just let me know. Mine works but not intermittent, just one speed. -
I need a working module. -
Serpentine belt path question
olddude replied to NC Tom's topic in MJ Tech: Modification and Repairs
I need a working 56000428 wiper module for a 89 Comanche
You were correct. I replaced the switch and the truck started right up. Thanks.
Thanks, I will look at that.
I have been working on my on-going problem. Several years ago I started having a problem starting my truck, turn the switch and nothing. I replaced the start relay, no help, so I replaced the the ignition switch, which is a pita. Then it was a sometimes thing, it would start just fine for a while then, no start. I installed a remote start button under the hood, connecting direct to the starter. Most of the time it would start just fine occasionally no start and I would use the remote. I have not been driving the truck much so I start it up occasionally or drive it on a errand and I would have to use the remote to start it. So, last week I decided to do some of the things that I have been putting off. Replaced the valve cover gasket. Got that done and running it to check for leaks and noticed a drip from the thermostat housing, and replaced the gasket. Then, leak checking that and noticed a leak from the power steer pump. Replaced the pump and had to wait a week for a pressure hose. So, now I am back to the start problem. I decided the ignition switch is either bad or not adjusted correctly. I replaced the switch again, no start and none of the instruments work (I pulled the instrument panel for access). When I turn the switch to the start position the radio and the computer screen goes out. I think it must be a wiring problem. Where to start
Saw one several months ago, very rare to so one here. I can't remember when I have seen one before that.
has the speedometer gear been change?
How did you aquire your Comanche and what is the story behind it?
olddude replied to Classy Comanche's topic in The Pub
I bought it new in 1989 89 Comanche.pdf -
The Wildcat was one of my favorites, it was a 'horse". My only complaint is the distributor being in the front of the engine, just behind the fan. In a hard rain if you ran through a large amount of water the condensation would collect in the distributor and drown it out. I don't know how many times I would get a call from my wife that she was stranded.
olddude replied to neohic's topic in Member Projects: Other Cool Stuff
same temperature today? -
52 Chev. Coupe 56 Mercury - mistake 56 Chev Belair 66 Chevelle SS396 54 GMC pickup - restored 69 Buick Wildcat 73 Pontiac Grand Prix - another mistake 78 Chev Pickup 80 Buick Regal 84 Buick Rivera 89 Jeep Comanche - still own 93 Cadillac Sedan Deville 99 Jeep Cherokee - rear ended & totaled 2004 Cadillac Sedan Deville 2015 Cadillac Escalade - still own 2008 Jeep Wrangler Sahara - still own
February 2023-The Comanche by the Sea
olddude replied to 89 MJ's topic in Comanche of the Month (MJOTM)
Another nice Georgia Comanche -
Heater Core Recommendations
olddude replied to Blaine.D's topic in MJ Tech: Modification and Repairs
I replaced my heater core with one from Advance several years ago and I replaced the A/C evaporator at the same time both being 30yrs old. It's a process. I removed the dash, some say just take loose and let it hang while removing the enclosure. First you need to discharge the Freon from the system. Like I said pita, Takes about 1 day to remove & 1 day to reinstall. -
Jealous
Sounds like a find! Awaiting the next installment
Just part of the process. I like the truck, I think it will be a good one, I noticed the UGA receiver cover. If it's a Georgia truck it shouldn't have much rust. Just keep on keeping on.
I used the old expansion valve on my r134 conversion. When I replaced the evaporator later I picked up a o ring kit from Advance Auto. Good luck, that thing is a PIA.
11 degrees F here this morning. I think the low was 9. It's 9:51 a.m. and up to 13 F. That's pretty cold for middle Georgia. The good news is, it's a bright sunny day today, not windy like yesterday.
Had all of them removed, 2 as a teen and 2 in the air force. The last one was impacted and they broke it into with a hammer and chisel, I thought they were kidding when they said they were going to do that. "they were not". The next day I looked like I had been in a fight with a prize fighter. The right side of my jaw was black from where they had me back it up with my fist. I trust you had a better experience.
correction: It was a 99. Well what do you expect from an Old Dude.
