89 MJ
    8
Everything posted by 89 MJ
  1. Glad I could help!
  2. 89 MJ
    2 door XJ owners
    Ok. I’m glad you’ve owned several of each, it makes my research easier. Thank you!
  3. 89 MJ
    Infiltrator
    Not a chance in Hell
  4. 89 MJ
    Infiltrator
    They probably think: "Our neighbor is F#$%ing awesome! He drives up all of our property values, we owe him a big thanks"
  5. 89 MJ
    2 door XJ owners
    That seems like a very impressive amount of rear space. The only thing this would really haul would be my gun and golf clubs before my MJ gets out of storage, so it wouldn't haul anything crazy. Thanks for the input!
  6. 89 MJ
    2 door XJ owners
    I'm 5'11" and 120lbs. Pretty small. Thank you! Ok, thanks!
  7. 89 MJ
    2 door XJ owners
    Ok. Thank you!
  8. 89 MJ
    2 door XJ owners
    Thank you! How did the ride quality in it compare to the ride quality of your MJs? I would assume the front seems bigger because of the bigger doors, but A main reason I want one is because something like this one would look so good next to my blue MJ.
  9. Have you talked to your wife about this? What are her thoughts on it, on the time aspect. I would assume this would be a nights and weekends gig, yes?
  10. 89 MJ
    2 door XJ owners
    This is mainly what I was wondering. I wasn't sure if it would have a stiffer ride compared to the MJ due to the shorter wheelbase and shorter leaf springs. I'm 16 years old. Practicality means almost nothing to me. I am just looking for something that could seat 4 people in a pinch, but still be unique. And I need something to drive in the winter, and the rear seat would rarely, if ever, get used. The back seat wouldn't get used much at all. Thanks for the reply, my biggest concerns were driveability and if it had enough space to put stuff in the rear.
  11. 89 MJ
    2 door XJ owners
    There has to be a few of you that have owned or own a 2 door XJ. I am very familiar with MJs, but I want to add a 2 door XJ to the fleet. My question is, how do they compare to an MJ in ride quality, space, driveability, and usability? I know I could buy a 4 door XJ, which would be more practical, but the 2 doors are cooler. I've never really driven an XJ either, so I don't know much about how they drive. Is it worthwhile to add one to my fleet? Thanks in advance.
  12. It must be a very early 87 based on the fender badges. I LOVE the two tone though!
  13. My blue truck has OEM mirrors in the 84-96 flavor. The truck is my daily driver and I am yet to think, gosh, I wish my mirrors were bigger. I also think that the 84-96 mirrors are better looking. I have even pulled a trailer with my truck and visibility was fine. In my opinion, you should just find mirrors that you like and go with those.
  14. I suppose skateboard look, wheels are easier to change than a lift Air fryer or pan frying?
  15. When it comes to drilling spot welds, we have found that if you go through both layers of metal with a 1/8th inch drill bit, then go through just the layer you are wanting to replace with a 5/16th inch drill bit, it will actually work out better than using a spot weld drill bit. After drilling through it, the metal will just about pop off.
  16. Muscle car. No replacement for displacement. Trackhawk or TRX?
  17. Looks like it was a great time! It was a IH Scout II that you pulled out though, not a Bronco.
  18. For simplicity, gotta go MIG, for the best looks, gotta go TIG. Personally, I would do MIG more than TIG, even if I had the equipment to do both. LED Light bars or old school Halogen off road lights?
  19. Looks like it will be a great truck!
  20. I will be using various pictures from my build thread on my blue truck to give a little tutorial on how to properly do rust repair. Even if you are familiar with rust repair, I have picked up on a few tips from my dad (restores cars professionally) that may make your life a little bit easier. Now, I have access to a lot of higher end restoration tools, but I recommend that you purchase some of these as well, lots of these can be picked up at Harbor Freight or second hand for relatively cheap. We will start this with a list of tools that you will want: 1. Sandblaster 2. Drill with 1/8th inch and 5/16th inch drill bits-You do NOT need spot weld drilling bits 3. Cut off wheel (1/8th inch disc) (pneumatic) 4. Cut off wheel (1/4th inch disc) (pneumatic) 5. 90 degree grinder with 36 grit (pneumatic) 6. Air saw (pneumatic) 9. Blow gun (obviously pneumatic) 10. Various body hammers 11. C-clamps 12. sheet metal brake (not necessary, but very helpful when making 1 off patches, otherwise you could use a bench vise and freehand bend) 13. Welder (duh) 14. Vice grips 15. Weld through primer Your first step is to identify your rust/metal that is going to get replaced. Next up you will want to cut out your rust. It is a good rule of thumb to go 1" to 1.5" greater than your rust holes-the rust is always worse on the inside. Once you get that cut out, sandblast and use the weld through primer on the parts that you will keep. 3rd, you will want to trim your patch panel close to shape-leave it a little on the larger side, you don't want to make a patch twice Once you get your patches made, start trimming out the metal (not the patch metal, the original truck metal) with the air saw. Only go an inch or two at a time and use tack welds to hold it after you cut it out. Try to make the corners of your patches round to distribute the heat and prevent warpage. Once you get your new patch tacked in, continue using small tacks when welding in sheetmetal. If you lay a solid bead, you will warp your panel. Move around on the panel when you are tacking it together and use your blowgun to cool the metal after welding it. Use your wider cut off wheel to knock down your welds, don't make them flush, just take 80% off of the weld. Smooth them out with your 90 degree grinder. When you are happy with how smooth your welds are, sandblast where you have welded. Be sure to be careful with your blaster, it is easy to warp the metal. Sandblasting the metal will find any pinholes in your welding, you will need to make sure there are no pinholes. Then you are ready for primer and body work.
  21. I think I have come up with a plan for the Ugly Trucking. My plan is to make it run and drive, then it will probably be sold as is. As much as I would love to do another Comanche, my next MJ restoration is going to be a Metric Ton and the one after that will probably be a 2wd. We did get the truck to run, usually, we will need to do some troubleshooting there, figure out why the clutch won't disengage, and make the brakes work. It really doesn't need a ton at this point, so hopefully when I finish the partout on my other red truck, I will be able to get back to this truck. This truck would be a really good one to restore though, considering the only rust is in the floors.
  22. Robin Williams Stroked 4.0 or LS?
  23. The silver dash bezel looks great!
