ValpoManche
ValpoManche's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. You get back up and running yet? I need three sets? Will send a deposit if that helps.
  2. Most excellent idea! Thank you for sharing and adding link to the controller.
  3. 87Warrior do you still have you 99 template? If so, I’d like to pay to have it shipped to me so I can make a digital file of it for people to run off at staples of FedEx office on 24x36 paper to use on their project. You up for sending it to me if I pay shipping? Also, if you don’t have one does anyone else on here have one that I can use to make a template that we can throw up here for others to find in the future?
  4. What are the red and white wires coming out from the firewall where the two coolant lines go into the heater core? The two wires are almost under the coolant container and just to the left of the heater core coolant lines.
  5. Has anyone gotten back to you on this post by PM?
  6. Lol @89 MJ. Need to find another one or two for builds. Best from bumper made for MJ/XJ!
  7. Thank you guys! I have done the rear ZJ swap on my XJ. So I am familiar with the ZJ prop valve for regulating fluid to the rear brakes. Haven’t done a WJ booster swap and was seeing some different posts on options. Since I have everything apart on two different MJ’s and a third in process, I am planning on a trip to the local JY and figured I’d get a list together for anything I can find that will upgrade from stock. I may just end up pulling all components from the WJ and also any ZJ’s if they are there so I have parts and pieces to assemble. @Tex06Ill let you know if I need your parts. Gonna have lots of extra parts when o get these done. Let me know if your looking for anything.
  8. Happy Thanksgiving Everyone! Anyone have a template for the meter snow plow setup? Found a plow setup but no mounting brackets. Just putting this out there in case someone has a template or maybe has a set off their truck that could trace and post up here for member use.
  9. I have been spending a lot of time reading about brake booster upgrades. Everything from WJ to XJ. For those running 31-35 tires on long bed 4x4 setups, lift is not critical; What modifications have you found to work best? I will also be running rear disc brakes, so this will be an additional factor for performance.
  10. Anyone do the external AX-15 swap while updating to OBDII and putting in a 4.0 HO with the updated wire harness for the 4.0HO? Looking to rule out the need to hack into the harness other than the rear tail lights. The external AX-15 I am using is from a Cherokee.
  11. I'll check my parts truck and parts bins. If I have extras of these I'll send them to you and ask to get one back to install in my frame off resto I'm working on.
  12. Frank: Want to order one with Amber cab lights. Email me at asworden@gmail.com for making payment arrangements and to get me shipping info. ValpoManche
  13. Anyone have one or know someone who does? Pic below is what I'm looking for. This one is on my XJ.
  14. Does anyone have any wire diagrams or know where to find them for a rear power center? I don’t care if it’s connected to the engine bay battery or a separate battery in the trunk. Thank you in advance. Want to run two 110 plugs, 1 usb, and 2 cigarette outlets.
