89 MJ
    8
Everything posted by 89 MJ
  1. Up to $7,000 with 1 day to go. I've got to ask, did it hit your reserve? I would guess, based on the condition, that your reserve was around this price.
  2. Just use cruiser's website or pick up a Haynes manual at your local parts store
  3. I'm not jealous, you're jealous!
  4. Ok, so its 15 grand. You will have a ton of money in rebuilding the motor (because you might was well build it while you are in there), but at the end of the day, it probably isn't going to be worth a ton with the NOM.
  5. 89 MJ
    MJ OEM Rear Bumper
    Dang pillar jumping out at you. My boss has had telephone poles jump out in front of him too.
  6. Good looking T/A! What year? Looks like a 70-73 to me.
  7. Bone stock with God knows how many miles.
  8. For some reason it won’t let me copy the link. Here is a screenshot. No pricing or date to release yet.
  9. Are you going to beat on your truck? My dads YJ with 35s, a 340 hp 5.3, and an NV3500 has done several burnouts and donuts on the pavement with no breakage. I think you’ll be fine. The 3500 came in half ton trucks too.
  10. It just gets brighter . Turn signals are also the whole thing other than the reverse light, it just turns off the brake/taillight when it is blinking, but the other one stays lit.
  11. How the heck should I know? I never let anyone else drive my MJ! It should be the whole top part above the reverse light IIRC.
  12. @Pete M, can you please move this over to tech?
  13. As long as it is gloss black, it will usually look the same. Make sure though when redoing everything that you try to get paint from the same batch. Sometimes different batches can have a different sheen.
  14. That's a lot of RPM for our little stump puller engines. Maybe try a different TB if you have one, maybe that is sticking.
  15. The grill and headlight bezels on my truck are rattle can too, and they still look fine (paint is over a year old and sits outside spring-fall)
  16. My dad has an NV3550 (maybe 3500) in his 5.3 YJ on 35s. Its beat on and has held up.
  17. Its looking good!
  18. I probably have about $500 in parts that I ordered when I did my engine swap. Just one order was over $300. If you wanna play, ya gotta pay.
  19. I have been seeing updates on their FaceBook page.
  20. I see KeyParts have their MJ taillight lenses in the testing phase now. Depending on the price, I'll probably pick up a set to put on my worst set of taillights. If I do that, I will create a thread on it.
  21. But depending on what 350 he uses, he might make similar power to a 4.0.
  22. I would check sensor adjustment and check all of the vacuum lines on the engine and go from there.
  23. Get used to it When I order parts it’s usually hundreds of dollars at a time.
  24. Yeah, the grit for sandpaper is a bit of a personal preference thing, I like to go a little more agreessive to make sure my next coat of primer will stick. On my truck, I went with 180 pre bedliner, but I wouldn’t recommend going any less.
