eaglescout526
Administrators
    13
  1. Have you inspected the NSS internals since owning the MJ?
  2. I have those same tabs on my XJ. Funny enough, they were with the hooks I found at my grandparents house which incidentally enough were the same Warn hooks Jeep used.
  3. On my MJ it is the same as fiats. Heres what you can do, get a nut and thread a bolt then put the support on the hook. If that will make it easy.
  4. I can take a look. I installed hooks on both.
  5. Couple things. One. Finally got the exhaust down pipe!!! Went to go put it in, got it bolted to the manifold, looked at the other end. Aaaannnnnd it’s too long. Ain’t that interesting. I for the life of me can not figure out why. Now my 88 parts book says 4cyl is the same regardless of the 4wd or not along with XJ or MJ. Fits both. Well no big deal, I’ll cut it, expand the pipe and slide the cut end in and weld it once I have it fitted to where I need it to be. I’m still trying to figure out how this is an issue unless I ended up with a 4.0L pipe which I highly doubt but everything should be the same unless AMC changed the frame and the mounts on the XJ after 86 which I am not aware of such happening.
  6. Right. But are any of them new? Sounds like the trans mount is new.
  7. How are all your mounts? Motor and trans?
  8. Heres where the sensor on the D35 goes. I put it in too high, whoops but thats ok, it is still reading the fluid. But now I need to find a washer like gasket like how an oil pan drain bolt uses on all these sensors to stop the leaks. I also found a t-case skid plate in my parts. I think I got it from the same person who sent me the system sentry but I do not remember anymore haha. Now to figure out how to install it, or where it goes for that matter and if my XJ can take it.
  9. So I decided to tackle my bizarre issue with my front sway bar. Replaced the links and decided to ditch the poly greasable bushings in favor of just regular ole rubber bushings. So these are not the original mounts by any means. These are newer style from Chrysler that actually cradle the whole bushing which is pretty nice. Whats odd is I remember fighting to put the poly bushings on but these hardly fought me at all other than aligning the bolt holes to tighten the bracket down. As for the links, well I put them on first then the bar and it is all lined up pretty well so I have no idea why I had any issues with the links. Probably the poly bushings but we shall see how she drives.
  10. Thats scary that the ECU failed.
  11. Ok. I walked into oreillys. Grabbed the cheapest sunshade they had and cut the thing to fit. I do not, absolutely do not regret doing that at all.
  12. Bump! Come get some interior pieces! May not have full sets of stuff or MJ specific but I have odds and ends. If you dont see something, ask me if I have it. I just might and never got to listing it!
  13. This one looks like one of the first 4 doors ever done.
  14. The Renix system can compensate based on two sensors. TPS and O2. If you adjust the TPS to put out less fuel or more fuel at idle which is voltage, it would be fine. But honestly it doesn’t matter for the PSI since the fuel is regulated down to 15psi into the injector. Course I don’t know much about those ratings unless they’re based on either how much pressure they can handle or how much pressure they’re outputting the fuel to. I can’t see there being a huge difference, but I’ve never known this till now so I do want to test this.
  15. Good luck finding cheaper. The only ones who used that injector was AMC and GM. Maybe GM might yield ya a cheaper injector but that injector is a costly one regardless. I might have one or two, can’t guarantee they pulse like they should. What ya ought to do is hit a junkyard with a bunch of older Chevys from the 80’s and 90’s, the V6’s and 8’s used the TBI set up.
  16. Socket that is the same inner diameter as the pin. Or flat head and push them in one at a time till it comes out. That one requires some patience to do.
  17. Do you know any other history? Something like that with it having an issue while driving points me to a bad head gasket and not sensors if the head gasket has never been serviced and if it’s sat for a few years with coolant in it that would destroy the head gasket. I only say such cause mine checked out with all the sensors but the head gasket caused my problems with driving. The absolute only other thing that can give driving issues is the O2 sensor not being read properly by the ECU which is a result of bad/dirty pins in the connector on the harness side and would fault the system to remain in open loop vs closed loop.
  18. It’s actually called an ISA or an idle speed actuator. They can be found on GM cars and yeah the YJ but not many places have it listed to fit the XJ and MJ due to the XJ and MJ getting the 4.0L more commonly than the YJ until 91. That being said, they rarely go bad and usually are misadjusted due to shade tree mechanics or techs who have never worked with or understand the Renix 2.5L to set it correctly. It’s possible for them to have swapped motors but that wouldn’t make a difference unless they swapped the engine management which they haven’t done at all and still has the Renix TBI. This all being said, is your engine behaving funny or have drivability issues?
  19. Rear axle has its sensor now. Thats when I found the transfercase low. It really wasnt but the oil that came out looked like a strawberry milkshake. Guess a drain and refill for that is in the future. I also found the axle to have been really low on oil too. That was a scary discovery when I had drill the hole for the sensor.
  20. Before I found a factory bumper, mine was bolted to the original bumper brackets just fine actually.
  21. Yeah....someone really wants it. At this point its too rich for anyones blood, and past its value in my opinion.
  22. Yup! What fiat posted is the same one I have on my truck. It’s nice and definitely helps keep the sun off my back.
  23. ….you know aftermarket ones exist right?
