Fredo
Fredo's Achievements
Fredo started following Power Windows/Locks , Bucket seat installation , Early XJ hatch/tailgate lock cylinder? and 7 others
thanks
So I have 2 manchee, one of them is 3’ lifted, and the second one I want to make it in to a “street Comanche” not sure is that is how is called. What I want to do is put 245/40 r19 wheels but, not sure it they will fit and / or what is the biggest rims whit tires I can throw on. I want something like this
sweet. thank you let me look for them!
its an 86
So, I have an issue, I swapped cluster on my 2.5 4 cylinders, to the cluster that has a TAC. But when changing the temperature bulb/sensor, this bulb/sensor does not fit the bulb for the 2.5 L seems to be shorter than the 4.0L. I had swapped cluster in my 4.0L and no issue. Anyone knows what temperature senor a 2.5L needs so my gauges can work Picture is the temperature sender I used on my 4.0L
thank you guy!!
thank guy!!.. do you happen to know size of the front speakers?
Tach / Tachometer not working, changed and not wired
Fredo replied to Fredo's topic in MJ Tech: Modification and Repairs
thanks!- 5 replies
- tach
- tachometer
(and 2 more)
Tagged with:
- 5 replies
- tach
- tachometer
(and 2 more)
Tagged with:
So when I bought this 86' MJ with a 4.0l 5 spd had on Tachometer, I switch instrument cluster but TACH still not working, looking at the engine, I see the distributor is not the original, so, apparently this was changed thus it was not wire to the cluster (this is my conclusion) my question is, is there a wire diagram an one can share and/or, any one know how to connect it?
- 5 replies
- tach
- tachometer
(and 2 more)
Tagged with:
it help me a lot, thanks!
yo don't happen to have the dims and measurements of the brackets, do yuo?
So I’m trying to set up my stereo and leave it as original as possible, I want put ‘’stock’’ 4x6 speakers but my manche don’t have the back brackets and I’m doing them from scratch from a metal plat I have. does anyone have the dims and size that have to be?
