eaglescout526
Administrators
    13
  1. Nope. Tried a G34 in my 84 XJ and it will not fit. The hold down is different for 84-86.
  2. I am issuing a technical service bulletin for my cruise control kits. If you have purchased a kit from me and cannot get it to work, please let me know. I have a solution. Use zip-ties where I have rubber tube mating with plastic tubing. This will eliminate a vacuum leak preventing cruise control from working. Why am I issuing this? Well I was having issues with my new 4wd set up and decided to use zip ties on the hoses to prevent them from slipping off and causing issues. This worked for me pretty well and I feel it should work well for my kits if I sent them out with plastic tubing mated to the rubber hoses. I will be locking this but please PM me if youre having any issues and I can happily send some zip ties along as I have a metric ton.
  3. I have a few of these if you want a couple.
  4. All good. Wish those were factory, but they weren’t.
  5. Not factory. A special 100 MJ deal with archer bros and a California dealer. Also not. A custom thing as well.
  6. Mopar. Haven’t had an issue with either one. That I have/had. The first one I think lasted me about 4 years before it gave up and the second one I’ve had for maybe about 2 now. Maybe 3.
  7. I’m using the old 84-86 selec-trac switch. I imagine if you found an Eagle or an SJ with the same set up, you could use it the way you’d like.
  8. I can safely say it’s faux selec-trac haha. I am glad I do not have much to worry about at all. It’s pretty neat actually. It’s literally a switch that sends vacuum to one line or the other. Rudimentary but it worked on the NP228/9 which I sadly couldn’t use. But I have mine set up and it’s working to where vacuum just either vents on 2wd or it goes to the actuator on the axle to shift. But I understand all the definitions better. Thanks guys for the input!
  9. I appreciate your guys input. It just seems to me the market has limited choices. So I think what I am gonna do is get a better pan, dump my used oil in a bottle like a cranberry juice or gallon milk bottle as I drink both pretty often and take it to O'reillys and have them dump it.
  10. No. I am not doing away with it. HOWEVER! I am going a different route. Probably one not seen or talked about as it sounds crazy. Selec-trac, with a command-trac case, but the selec-trac vac switch controls the front axle shifting. Crazy? Brilliant? I guess what I am after is some opinions. As it stands I can have a selectable drive via the vacuum actuated system, but I can have 2wd low. Am I going to run into any issues with this set up? Am I gonna lose an NP207? or a front axle? Or a whole drive train? 4wd is still very new to me but not complex to where I can not understand what all is going on. Granted if I absolutely need to, 2wd operation on the 207 is still available. Let me know what you guys think.
  11. I can only see it being an failure if its not well maintained or their putting what they shouldnt be in the cooling system. I guess in your situation, I wouldnt knock it just yet.
  12. Really? Hmmmm.
  13. The only way I see this happening is if something really acidic inside ate away at the coolant passage in the manifold to do this. A failure really unheard of for either engine really. And the aluminum manifold is a great heat sink so bypassing the manifold may or may not cause an overheating situation. Not sure as I have never heard of anyone doing this. Could also have a rusted out headgasket on the 86 letting coolant into the combustion chamber.
  14. I simply pulled mine right off. Course yours looks better than mine does which does explain why it does come off easily.
  15. One of the last ones I provided a build sheet for. Those were the days.
  16. Ok. The only reason why I say this is once a year, every summer, ever since I cleaned it out in 2017-18, I’ll have an issue where she will run funny and the O2 circuit is the cause of her running funny till about 15 min of driving and it’ll clear up. So I’ll spend about an hour with some electrical contact cleaner and spray the hell out of both ends liberally until it’s clean or I’m satisfied with it and give her a start and see if my issue clears. I honestly think with how hot it gets out here, the stuff in the C101 is getting liquified and messing with the connection.
  17. This just occurred to me. Do you have the C101 and have you cleaned it?
  18. I am not a fan of 97-01 swaps, but I am enjoying what you’re doing to the newer interior to make it match an older color.
  19. Final adjustments! We took him for a ride around the block this evening. Couple little things I need to fix and itll be good and ready. Theres still more to do. Air shocks, new rear leafs, tcase skid plate.
  20. Lol. Still a good case.
  21. Sure it’s not a 207 or did you swap it out?
  22. Yeah it doesnt, even my 88 parts catalog does not show the special nut. I do not off the top of my head. I can go see and study it but it should be the same as the bolt unless you werent able to get it off with the special nut.
  23. Fun fact, that is the 84-86 diagram which does not show the special nut sleeve that slides into the frame, but you are correct. The sleeve should slide in from the inside and the bracket is bolted down from the outside. My 84 does not have the provision at all for this hole. I think I still have mine somewhere.
