13
Yes, its pretty easy to stick the leads in the connector and see what it is outputting while cranking. .02VAC is the absolute bare minimum but honestly, dont settle for that. Factory Siemens/Renix CPS output .05VAC with .03VAC being the lowest. Shoot for something that will do .03VAC.
Charcoal Canister - hose connections
eaglescout526 replied to Keri's topic in MJ Tech: Modification and Repairs
Correct. -
Have you tested the CPS to make sure it is outputting more than .02 VAC?
So what is circled in picture 1 is irrelevant to 87-90 Renix. Pic two and three go to each other. It is the vac line for the heater control valve which opens and closes off coolant to the heater core. It is highly recommended to get it hooked up again seeing how you have AC. -
System Sentry Sensor Location Dilemma
eaglescout526 replied to eaglescout526's topic in MJ Tech: Modification and Repairs
Theyre for a very old set up I’m putting in my XJ. 84-85 only were the model years it was available. I know they can be adapted to use on an MJ if you found the whole thing. So this isn’t something that will plug n play in an MJ. What I have is the last NOS in the world. There’s some number on it but it’s not the AMC number which I don’t have at the moment. -
It’s probably half a quart for both axles given the locations as where they should be. -
A good dryer or washer will do good for repair panels if your in a financial pinch.
That’s an idea! Maybe an armored thicker one would allow for the original cover to get trashed with the sensor in place. It looks for level based on the continuity used by the fluid. The oil completes the circuit and let’s the module know it’s full. Once there’s no fluid to complete the circuit, it shows it as empty. -
Backup lights are not working
eaglescout526 replied to Eagle_SX4's topic in MJ Tech: Modification and Repairs
No problem! How are the contacts on the fuse itself? I know lately I have been battling corroded fuse legs on my XJ and barely supplying 12v to what its powering. -
Wild thought. Is the trans fuse blown? I have no idea if the fuse affects power going to or from the switch though. -
I know this is XJ but honestly, I can barely trust facebook groups to not give me 30 likes and zero advice. And I dont want to join an XJ forum when I know all of you guys are the best and can give a good answer or an opinion on stuff. So on the D30 AMC located its oil sensor on the left side of the pumpkin if you are looking at the pumpkin from behind. This one surprises me, rather AMC just make one axle and issue a plug kit for each on that doesnt have the system sentry, they made two. One with the sensor hole and one without. Same goes with the D35. My 30 does not have the plug nor hole, I want to add it to the 30, but drilling on the side where it goes will be tough as I would either have to cut the LCA bracket, I see that as a BIG no no. Or I drill a hole through both LCA brackets and get to the spot where the sensor goes but I would need to get the right size drill bit in an extreme length. Course another option I have is to drill a hole in the front of the D30 cover and put it there, but from the looks of everything, it looks rather small and compact to where that also could be a challenge. What would you guys do? Pic of the sensor:
JL is the trim and drive. 62 is the long bed.
Custom Gaskets for HVAC
eaglescout526 replied to H3ADBANG4L1F3's topic in MJ Tech: Modification and Repairs
Wanna put an AMC logo on those? Haha. -
No. 87-90 did not have this. Only the YJ and 86 XJ and MJ had said switch. It was replaced by the power steering pressure switch as a WOT switch.
I literally walked into oreillys, bought a cheap reflective one and cut to fit.
I’ll have to look in my TBI book and get back to you. Since it’s a switch, you probably will be looking for continuity while closed and open with open throttle. Just a guess.
The CTS is in the ISA actually, it’s a set of contacts that tell the ECU when the throttle is closed. It’s interesting how they set that one up.
Check the ground, see what resistance exists between it and the ground at the battery. It’s interesting that you have this random rev hang on a 2.5L. Let me do some more thinking and reading on this to see if I can come up with any other probable causes.
What the hell is this
eaglescout526 replied to Johnnyutah's topic in MJ Tech: Modification and Repairs
Year would help us but if youre MJ has Renix, an idiot light cluster or a gauge cluster is all you get. HO its "digital" but only the speedo and tach are. HO XJ Gen II swap would yield you the cluster you want but you have to do a whole interior swap to 97-01. Both HO swaps require you to change the engine management. As far as the clusters being "good", clean the grounds and all the connections at both the sensors and cluster and it should read pretty accurately. Aftermarket sensors are known to be off about 10-20% in accuracy. Mopar still makes the oil sensor but not the temp. -
2.5L just has a bottom bar support that holds the radiator from moving back and forth at the bottom.
NOS floor mats
eaglescout526 replied to fiatslug87's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
I see it now haha. It’s camouflaged in. Oh I know what I’m thinking of for the logos, on the SJ, they got the full AMC Jeep. I think the XJ did not at all. -
NOS floor mats
Wow. That’s a price for something you can get repop. Like I’d understand if it had the old Jeep logo in the mat but I don’t see that. -
2.5L Renix VS 2.5L MPFI flywheel dimensions?
eaglescout526 replied to OldSch88L's topic in MJ Tech: Modification and Repairs
Ok just making sure. Didn’t know if you gave it the whole works while you were in there. -
Ok. Now what about the clutch disc? Do you remember having the word “flywheel” face the flywheel when you were installing it?
