eaglescout526
Administrators
    13
  1. Now when you swapped, you got all the parts for the HO right? Clutch disc is mounted correctly too right?
  2. And now to rake in the dough. I mean give everyone good seals on hvac
  3. Yes it was an 86 only thing along with the special winch adaptor that later was just the flat end of a tire iron. but this would do away with my ratchet strap on my MJ and be a bit more reliable.
  4. I feel almost any bar will do. I believe 80’s and 90’s ford trucks had just a bar and that bar could be easy enough to use instead of making one but it’s also just a flat bar with some j-bolts. I’d love to find those wing nuts though. edit: found them. Lol.
  5. Now with two more lights off!
  6. The holes are still present on the long bed for the full size spare tire bar? I got a new piece of literature breaking down the MJ and stumbled upon this: Now understanding where and how it’s supposed to go on….I see a future where I’m putting this on my MJ.
  7. Yes. It should jump the system regardless. If it does not, something else is preventing the system from working but it sounds like you have everything else but the pressure switch figured.
  8. Always take it with you when ever you go to a car show and put it on your dash.
  9. There should be a relay as well that could have failed. I once had an intermittent relay in my system that would go on like normal and fail when really hot.
  10. Well damn. Ok I think I have a general idea as I had to make 86 vac set up with 87-90 set up minus the 2 ports on the TBI as two of them go to the crank case if I remember correctly.
  11. Does your firewall still have the tag on it that shows the vac diagram?
  12. Wild thought. Every vacuum line is routed correctly right? I can’t remember if the MAP is routed to the base of the throttle body or the port at cylinder 3/4 on the manifold. Nevermind it’s an 86. It’s obvious where it goes.
  13. Lol that’s not terrible at all. I think we all shun but encourage everyone to hang on to parts. I took on the 2.5L parts roll and that’s what I mostly have. But I’m as stumped as you are with this issue. Now you said the ISA does work as in you have seen it move or heard it?
  14. Hahahahaha I’ve already done that to myself. I think I’ve got two or three throttle bodies, I had 5 intake manifolds at one point and I believe I’m down to one or two now.
  15. I have two spare ECUs if you want to test and see what’s going on.
  16. Nope. That’s mostly why AMC preached that it should be the last thing to be replaced as it’s built pretty well and reliable. I have one ECU in my possession where the fuel circuit doesn’t work. I need to do more component testing as to why that is. The voltage regulator was replaced on it and it didn’t make a difference other than it could crank again.
  17. Oh and im not asking you to test the sensors again, I’m just asking if they all got 5V when you did test them. If they didn’t then the ECU is at fault. I’m going off what AMC said in the books that the ECU should be the absolute last thing to replace when having these issues.
  18. No that’s correct. I have seen the both as US and France manufacture. That ECU looks like it was made in 85. There should be a date code where it says made in USA. And yes it’s gonna be clean haha. It’s in the cab.
  19. Huh. Interesting. Ok. Well only one way to find out. Is every sensor getting 5V from the ECU?
  20. Not as far down as I thought it was gonna be. If you remove the air bonnet, how open is the throttle?
  21. Sounds good and no problem!
  22. Give it a shot. Worst that can happen is it chokes on too much air. Not very. I’ll give ya an example. On chunk my 84 XJ, I swapped to TBI. The screw was too far in and wouldn’t idle for me. I unscrewed it enough(one or two full turns)just to get him to run and idle after two key cranks. I can’t do the adjustment since I’m still missing the down pipe for the exhaust. But there’s a real world situation of how sensitive it is.
  23. This makes me think the ISA screw is too far down and the throttle is all the way closed.
  24. Can you start it with the vac line plugged in and your foot down on the pedal? If you can, adjust the ISA until it will start. Can I get a pic of your ISA? I want to see what we are working with here.
  25. Sounds good. Id test the IAT. Both with the engine cold and at operating temp. It’s based on resistance if I remember correctly. So you’ll be looking for low value while hot and high while cold. I could have that backwards. Cruiser always had a picture of the how the values should be in relation to the temp. I’ll have to find either said pic or take a pic from a manual.
