eaglescout526
Administrators
    13
  1. I think you need the Mopar Performance ECU from 1990. Course sourcing those will be next to near impossible.
  2. Could've hit me up. I am sure AMC salvage has a few laying around that I could've snagged one for ya. But I'll voice my concern and just say I wouldn't trust repaired aluminum, especially after something that looks like the San Andreas fault. But that's me, if you have complete faith in their craft then that is perfect by all means.
  3. I wouldve sourced a new bell, honestly. When my trans blew it ripped the bell clean into pieces. Who knows if that bell once fixed will be able to handle the torque of the 4.0L.
  4. Garden bed. Pun intended.
  5. Without pulling the cluster and stuff apart, its the ground that's bolted to the dash in cruisers tips is the cluster ground and everything else. If your truck has AC, youll benefit greatly if you do the blower ground mod as well. I know I saw an improvement in the volt gauge reading on my cluster.
  6. The electrical manual for 88 is on here. I do have an 86 manual that I can look over and provide assistance with. Sometimes that ground doesn't always help, but it may not help if the other grounds are dirty/bad. One ground from the battery to the block, on from the block to the firewall and then that's pretty much the grounds for everything else is that strap from the block to the firewall. Not sure where that strap is though on a 2.8L.
  7. Definitely start with the grounds. Check and clean them all and go from there. The early 84-86 clusters use old style connection for the gauges so taking the cluster out and looking at the contact prongs on the backs of the gauges and give them a good cleaning. The older clusters are notorious to have decently reliable gauges. Especially the tach. The tach likes to have a mind of its own.
  8. *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADA LIGHT PACKAGE AHL HEAVY DUTY INSUL PACKAGE AJZ BAC 75 AMP ALTERNATOR CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT &&&&&&&& REAR DDQ Transmission - 5-Speed Manual EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LNJ DUAL ROAD LAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MCA FRONT BUMPER GUARDS MCB REAR BUMPER GUARDS MD8 Delete Front License Plate Bracket MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 20 GAL FUEL NHM AUTO SPEED CONTROL RAF RADIO - AM/FM/MTR SBA POWER STEERING SUA TILT STEERING COLUMN WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 11/13/85 Body code JP62
  9. There’s a universal throttle body rebuild kit that I used that has a new pressure regulator diaphragm in it. It’s made by standard and I believe it’s just called a TBI rebuild kit.
  10. Thats a mighty big Jeep sign. Needs a big AMC logo next to it lol.
  11. D44. Someone has a good picture of the known popular rear axles. I see that on the passenger side of the pumpkin is a data tag for that diff. See if you can clean it off and get your gear ratio from it and a date code.
  12. OEM if possible. Otherwise its a crap shoot at your local parts store. Some brands like Napa are usually pretty good but autozone is usually avoided. Depending on what you need I can look up parts and tell you whats available and whats not.
  13. Have not heard anything on the status of these other than they will happen. Coastchief is in the middle of life and will be replacing his head gasket on his truck.
  14. Actually the Fuel pressure regulator is the same concept as to what you would find on a carb regulator. No special tools are needed to rebuild the TBI's but special care is to be heavily noted with the injector retainer screws. So the regulator consists of the diaphragm, a spring, the housing and an adjustment bolt that is either plugged off or exposed. But hopefully you won't have to do a rebuild of the TBI but its still easy to rebuild. All you need for our Renix system is a good multimeter, some torx bits for the TPS, some books and the passion to fix the problem at hand. We are all here to help you out.
  15. *X1 -SA Charcoal 3LX AGJ Driver Assistance Group AHL HEAVY DUTY INSUL PACKAGE APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PWB QWB RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBG SPARE TIRE - COMPACT WJN 15" Aluminum Wheels Build date 3/23/88 Body code TM61
  16. When a sensor goes out of spec, the ECU will make the engine act up. Otherwise no these engines run really solid.
  17. Factory Service Manual is the way to go for all repairs. The TBI book I mentioned that you got will greatly help diag the rich situation as will an REM. The TPS can be out of wack and causing it to run rich. Check the vacuum lines to the MAP sensor on the firewall. If any of them are cracked or damaged, the MAP will feel the loss of vacuum power from the intake and dump fuel into the engine thinking it is starving for fuel. The TBI book will help you out greatly with the sensors and what their specs should be.
  18. Perhaps the linkage is off in terms of the actual gear location on the T-case.
  19. Probably has to do with how much it can carry. Not sure if that code is for Metric-ton package or not.
  20. Lol YJ I understand why. The front axle is still supported by leaf springs. The JKU is just bigger.
  21. *X1 TRIM STYLE X1 - CLOTH BENCH -YY 131 Zone 31-Boston 1AA U.S. Dealer Retail 3BK Customer Preferred Discount 5AM Largo Tracking 5KN Metro Cars of Detroit ADL Skid Plate Group ALN Body Color Bumper Group APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Dual 700 Amp Maint. Free Batteries BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHT Elec,Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB MOPAR Hood Lock K2X STRIPE/BADGE/MOLDING/COLOR K3T STRIPE/BADGE/MOLDING/COLOR KKG LAF Seat Belt Alert-Driver Seat only LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon PY3 Classic Yellow Clear Coat QY3 Classic Yellow Clear Coat RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TAE MUD &&&& SNOW TREAD TBB Full Size Spare Tire TBM Tire Carrier Winch TMW P265/60r18 BSW A/S All Terrain Tires WJM 15X7.0 Chrome Wheels XBS Pickup Box XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 3/19/89 JM62
  22. Might be right about this, still have some mystery vibrations going on, not sure if its because 30 year old truck or something else to replace that I can't seem to pinpoint on replacement. I find my long bed incredibly easier to park than say a full size truck. I would imagine short beds are a quick easy turn in.
  23. TPS adjustment sounds to be in order. The TBI book will tell you how to do that and its specs on where you want it to be in terms of voltage output to the ECU. NGK plugs are fine.
  24. Well done on the cut.
