Dave Vig
679 profile views
Dave Vig's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. Pretty sure. Put in a second clutch master after the new clutch install. Everything is going into gear fine except reverse. It’s been a pain in the rear
  2. Thank you for the replies. My ba10 seems like the synchros are going bad. Put in a new clutch had the toughest time getting it to work properly. Finally a mechanic down the street got it going. It’s running great but putting in reverse is slightly grinding unfortunately
  3. Wondering if someone can help me. I have an 88 4wd, 4.0, 5 speed short bed Comanche. Pretty sure it has the Renault tranny in it. Attached is a picture of an AX-15 from a 84 Cherokee. Will this fit my Comanche? Any help would be great thank you
  4. I will try doing that. Hopefully it will work. I will keep you posted
  5. I will try what you said cruiser 54 and yes Jdog I purchased a Luk clutch kit and fly wheel from rock auto. Also put in a clutch master cylinder. Did not replace the lines though. Very strange! Like it wants to work. If I take it around the block it did ok. Then when I stop the truck the clutch has no pressure and it won’t go into gear. Grinds when I put it in reverse.
  6. The shop installed it
  7. Hoping to get some help. Ok I put in a new clutch and clutch master cylinder on my 1988 Comanche 4x4 5spd. 4.0. When I picked it up from my mechanic I drove it off and the clutch had no pressure and I couldn’t get it into gear unless I pumped the clutch pedal to at least get back to the shop. Left it there all weekend was called that it was running fine. I drove it home was doing great, then all of the sudden went to take for a spin and same thing. No clutch pressure and couldn’t get into gear. What a Freakn bummer. Any help? I could use it thank you David
  8. I think I read about this just can’t remember where or when. Any particular year of Cherokee?
  9. That’s good to know I did not know that. I do see the trim on the outside and as far as the windshield goes. Is there any specific windshield I need to look for? or will a glass shop be able to decide that for me
  10. I have a question about the windshield on my 88 Comanche. It is leaking and I am wondering about the seal or gasket. Where can I get that gasket? And obviously a glass shop should be able to install it shouldn’t they. Hope this isn’t to dumb of a question thanks for any help David
  11. Ok got it. But if it’s to full will it cause it to run hotter than normal? Reason being I took it for a ride and I noticed it
  12. Ok thank you I had someone do some hose replacements for me plus a new expansion bottle I notice it was pretty full. Plus it ran hotter than what I’m used to seeing.
  13. Just put in a new expansion coolant tank on my Comanche. If it is to full will it run hotter than it should?
  14. Can you guys please tell me what this part is exactly called? Is it a crank case breather assembly? Reason being is I need one plus the hose
