Looks good! That must have been a later model gen 1 Cherokee with the turbine pump. MJ senders require a bit more modding. Those pumps are awesome btw. I run them on offshore jet skis as well with zero failures
new A/C accumulator port not right
ghetdjc320 replied to Pete M's topic in MJ Tech: Modification and Repairs
Yeah, I’ve not seen a hose fitting that is a coupler for AC hoses. Looks like either a dryer or hose swap is in order -
guess which pile is the good wiper 'puters...
Reading those labels is just sad lol. -
There is a big market there for sure. XJ’s, MJ’s and YJ’s and I’m guessing at least some ZJ’s -
Let us know, it's a service that almost everyone is going to need at some point. -
This is what the thread fitting should look like going into the dryer. Assuming the thread is 5/8 and not 3/4 https://coldhose.com/products/6-straight-o-ring-fitting-1?variant=35531641585824 -
There was someone working in the circuit boards of these things iirc. It would be a really great service for someone to start. There is a similar GM part but no direct swap replacement I’ve ever heard of anyone finding. There is a guy in eBay refurbishing old overhead consoles. He repaired the one going into my MJ. Wonder if he could repair these modules. -
Looks like just a standard #6 female to female ac connection should work -
Is that not where a t would go for your pressure sensor or do you have that mounted elsewhere? -
It’s a custom project.
Suggestions for best stock speakers
ghetdjc320 replied to OldSch88L's topic in MJ Tech: Modification and Repairs
That’s right -
Audio running to speakers you can think of as powered, audio signal running between two components (say a CD player and an amplifier) is generally non-powered or “line level”. Aftermarket radios tend to have this “line level” output for amplifiers. But some amplifiers can accept that higher powered “speaker level” input. -
Just realized it’s a retrofit. Clean, but wish they just made a new turn key piece. Also not liking the contrast on the main gauge panel. I’ll check into this further. Was planning to have Dakota Digital build me a custom dash using HDX gauges with all oem font but will have to compare now. I do like the info center for sure. Is the top indicator non-functional?
I’ve been waiting for this…
Project “Tomahawk”
ghetdjc320 replied to ghetdjc320's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Yep, that’s right. -
Project “Tomahawk”
Alas, the elusive Yazaki PA mirror switch connector straight from Japan. Had to order 3 so if anyone needs one let me know. -
Agreed. I’ve built many a stroker at this point. Best bang for buck for me was a 4.2 mini stroker with the old 232 crank and 4.0 rods. Diminishing returns past a certain point. There’s just so much more potential from swap candidates. I do still love the 4.0 but you have to sink a lot of coin into it to get it to perform much beyond stock numbers. A stock well running 4.0 with the right axle gearing is plenty of fun. They are easy engines to build though.
If you are referring to the 5.0 kit from 505 performance, I would strongly suggest reconsidering. 505 is very difficult to deal with and their quality is not very good. On a 5.0 build, I would suggest going aftermarket ecu and getting your maps tuned properly. That being said, it may be worth running a cost/benefit analysis. If you go stroker, be sure to checkout Russ Potenger’s builds at Bishop Buehl. He can get you all the parts you need and is top notch in service and quality.
To a degree. But it cannot exceed certain limitations such as injector pulse width beyond a certain point nor will it read wideband data or allow you to tune the data stream. What it does have is a knock sensor. If your stroker is very mild with minimal requirements beyond that of a stock engine, you should be be good on a renix system. If you want to seriously ramp up power and tune the map for your engine, you’ll need to go aftermarket ecu.
Seat mounting stud size info
ghetdjc320 replied to Brewinghokie's topic in MJ Tech: Modification and Repairs
The nice think about most MJ parts is they are all pretty much M6-M12 and mostly M8’s and M10’s. A few fine thread fasteners but most aren’t. The seat studs have that fixed shoulder on them as well
