I'm in alberta and if you come get it I got a bench seat for you original MJ 86 blue FREE my gf wants me to get ride of it lollllll
but it was for a stick ...........
well you can do the same thing I did for my YJ and it's going with all 1 ton TRE's and dom tubing but you have to ream the knuckles to accept the largers TRE's
keep in mind that I've done that to a dana 44 not sure 30 knuckles have enough metal to do this and at the same time go over the knuckle to give you more clearance ..........look for high steer on google there are some good site with lots of pics for it
pics: photobucket.com
flasher prob : most likely a ground on that line that is bad
you can also try to check the flasher unit in the fuze box (the round thing in metal with 3 pins) or just replace it .its like 5$
lollll I did the same thing with my first pull
but taking the tranny out is just a pain in the ......... if you wanna take it out by it self
sure you can do it seperatly but just more work
bye the way renting the crane cost me 25$ for the weekend so if you don't trust your hoist...........
the only site I found is the one for the north america and after trying to decode it ...........it make no sense .....
je crois pas que tu va trouver ca sur le site jai fait quelque recherche sur google et je n'ai rien trouver
verifie dans ton manuel du proprio ou cherche toi un livre de maintenance
moi jai verifier dans mon manuel HAYNES et je n'ai rien trouver
dsl sais tu si ton camion a été importer ou construit en europe ??
totaly fixable, uts just the front end get a chero and cut the front off you can cut the soptweld on the fire wall to take everything off
if the frame is twised a bit call a good welder and get it plated at the same time he fixes it ........
yeah stupid me I apparently threw away the hockey stick door handle so I had to put back the regular ones
I also f*cked up the speaker grill and that was the only option that was left for them.......
and when I went to put back the exterior door handles both studs broke off :fs2:
now I'll have to go to the junk yard sometime next week
now only minor details to finish it
I had a G-Waggy 88 and the first thing I did on it was to change the leafs on it!!! Damn they were curving down lolll
and I went and bought a set of BDS 4'' lift full pack leafs
I'm not sure about the load capacity on them but with my experience I wouldn't go with anything else if they would fit underneath the MJ
thats the waggy on 33'' and 4'' lift
I would be interested in details. Wouldn't a simple jumper wire allow the low beams to feed power to the high beams also, causing them both to be on all the time no matter what?
not realy if the switch is on the jumper wire
all done with the tranny and the clutch now
she holds pressure real nice and no leaking got to love it
now it time for and going to see the expendables
