Everything posted by wannabeMJ
your to far but I have 1 to sell 50$ just for you if you come get it bha I'll give it to you
87 2.5 engine wants to die when warmed up
wannabeMJ replied to wranglercory's topic in MJ Tech: Modification and Repairs
my bet on this is a plugged fuel pump(meaning you got sh*t in your tank) runs fine at idle but as soon as you step on the gaz all that junk wants to up the fuel line bloking the pick-up in the gaz tank..... -
what was wrong with the horn in the first place?? just a cut ground?
X2 on the trim??
Engine swap ideas please...
wannabeMJ replied to tjjeejeepcomanche's topic in MJ Tech: Modification and Repairs
Cherokee 2.1L TD 1987 land rover diesel but for more info (if you can read french) go INFO4X4.com it's the france forum about trucks I'm sure you can pick up bits and pieces from their sites and maybe even an engine good luck Dominic -
this might be a long shot but on my other forum from quebec there was a lot of talk with guys from france wich is not to far from you (read closer then america) but the guys over there were putting small diesel engine in their jeeps so I'm not sure but a 4 banger diesel could put more torque in your truck then the original 2,5L I can try looking it up and give you what models they used -
Any clutch replacement tips?
wannabeMJ replied to veritas4156's topic in MJ Tech: Modification and Repairs
the hanger is just a slide on you should be able to take it out!!! -
X2,3,4,5,6,7 this is what I would love to do but the GF keeps me on a real tight budget WOW its all I have to say ..........
yaaaaa....now my flares
wannabeMJ replied to STERLING STINGER's topic in MJ Tech: Modification and Repairs
Midget with a sponge. :D :cheers: can't seem to find that at the store :dunno: -
mj payload & towing capability?
wannabeMJ replied to zzze's topic in MJ Tech: Modification and Repairs
if My YJ is rated at 1400lbs could that mean i could pull my YJ on a flatbed with the MJ or would that be to much?? -
what's a fender washer -
bed side fender trimming
wannabeMJ replied to over2land's topic in MJ Tech: Modification and Repairs
never mind I found the answer staring at the fender flares for like 30 min then I went :fool: too myself and figured it out thx anyway Dominic -
86 2,8L long box comanche X
wannabeMJ replied to wannabeMJ's topic in Member Projects: Your Comanches
sorry the other comanche is already at the JY it left saturday morning it was the only way the wife let me have it (it had to go away fast so she can have her parking space) automan dunno it think its because its the street side so receives more $#!& being park on the street -
well I'm jacking that thread up because its the same topic I wanna cut my rear wheel fender so it's easyer to fix and I saw some pics of what you guys did some people went and cut 2'' up and some 3'' I wanna cut just over the lip wich will give a rough 2'' kinda like this but my main question is what did you guys do for the part of the flare that recces near the bottom of the bed same with the front like this : -
once again working on my truck I bought the rubber thing to remove pinstripe and holy rubbery thing batman it work wonders so I moved on to getting the rust out of the ''new to me'' bed and after a days work this is what's left to do and now 4 different colors on the truck -
plug for the prop valve outlet
wannabeMJ replied to wannabeMJ's topic in MJ Tech: Modification and Repairs
for those who will search this: 3/8'' fine threads 7/16'' long with a o-ring -
thx CW I just didn't have the right words for the search -
yeah coolant prestone is the brand of coolant :fool: my bad it's a french thing you woudn't understand :thumbsup: -
I have removed the prop valve on my MJ and I was wondering if anyone knows the exact size for the plug to put on the brake thingny where you take the line out ( sorry don't know the exact name for that part :dunno: ) thx Dominic
got the other manche yesterday :beerhead: it had a prestone leak but still made it to my place so I got to work and started taking everything away from underneath the bed then with the help from the girlfriend and the roommate we got the topper off then we switch box from my truck to this one then I went on to fix my cab corner fixing the rocker panel first then the actual corner hopefully it will look nice when I finish the body work also had a prestone leak from the waterpump gasket wich was installed 2 weeks ago :fs2: changed it again and still had a leak so I said f*ck it and put gasket maker instead and it worked nicely (so far) more to come soon as its a long weekend here and I will work some more sorry for the pics size -
not sure but it seems that the engine doesn't adjust to the new injectors so might wanna tchek the sensor for air/fuel mix
just found an other 86 long box in town for sale !!! should have bought this one for my project .........but its........ gold :yes: no its ok now the guy was in a front end crash and the grill and the fenders needed to be replaced but I got it for 100$ and the 2.8L works good :???: I think I just robbed the poor old man I offered him 100 and he said yes so next weekend Ill be the owner of an other MJ that will my 4th jeep in the yard but the next monday 2 of them are going to the JY I'm quickly gonna part the other MJ then send it on it's way if you want parts come to medicine hat july long weekend (but I keep the bed) the rest is up to grab -
will a cherokee fender fit the manche?
wannabeMJ replied to shipp08's topic in MJ Tech: Modification and Repairs
yeah they will fit but when I did mine I had to take the front part to as it does not attach to the fenders the same way studs instead of screws ......do a search on the forum and you should come up with some real good project post lots of people do that mod on this site
