I'm very suspicious of the MAP reading.
What did Tip 5 reveal?
Might check the ground at the MAP itself anyway,
Also, if the hose from MAP to throttle body doesn't "cascade" and has low spots, that can cause issues.
CRUISER'S MOSTLY RENIX TIPS
RENIX ICU/COIL CONTACT REFRESHING
OCTOBER 30, 2015 SALAD 29 COMMENTS
The contacts between the coil and the ICU on your Renix Jeep can become corroded and loose causing a complete or intermittent no-start condition. I recommend the following procedure as a maintenance precaution to insure this is eliminated as a possible cause now and in the future.
The coil is attached to the ICU by two T20 Torx bolts. Remove these two bolts and lift the coil up off the ICU. You will see 2 pins and 2 sets of contacts. Clean both the pins and springy contact pieces with a good electronics cleaner and some fine sandpaper.
Squeeze the springy contacts closer together with some needle nose pliers. Apply some OxGard to the contacts. Bolt the coil back on to the ICU.
While you’re right there, unplug the connectors from the ICU and inspect the pins in the harness connector. Make sure the pins are not retracted into the connector. Spray out the connector and the receptacle of the ICU with the same good electronics cleaner you used earlier.
I feel this procedure should be performed at least once in the lifetime of a Renix Jeep.
You know, there was an issue with the flexible clutch line between the master and slave cylinders.
The rubber line reacted badly to the fluid they used and shed off some gritty stuff. That stuff trashed the cylinders. It was always recommended that the line be replaced when a cylinder failed.
