Everz
    Long Beach, CA
1372 profile views
Everz's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. anybody remember if the upper oring is the same as the lower one, did my hoses, pump and steering box a while back and mustve done the same with the upper end of the pressure hose and pinched the oring over tightening.
  2. seen that whole kit on quadratec but not looking to replace everthing again. appreciate the help
  3. can't seem to find just the fitting anywhere or how to properly identify it, I know its -3an on one side… any help would be appreciated
  4. good to know ill have a look when I'm home, took the hog to work, thanks
  5. never gave them too much attention… they all seem like theyre there and tight
  6. ill check it out thanks
  7. have had this truck for about 4 years 88 jeep comache 4.0 with an ax-15, and it would happen occasionally when the truck got hot on the highway, you pull in the clutch and hit the brake and it dies…while rolling pop the clutch and starts back up or come to a stop and use the starter starts back up no problem. well lately its been happening alot more frequently and I have replaced several components or adjusted things over the years that I believed to be involved- coil, crank position sensor, idle speed, inspect the grounds. with no real luck so I'm wondering if anyone else has had a similar problem and any fixes in mind. maybe still too low a idle or fuel pressure regulator or pump on its way out?
  8. Initially I believed it was a throwout bearing cause ive had a slight rattle after having a transmission rebuild, took it to AAMCO and after ripping my differential apart they quote me $2632.07 for only doing ring and pinion and bearings and seals (no spider gears). I work on motorcycles for a living so I understand shops and parts price but the fact they “couldn’t find” 3.07/8 gears for weeks when I found them online in 15 minutes and when they did find them the cost was $813.21…. after telling him to go F himself I was able to arrange bringing my own parts in for cost of labor. And trust me I tried to take it somewhere else but they want $700 for diagnostic dis/and reassembly…
  9. thanks for the help. I appreciate it.
  10. thanks for the clarification appreciate the help.
  11. appreciate the help
  12. Just to make sure, the 3.07 is correct for the rear axle. I always thought the 3.07 was for the front axle with a 3.08 in the rear. I notice the spline count also says 26 when I believe its supposed to be 27.
  13. Maybe blown is the wrong word, differential was clicking loudly while in motion was able to drive it slowly to the nearest shop that I believed would do good work. Here I am 3 weeks later no truck and an estimate through the roof if they have to source the parts for the 3.08 ratio.
  14. Recently blew up my rear diff and shop says they “can't find the right pinion gears”. I can find dana 35 3.08 pinion gears online but fitment say it is incorrect for a 1988 jeep comanche with 4x4 and 5 speed manual. Is there really a difference between a cj and mj dana 35 rear axle? here's the website where I found what I believe is the right stuff but correct me if I'm wrong. https://revolutiongear.com/revolution-gear-ring-pinion-for-dana-35-3-08-5-13-ratio/
