omega_rugal
Everything posted by omega_rugal
  1. like, a lot... all conections have been checked, no loose wires, the only way to get it to crank as before is connecting the 2 batteries together... i had a similar problem years ago with a ford escort, starter failed overnight, turned out to be worn carbon brushes... i´ll drop the starter next saturday...
  2. so the last weekend i took the mj to do some chores, it worked fine as usual and was parked for the las 3 days. this afternoon i try to turn it on but the starter is too heavy, my first diagnostic was that the battery was discharged (i may have left something on) tried another know-to-be-good battery but nopé, same thing, it tries to hard to start then it catches up and runs, next step is drop the starter to see what´s wrong but, how does this happen? can the started run fine and then $#!& on you next day?
  3. you can take the hoses out and plug the thermostat outlet and screw a cap on the return tube...
  4. is it a dana 35? what if you have a amc 20
  5. you need to drill them and use an extractor...
  6. depends on your version of engine... update your signature
  7. nissan tsuru (sentra in the us) not exaclty, i had to wait for it to coo downl, otherwise you can touch it, so it wasn´t operating temp neither cold i´ll check clearences again, just to make sure...
  8. i know the 4.0 doesn´t require valve adjustments this is for another engine, i´m looking for advice from seasoned mechanics since i´m not one, i just take things apart and put them back togheter. i have a tsuru b13 with the e16s, it´s a single overhead camshaft, i had have it for like a year or so, and ever since i got it i has a weird ticking noise i always though it came from the valve train so i finally ventured to open it and see if i could fix it, after taking off the cover turns out pistons 2 and 3 had no gap in the valves so i adjusted them following a youtube tutorial (yes, i did it) weird because i expected them to have a large gap somewhere, after checking all the valves i put the cover back and fire it up, next i´ll try to explain the best i can: before: cranking speed was good, sometimes fired up quickly, sometimes it didn´t power was ok but had to give it some gas to not stall while cold, when hot worked fine after: cranking speed is slower, as if the engine was too heavy or the battery is discharged but once it begins turning works fine i feel a noticeable increase in low end power, no longer stalls at idle and overall it feels more torquey noise remains... now i suspect the timing belt or tensioner... i´m more than happy with the power improvement but i don´t like the starter like that, my theory is that by adjusting the clearence in pistons 2 and 3 fixed an unnoticed compression leak but in the same time the starter now has to work harder... or did i @#$%ed up? please move the topic if it shouldn´t be here...
  9. my words exactly, that way i know if it´s getting power...
  10. nothing, but apparently the pump is toooo noisy for some...
  11. you can get a few more miles out of a dying pump bypassing the resistor... but yes, bypassing the resistor should be the exception not the rule
  12. that´s what i don´t want to do haha but i had to ask...
  13. one simple question: does the throttle body of a tbi 2.5l physicly bolts to a renix 4.0 manifold? is for a school project
  14. so the truck actually rolls back in gear? wow that´s some major internal damage like clutches not grabbing but if happens after $#!&fs the somethign is stuck/plugged in the vavle body... try changing fluid and filter... but your aw4 seems to be on its last leg
  15. once you do, take the ba10/5 apart, bet theres at least one collar stuck in gear...
  16. that´s a stupid law considering anyone can tamper an odometer...
  17. bad luck man, the $$$ that it will cost to drop it, see what´s wrong and fix it does not worth a ba10 you have to options: find an ax15 in good shape that don´t cost an arm or a leg or get a cheap beat doen xj donor, take the aw4 and sell the rest, or keep it for parts...
  18. looks good,see if you can bargain a few dollars for the mandatory upgrades...
  19. my condolences...
  20. all have them, even the one´s that use individual coils, in this case only the CAM POSITION SENSOR aka SYNC SIGNAL with no distribuitor it says right here http://www.lunghd.com/Tech_Articles/Engine/Cam_Position_Sensor_and_Sync_Pulse_Stator.htm wait, what do you mean by "Boost"?
  21. what about the cam position sensor ? you know the one inside the distributor? if the ecu can´t get a proper sync signal to fire the inyectors it will use a random order, the engine will run but may or may not run right...
  22. closed system + leak = your problem... there should be no leaks...
  23. the ba10-5 looks like had provisions for a external slave... http://www.jeeptech.com/convtrans/ax15swap.html "Inside the bellhousing of the Peugeot, it looked like it had the ability to have the external slave unit bolted to it. There was a place on the right side for a ball stud for the pivot point of the release fork/bearing such as on the AX-15. However, the Peugeot would require holes to be drilled for the studs to hold the slave unit on the side as in the AX-15." go figure
  24. was so difficult to put an spacer so the coil doesn´t touch the engine, preferibly made of a non conductive material?
