3
Everything posted by zomeizter
Just picked these up for cheap, the Jeep set is 17" and the aftermarket ones are 16", these should fit the 'manche right?
If y'all care to download the Bosch Relay Guide that Jeep Driver mentions...
If the wiring problems are due to vermin, you can repair them yourself with minimal investment but it could take some time depending on the extent of damage. Keep in mind that just one necessary signal conductor can dead line your vehicle.
The difference is obvious Driver, I gather one is aftermarket?
I have a set exactly like those, takeoffs from a 99 XJ.
New IAT / Intake Air Temperature Sensor
zomeizter replied to coolwind57's topic in MJ Tech: Modification and Repairs
^^this^^ -
Where can I buy one of these?
zomeizter replied to KANTANKRUS's topic in MJ Tech: Modification and Repairs
OP, go to any Oreilly's or Autozone and find the "HELP" section, you will find an assortment of vacuum elbows and boots... -
Violent vibration
zomeizter replied to BeaterComanche86's topic in MJ Tech: Modification and Repairs
OP, my MJ has a similar symptom, right at 55-60 mph, there's some vibration coming from the driveshaft. I had it balanced once and they almost got it perfectly balanced but the problem came back after a few months. The driveshaft on my truck is the "rubber sandwich" type, and this rubber is old and coming off causing the imbalance/vibration. I will not get it re-balanced again since I will be installing a lift and the shaft may have to get re-tubed/lengthened. Maybe the problem with yours is at the driveshaft, check it out. -
I converted mine a few years ago by doing the following: New compressor, expansion valve, receiver/drier, replaced all o-rings to the 134a type (green/purple), completely flushed condenser, evaporator and all hoses. A quick google search can reveal you the specifications for oil (PAG) and refrigerant charge, IIRC you have to use 15% less 134a refrigerant than the R12 quantity specified. For the fittings, you can find the kit at any auto parts store, this will allow you to use the 134a hose connections for your gauges or A/C service machine. My conversion went very well, it gets ice cold even in the hot summer days here in the south. My 2.8L setup was equipped with a mechanical fan which was replaced with an electric fan setup which helps a bunch with A/C performance when stuck in traffic.
Help! Track bar tightening
Glad to see this, I got their best CA kit they offer, I have not installed it yet though, awaiting the last piece of the puzzle... -
Where’s the rain coming in??
zomeizter replied to Vineyard86manch's topic in MJ Tech: Modification and Repairs
Indeed, but them there plugs were a bit big and are not located on the lowest point... -
Awesome!
I fought all mentioned leak sources here and eventually gave up and "engineered" some drain holes on the floor pan...water leaks in, then it immediately drains out, no carpet installed... -
Will 3" lift in front and 2" in rear look right?
zomeizter replied to jrl3's topic in MJ Tech: Modification and Repairs
Hey Driver, are them there flares Bushwhacker? Ima be cutting into my wells soon and would like something like your setup... -
Mystery box on 87 mj 4.0 5 speed 2wd
zomeizter replied to tigwelditbro's topic in MJ Tech: Modification and Repairs
cruise control box? Mine has one like it... -
So you need info on oil... https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=cfrm ...you're welcome.
If it is not necessary to be pulled, homebrew yourself a spacer...
Agreed. At one point I considered a headlight upgrade consisting of the H4 conversion or LED with some added relays. After I began to gather the wiring and readying it for some hacking, I discovered a harness connector badly corroded as well as the connectors at the headlamps. I eliminated the harness connector by soldering all the wires and I cleaned up and tightened the headlamp connectors. Turned the lights on after the task was done and the lights were so bright I did not want/need LEDs anymore, bought some steaks and beer with the savings
Right on man, glad you got it resolved...
If you're certain it's in bypass mode and the pedal stomping is not resetting the valve, maybe it's time to remove the valve from the distribution block and check for damaged o-rings, maybe it's stuck with contamination. When I removed this valve in my 'manche, I could not believe the amount of crud on it, I guess it was due to it sitting unused for 10+ years...
1986 MJ 2.8L V6 failed emissions.
zomeizter replied to justinmartinez001's topic in MJ Tech: Modification and Repairs
Agreed, carb tune and operational cat air supply system will clean up emissions. Also, ensure the choke is operating properly, it may be contributing to the high CO reads... -
Time for new steering componants.
zomeizter replied to chopper35nj's topic in MJ Tech: Modification and Repairs
Right on, thanks. I will be running 31 inch mudders on steelies myself, nice setup you got there... -
What transmission do I have
zomeizter replied to 86 Comanche's topic in MJ Tech: Modification and Repairs
I don't think I could convince myself to do anything with the 2.8L, although the one in my 'manche came from a Camaro and supposedly it was "refreshed the right way", whatever that means, according to the guy that sold it to me. I did remove the valve covers and oil pan and to my surprise, it was pristine clean, like fresh out of the machine shop. So I threw in a HV/HP pump and installed it, replacing the original 2.8L with a rod knock. Once the installation was completed, the damn thing started on the first crank and has been taking hell since the summer of 2016. I will run it till it dies or I find a manual tranny for the GM or Dodge V8 swap. -
It sure does, but a tranny-mounted starter and flexplate side throttle body. I do like the clearance mods made to fit the FWD GM sedans though, but not sure I'd keep the ax5 behind the beast...on the lookout for a deal on a GM/Dodge NV35-5600. -
I reckon the picture is not clear. Just to make sure I order the correct upgrade items, my cart contains the following MOOG parts: DS1238 x1 (XJ) DS1312 x1 (ZJ) ES3096L x2 (ZJ) ES2079S x2 (ZJ) I will be installing these together with a 4-5" lift, is a Pitman arm or any other steering component required/recommended?
