mnkyboy
Moderators
Everything posted by mnkyboy
  1. the sleds are in the bed in the pics. yes we were on Mt hood a little outside Estacada. yes its a bone stock D30 for now,i wasnt suprised when it broke.
  2. Propane is best indoors,kerosene works well outside or in well ventilated areas plus they will run on diesel.
  3. here is some pics for comparison here is mine stock with 31X10.5 here it is with 5" lift and 31X10.5 and 5" lift with 33X12.5
  4. went up the mountain today to do some sleding. It was alot of fun till i got stuck and broke my front axle getting out,I snapped the right u-joint and had to limp it back to town where i had a friend meet me with a trailer.
  5. thats basically the same setup i have except i have a flowmaster,it sounds alot better then stock.:thumbsup:
  6. my 2.5L did the same thing when i got a tank of bad gas.
  7. Thats the easiest place to start. last one cost me $30 and took 20 min to install
  8. here's the finish on my bumper with the hammerite paint.
  9. a guy in my nieghborhood used something like that to do a two tone job on his F350. it looked good when he first did it but over the last few years it has faded and turned gray. on my tube bumper i went with a hammer finish spray paint,other then some chips from the D-rings bouncing around it seems to be pretty durable. It looks pretty good most people think its powdercoated.
  10. mine did something similiar. From the time i got the truck i noticed a small "pop" when i pushed the clutch,on my way to work one morning i went to push it at a light and it popped then locked up on me. I limped it to work and had a new master cyl sent to the shop,when i took the old one apart i noticed the spring had been broken and was causing the popping sound.the spring pieces got jammed in there causing the lock up.
  11. I had a few beers but no hangover :thumbsup:
  12. mnkyboy
    Happy New Year!
    I will drink to that :cheers:
  13. ok i replied within the first 30 seconds what else do i get :cheers:
  14. mine was also a stage 2 hooked to a mild built460 in a 83 F250 4X4,it had 4.10s and 35X12.50s that thing guzzled gas but it could pull about anything. I lost it to a tree last winter :( my brother has a 79 Bronco,built 460/C6. not sure how much lift but it will clear 38s. the thing is monster :cheers:
  15. mnkyboy
    I laughed:
    You made three mistakes. First, you took the job. Second, you came light. A four-man crew for me? @#$%in’ insulting. But the worst mistake you made– Empty gun rack.
  16. the old trannies do seem to handle the abuse . i had a 3spd or "three on the tree" in a 74 f250 that could not be killed. the autos were not bad either I had a C6 with heavy duty packs in a 83 F250 that was pretty bullet proof. you must be hard on transmissions and/or you were getting poor replacement trannies. they should live longer then that.
  17. you can get an Allison in the GM which is pretty tuff
  18. I doubt that Fords tranny was stock the engine sure wasnt,build them right and you can tractor pull with them. IMHO the ZF manuals behind the diesel arent any stronger then the auto,the old 5spd does seem to be a little better then the 6spds though
  19. my in laws had a 6.5L,they had nothing but trouble with it. just remember the 4.0L seems to be the prefered engine around here,anything 2.5L related and a 4.0L swap is usually the answer. so expect at least one person to suggest it when you say anything 2.5L related I too have a 2.5L and no desire to do a 4.0L swap :cheers:
  20. on my old mustang i gutted the cigarette lighter plug and put a button inside it.you click the lighter and it grounds the coil,click it again and it ungrounds it. my EXP has a switch on the ignition system and the fuel system,it has a bank of switches were the ashtray should go. if they arent flipped just right it doesnt start
  21. actually it does mean something,I'm a lift truck/equipment mechanic and hyster used the 305 V6 and maybe some of the others but they are pretty rare anymore. I'm not trying to make you like the 4.0L, i just wanted to clear some stuff up. I got real worried that my XJ was blowing oil into the airbox right after i got it and i had the same idea about it as you till i researched it and found out what causes it. figured its good info pass along,might come in handy some day.
  22. I have a security camera aiming at mine,next I'm getting an alarm before i put in another Stereo :fs1: freakin thieves
  23. Your right you didnt ask for any 4.0L info but since you were talking out your @$$ about the 4.0L and other people read this stuff and appreciate the info i decided to clear it up.
  24. use the little quote button and quote me saying anything about you doing an engine swap if YOU can read you will see i was pointing out how little you know about the 4.0L
