dasbulliwagen
    3
  1. A lot of modern AC compressors are built on that design, or something similar. I never thought or wondered if something like that would make a good gas engine, but looks pretty cool. makes me wonder too if it would be possible to control valve timing like most modern variable valve timing systems on conventional engines.
  2. If youre planning the 4x4 swap, I would keep the 4 .10 axles and find a good AX5. Might even be cheaper that way than having new gears set up. That way too you can use the fronbt axle from the donor as well as is.
  3. I think its good youre trying to find ideas like this, but a rotary is not a good idea. I'm a Mazda dealer tech, and most of the RX8's that come in have had 2 or 3 motors put in under warranty within 80000 miles. And like was said, power isn't made until the higher RPM's (5-10K). They are fun to drive though, but I wouldn't own one. We actually considered buying one before I was with Mazda.... glad I didn't! They are beautiful cars, but at the time the price put us off. Your best be is to go with whats proven. That way youll still get to drive the thing and not mess with finding or making custom parts that may or may not work for an engine that never been swapped into an MJ before. Good luck, and let us know what you end up doing!
  4. At 3 inches I personally would go with adjustable arms to get back proper caster. If I didn't do that I would go with a new set of stock arms for a WJ. My 2 cents.
  5. They had some kits like that for XJ's in Europe. They might be more common over there. Otherwise due to rarity I would think it would be easier to maybe make one like you want or find someone good with fiberglass to make one for you to spec. Maybe talk to boat repair people. I bet it wouldn't take much for one of them to build one. Good luck.
  6. Yes. Only differences are between the standard load models and Metric ton models. Standard has 4 leaves, MT has 5, and they are interchangable.
  7. I had a similar issue when I did my 4x4 front end install with new steering parts. They werent Moog, though. They were improperly machined froim the factory and wouldnt allow proper steering movement. I had to swap them out for another set to get it right.
  8. Thanks for the help guys. And onlyinajeep, Ill keep you in mind, but Ill probably just order new. I appreciate the offer. Youre only about 2 hours from me!
  9. Ive done the JK takeoffs. They are about an inch longer than stock and will require minor modding to make them fit. The JK Rubi and regular JK shocks are the same length so it shouldnt matter which ones you get. For mine with 2wd rear springs and longer shackles the rear JK shocks are a small bit too short, but work fine for normal driving and hauling and ride great.
  10. I didnt even think about that, I still have my donor truck that I got the trans and case from. New would be nice though. That way the donor would still have one for when or if I build it. I have it in my mind to build it for my daughter down the road. Time will tell.
  11. Working to finally get my 4x4 conversion linkage installed and remembered that I still need a speedo cable. The original 2wd one is too short to hook up, but when I go to rockauto or anywhere else, there is only one part listed. Just FYI, I have a 1987 2.5, AX5, NP207 combo. Does anyone happen to have a correct part number to narrow my search, or do I just order the only one listed and hope its right? Thanks for the help!
  12. I just got two sets of spidertrax from Quadratec at regular price, but with no tax and free shipping. I didnt want to skimp in this area. Its cheap insurance to just get the good ones. I did look at all the others though and even looked at the generic non hub centric ones from the wheel place here in town.... I just didnt like the way they looked. If they are that cheap looking, how cheaply are they made to begin with? The Spidertrax looked awesome, and made in the USA. can't go wrong.... I hope.
  13. It was originally sold to the militay in Switzerland. I PM'd your build sheet. Have fun! Make sure to add your build date to the 92 registry. 4-24-92! One of the last ones ever!
  14. If you post your VIN or PM it to me, Ill run you a build sheet, not that it will tell you much. The above posts are pretty much right on.
  15. I hope you can decipher that, they don't copy and paste like they used to.
  16. Standard Equipment Code Description Code Description Code Description APAS Monotone Paint BAUS 117 Amp Alternator BCDS 500 Amp Maintenance Free Battery BGAS Power Front Disc/Rear Drum Brakes CDBS Reclining Front Seats CFMS Rear Fold w/Removable Cushion Seat CGGS Traveling Inboard Seat Belt Buckle CGWS Next Generation Front Air Bags** CKAS Carpets - Floor and Cargo Area CKNS Cargo Compartment Carpet CKTS Cargo Tie Down Loops CKXS Plastic Liftgate Trim Panel CSRS Passenger Assist Handles CSSS Lift Gate Assist Handle CUFS Full Length Floor Console DGSS 4-Speed Automatic AW4 Transmission DHNS Command-Trac Part Time 4WD System DJHS Dana M30/181MM Front Axle DRAS Corporate 8.25 Rear Axle GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GNAS Rear View Day/Night Mirror HGDS Deluxe Insulation Group JCDS 100 MPH Primary Speedometer JHAS Var Intermittent Windshield Wipers JJAS Cigar Lighter JJBS Dual Note Electric Horns JJJS 12V Auxiliary Power Outlet KGPS DESCRIPTION NOT AVAILABLE KRPS DESCRIPTION NOT AVAILABLE KTPS DESCRIPTION NOT AVAILABLE K3CS DESCRIPTION NOT AVAILABLE LAJS Headlamps On Warning Chimes LBCS Glove Box Lamp LMAS Halogen Headlamps LPSS CHMSL Lamp MCAS Front Bumper Guards MHAS Black Windshield Moldings MMCS Rear Qtr Solid Window Insert MMGS Belt Moldings MMKS Body Color Drip Trough Molding MNAS Black Door Handles NBKS EVAP Control System NFAS 20 Gallon Fuel Tank QCJS Dark Blue Pearl Coat SBAS Power Steering SDAS Normal Duty Suspension SHAS Front Stabilizer Bar SHCS Rear Stabilizer Bar TBLS Inside Mounted Spare Tire XCYS Delete Remote Start System XJFS Tethered Fuel Filler Cap YAAS Build To U.S. Mkt. Specifications Z5BS Payload Rating - 1800# 1AAS U.S. Dealer Retail 155S Zone 55-Milwaukee 5ITS XK-Vehicle Family 5IWS JS-Vehicle Family 650S Wisconsin State Code 950S Wisconsin State Code Optional Equipment Code Description Code Description Code Description *XJ Cloth Low-back Bucket Seats -C3 DESCRIPTION NOT AVAILABLE ADAP Light Group AHT Trailer Tow Group ARXP Country Decor Group AWHP Power Equipment Group A20P DESCRIPTION NOT AVAILABLE CACP Low Back Bucket Seats CBVP Cloth Door Trim Panel w/Map Pocket CLEP Front Rear Floor Mats CSAP Spare Tire Cover DGB All 4-Speed Automatic Transmissions DHAP Lock-Up Torque Converter DHSP Floor Mount Automatic Shift Lever DMDP 3.55 Rear Axle Ratio EAAC All Engines ERH 4.0L I6 Power Tech Engine GAL Deep Tint Sunscreen Glass GEEP Deep Tint Sunscreen Liftgate Glass GFA Rear Window Defroster GNCP Sun Visors w/Illum Vanity Mirrors GTZP Power Mirrors, Fold-Away GVBC All Vehicles W/Power Mirrors GXMP Remote Keyless Entry HAAP Air Conditioning JAYP Instrument Cluster w/Tach JBGP Instrument Panel Woodgrain Bezel JHBP Rear Window Wiper/Washer JPAP Power Windows JPBP Power Locks JPS Power 6-Way Driver Seat KBSP DESCRIPTION NOT AVAILABLE KCPP DESCRIPTION NOT AVAILABLE KYPP DESCRIPTION NOT AVAILABLE K2CP DESCRIPTION NOT AVAILABLE LBBP Courtesy Lamps LCDP Map/Dome Reading Lamps LDAP Underhood Lamp LDBP Cargo Compartment Lamp LHDP Headlamp Off Time Delay LNJ Fog Lamps MBPP Body Color Front Bumper MBQP Body Color Rear Bumper w/Step Pads MDAP Front License Plate Bracket MFKP Body Color Grille MWGP Roof Rack NAA Federal Emissions NHBP Auxiliary Transmission Oil Cooler NHMP Speed Control NMCP Heavy Duty Engine Cooling PCJ Dark Blue RAAC All Radio Equipped Vehicles RAZ AM/FM Cassette Compact Disc Radio RCDP 4 Speakers RDDP Fixed Long Mast Antenna SCGP Leather Wrapped Steering Wheel SUAP Tilt Steering Column TBB Full Size Spare Tire TRVP P225/70R15 Eagle GA OWL AS Tires TZAP Goodyear Brand Tires WJ7P 15X7.0 Luxury Aluminum Wheels WKBP Matching Spare Wheel WLZC All Aluminum Wheels YGFA 8 Additional Gallons of Gas ZFJP Spring - Left Front ZFUP Spring - Left Rear ZUJP Spring - Right Front ZUUP Spring - Right Rear 2THA Customer Preferred Package 2TH 26H Customer Preferred Package 26H 3J3A No Charge Air Conditioning 3VUA Customer Preferred Discount 4X6A Wisconsin Act-13 Recovery
  17. You can't use the front doors on that one, but it looks like a good find. Good luck, keep us updated.
  18. My 2.5 has a gutted and sleeved cat, and a Flowmaster 50 Series muffler with stock 2 1/4" tailpipe. No rasp, mostly quiet at idle with a nice growl under load. I love it.
  19. The internal and external slave bell housing for the ax4 and ax5 are the same. I found this out recently when I did the same to mine. I'm not sure if its possible to find the conversion parts though without a full donor. You'll need the slave spacer and studs. The throwout arm and pivot. The slave plastic pivot that goes on the end of the slave pushrod. I might be missing a part but that will be close enough to get you started. Might just be easier to find a complete donor.
  20. Chrysler 300, Dodge Magnum, and Dodge Chargers have 17" stock steelies in a bullethole pattern, and 18" Cop car steelies in a 5 spoke design and then all the other aluminum rims and sizes. They are 5-4 1/2 with the correct hub centric size as well. These would be good candidates. Ive seen a few guys on Naxja running the 17" steelies with no issues.
  21. I'm working on some new pics and a build update, so Ill put something up here soon. Have to show off my new JK wheels!
  22. To them articulation doesnt matter as long as the axle is locked and ABS and traction control can keep the unlocked ones moving.
  23. You need to pull it apart to check everything, sounds like it could be a broken flexplate. Will the engine fire back up or does the starter just spin? If it won't crank over, but the starter spins, it could be a bad flexplate, that would be good for you as its an easy fix. Good luck, let us know what you find.
  24. There is another thread... called "Random Comanches found on the internet"
  25. YES, that was one of the most awesome things Ive ever seen them do. They got that thing to 1100 MPH! One of the best shows on TV right there.
