3
2.5 Common Problems
dasbulliwagen replied to Master7122's topic in MJ Tech: Modification and Repairs
The 2.5 and 4.0 are closely related and share several parts. Any issues that are common to a 4.0 base engine are common to the 2.5 as well. The 2.5 doesnt have the 2 piece rear main seal though so if thats an issue the trans will need to be pulled to change it. Otherwise it will run forever just like a 4.0. Just remember to keep power expectations low, and you won't be too disappointed. -
Spare Tire Mounting Options
dasbulliwagen replied to Dzimm's topic in MJ Tech: Modification and Repairs
http://comancheclub.com/topic/53556-xj-roof-rack-rails-on-an-mj/ Here a thread where theyre installing an XJ roof rack to mount a roof basket to hold a spare. -
Why is there a plate light BEHIND the bumper??
dasbulliwagen replied to JE39's topic in MJ Tech: Modification and Repairs
That's the same light and plate setup that was on my rear bumper delete when I bought it from the original owner. I have an XJ rear bumper there now with a custom plate mount and LED lighted bolts. -
Interco has 4 styles available in 33-10.50-15, only one of which MIGHT be considered an A/T by some, the SS-M16. But yeah, like was said, its not a popular size.
Non-CAD D30 question
dasbulliwagen replied to Jeep Driver's topic in MJ Tech: Modification and Repairs
Probably 3.73 if it was a 2.8L, maybe even 4.56 if it was a 4-cylinder. Its a 2.8 with A904 auto and the 228/229 transfer case. Ive read that the 3:73 was the most likely ratio for that combo but wasnt sure because of the auto. -
I saw the ad for that last week too, and wondered about getting it, though I don't need it. Glad you got a good score. -
I have an 86 Waggy parts vehicle with the NP228/229 and it is a non cad axle. I haven't confirmed the gear ratio yet on it but I mostly grabbed the thing for its axles. -
Theses Durangos are highly underrated. They are one of if not the best looking SUV of its type on the road. I wouldn't mind having one myself, but I think I might have the wife convinced into getting a new Grand Cherokee soon, so ive got that going for me.
best carburetor on the 87 2.5l
dasbulliwagen replied to ComancheCrusher9800's topic in MJ Tech: Modification and Repairs
My 87 used to stumble as well, until I changed the O2 sensor. been fine ever since. And, This is just my opinion, but Ive seen kids like you think that a carb is the solution to every fuel injection problem. That just isnt the case and often causes more problems than it solves, especially if you don't know what youre doing. You need to diag your TBI issue correctly and like was said, use quality parts. I understand youre 16 and can't afford much, butI still think youre going about this all wrong. My 2 cents. -
I swapped an 86 5 speed into my 87. The original slave has a plastic cone on the end of the shaft. I installed the new slave without the cone thinking the new version didnt need it. It would barely shift, like it wasnt pushing the clutch in far enough, which was the case because I didnt transfer the plastic cone that goes on the end of the slave to lengthen it about an inch and to push the arm in far enough and provide a non metal to metal contact between the slave and the clutch arm. Not sure if this is the case with you, but thought Id share on the chance that it is.
What axles would it have?
dasbulliwagen replied to 87MJTIM's topic in MJ Tech: Modification and Repairs
In some of the grands that had the full time transfer case option, they also had limited slip axles. Would this be the case for the Comanche as well, or was that not the case back then? -
There will be NO V8 offered in the JL. We will get an all new turbo 4 cylinder with near 300 HP, the Pentastar V6, also near 300 HP, and theres talk of a diesel as well. I don't see them putting in the 3.0 V6 thats in the Ram and WKII. My guess is another 4 cyl diesel, ala KJ.
I hope for the gladiator grille too to differentiate it from the Wrangler. Though with the huge popularity of the Wrangler they might not want to stray too far from a known winner.
Front end 87' sportruck
dasbulliwagen replied to Kyleinreallife's topic in MJ Tech: Modification and Repairs
I stole this from this thread http://comancheclub.com/topic/12163-acronyms/ This is a basic list without going in to all the sub-catagories of the CJ & FSJ's... CJ - 1941 - 1986 DJ - 1954 - 1982 ??years SJ - 1963 - 1986 ??years FJ - 1961 - 1965 MJ - 1986 - 1992 (Comanche) XJ - 1984 - 2001 (Cherokee) YJ - 1987 - 1995 (Wrangler) TJ - 1997 - 2006 (Wrangler) JK - 2007 - present (Wrangler) ZJ - 1993 - 1998 (Grand Cherokee) WJ - 1999 - 2004 (Grand Cherokee) WK - 2005 - present (Grand Cherokee) KJ - 2002 - 2007 (Liberty) KK - 2008 - present (Liberty) MK - 2007 - present (Compass / Patriot) XK - 2006 - present (Comander) -
There is a breakdown somewhere here about that with Model names and years. Ill look real quick, but someone else may be quicker to the draw and post it if they know where it is. -
For complete bolt in, youd want an original MJ rear 44, and then find a TJ Wrangler front 44 from a TJ Rubicon. Otherwise youll be doing some welding and fab to make other stuff work. Which isnt a big deal for some, but I don't know your situation. -
Went through a soft cloth car wash recently and it ripped off my driver side roof drip rail stainless trim. The spring steel clips that hold it on are rusted away and won't hold anymore. Does anyone know of a supplier for these or have a part number? Thanks
Anyone make a dump box?
dasbulliwagen replied to ruralandalone's topic in MJ Tech: Modification and Repairs
Craftsman was recently bought from Sears by Stanley. Just FYI. And there are several grades of Craftsman wratchets. The nicer ones are obviously more expensive.
I have a bunch of Jeep JK takeoff parts in a stuffed storage closet. I don't own a JK.
86 2.5L 4x4 transmission options?
dasbulliwagen replied to mdwatson's topic in MJ Tech: Modification and Repairs
There are shift kits available to update and upgrade the A904 that you have. It won't help with your highway rpms but nothing will other than overdrive or taller tires. Here is a link to tons of info on the trans and the mods for it. http://www.allpar.com/mopar/transmissions/torqueflite-tom-hand.html -
Need some wisdom for my rig
dasbulliwagen replied to SMPLTN's topic in MJ Tech: Modification and Repairs
JK shocks are not bolt on, but only take a little modification to make them work. like pressing out the metal sleeve on the rears, or installing a lower bar pin on the front in place of the metal sleeve. No big deal. Some say the red Rubicon ones are too stiff. I have the black ones on mine and like them. Ride is good considering its an old truck. -
Transmission Identification
dasbulliwagen replied to kazzx's topic in MJ Tech: Modification and Repairs
Just FYI... 1986 MJ auto was the 3 speed Chrysler A904 with an NP207 or NP228. Also, again, extremely rare. -
I agree with most of what has been said. Mine too is a 2.5 AX5 4:10 combo, but for a more modern look, Ive added a set of JK takeoff wheels and tires with hub centric adapters. They are right at 32" and at the outermost border of how big youd want to go without re gearing. With a 2" puck and shackles, youd be just about perfect. I have no real lift and have minor rubbing during some turns. A little lift like that would make it good. I agree with the WJ control arms as well. Theres a writeup somewhere on doing the uppers as well as the lowers. A little craigslist shopping could snag you some JK takeoff shocks as well. I have them front and rear of my truck. It only took minor mods to make them work, and I like the ride. Other mods can be done a little at a time, Like a ZJ steering box ( fewer turns lock to lock), or ZJ V8 front sway bar (thicker than stock) and ZJ tie rod (solid, instead of hollow). All bolt on mods and in budget if bought used. Good luck and keep us updated. -
Renix aftermarket header
dasbulliwagen replied to Knucklehead97's topic in MJ Tech: Modification and Repairs
I'm not sure the ports are different between Renix and HO on the 2.5. They sell an aftermarket replacement exhaust manifold that works with or without EGR. It comes with a block off for the egr tube if being used with HO. I don't think the 2.5 got the full re do that the 4.0 did when they switched over the injection system. I purchased an aFe header for my 2.5. It is not offered with the EGR port which is fine because I too am doing away with it. Ive yet to install the header but it is nice quality. Let us know what you end up doing.
