dasbulliwagen
    3
  1. Found a set of Firestone MT's in 255/75R17 on custom gloss black wheels all in like new condition pulled off a JK for $400. Havent paid for them yet but I'm leaning that way to go with the lift next year. I'm not thrilled with the tire brand or the wheels, but they arent bad. Ill post a pic as soon as i get to host the pic I took. I want to check the backspacing tommorow too compared to my stock JK takeoffs.
  2. Already bought or know Xmas gifts: RRO control arm drop brackets. 5.5" front springs, rear anti wrap rear spring perches, WJ booster and master conversion, a set of 255/75R17 Firestone MT's on black custom wheels (like new aftermarket JK takeoffs at a killer price). Will need during lift in the spring: Still shopping for shocks. Longer brake lines were already done, and already has an adjustable track bar (hope it adjusts enough). Also want to look at a helper spring for the rear leaves to help heavier loads.
  3. It still looks just like this. Hopefully will have some changes in the spring!
  4. Another thing you can do if you can't get the rod or the bracket is gone from the diff is use a piece of wire or a zip tie to hang the swinging arm in the 2-3 oclock position from above. This will give you some use of your rear brakes back without going through the trouble of finding the parts you need to fix it properly.
  5. Did I read on here somewhere that someone used a 4.0 timing gear in their 2.5? I'm trying to verify it but have been unable to find anything. The 4.0 timing sets seem to be cheaper than ones listed for the 2.5. There seems to be a lot of that around. Maybe because nobody is stupid enough to build a 2.5 Like me? Thanks for the help. I tried search but came up empty.
  6. These JK takeoffs are 17" just FYI. They rub a little while turning but not enough to bother me. The rears also rub when loaded down with 2000 lbs worth of scrap metal, but that doesnt happen that often. I hope to do the full lift in the spring. I put some 5.5" springs and some weld on rear perches on my list for santa, so hopefully he will come through. I already have a ProComp adjustable track bar on it and I'm hoping it is big enough to go with 6" of lift. I have it screwed all the way in right now as it is with little to no lift. If i need to get a longer one, Ill deal with it when the time comes.
  7. Just sat here and read all 10 pages. Love that you were making progress so quickly, only to have so much trouble. I feel for ya. Love the nice clean build though. You do good work. don't let this thing beat you. Maybe walk away from it for a while but don't give up. Good luck.
  8. I'm still only running one WJ control arm, and have been with no issues. I may try to install the others after the first of the year. Just ordered an RRO MJ control arm drop bracket set to prepare for lift. I hope I don't have issues with RRO like Ive read about. I did a little searching but didnt find a ton of complaints about them so hopefully Ill be ok. I'm also in the process of installing the WJ booster and master Ive had laying around for two years. I just need to finish flaring the lines into the MJ block and bleed the system. Hoping I don't have issues with the rear prop valve. If I do I may be eliminating it as well. The 1986 stock Wagoneer radio is starting to give me troubles, so I'm looking into either having it repaired or replacing it with something new. I really like the original unit, and have issues with confusing tiny buttons on the new stuff, so I may just have it fixed. I traded the motorcycle in my sig for a 1960 F100 4x4. The bike had been sitting for 7 years at that point and its value was about the same as the truck. Ive yet to start working on it, but it needs just about EVERYTHING so time will tell. I thought it best to save it from the kid who had it before it got really messed up. Again I'm horrible at updating and I'm not on here as much as I used to be be, but I'm not going anywhere. Love this place. Keep up the good work.
  9. Good to know. I'm not sure Exactly which ones are on my truck, but they were new takeoff probably 8-9 years ago, most likey a sport, but who knows.
  10. I'm a big Tire-rack fan, mostly because of their ratings and customer review sections. That and all they have can be arranged by price or ratings. Their prices are comparable to Discount as well even with shipping. Bought the current set of tires for my wifes car based on that. Ive also bought from them in the past but not for my Jeep. I was going to but then the new JK takeoffs fell in my lap, so now I'm stuck with Goodyear Wrangler SRA's until they dry rot enough to the point they are unsafe (because Ill never put enough miles on them to wear them out before then)
  11. I put the black JK takeoffs on mine and have been happy. Theyve been on there several years with no issues. I'm suprised to hear that the red ones are the same as the black ones just painted a different color. Is there any proof of this anywhere. I assumed they would be at least valved a little differently. I have a set in storage but didnt get them until after the black ones were done and on. I'm preparing for a lift so may change to Bilsteins or OME's at that time, but I like the JKs.
  12. aFe also sells a header but is for non egr use. If you arent in an inspection state this will bolt right up, youll just need to delete the EGR.
  13. Not sure its been done or not. It might not fit width wise either. You would probably have to run the entire donor vehicle wiring harness to make it work. Not sure if there is anything stand alone available for that or not. Would be an expensive swap no matter what you do though depending upon the cost of a rwd donor Grand Chreokee, Durango, Ram or if youre staying 2wd, Charger, 300, or Challenger.
  14. I know the manual trans trucks are more fun but the auto that came behind the 4.0 is a really good one the AW4.
  15. I have the standard JK wheels on mine right at 32" and get rubbing during certain turns but it isnt enough to damage the tires. I'm at about 1 1/2" over stock 2wd ride height. I'm not sure I'd have the same experience with the MT's you have though.
  16. A new oxygen sensor fixed mine when it was doing that.
  17. In mopars the A904 was used mostly with the slant 6 but also with some of the small block v8 cars. It can handle a 3.4 no problem. There are valve body upgrade kits available for them too that take care of any issues these trans had. I plan a similar setup for when my daughter begins to drive. Good luck.
  18. Been having running issues with the MJ lately... 2.5 TBI... I'm planning on going through cruisers renix tips, but I'm also thinking of going through tune up parts/ fuel pump/injector items anyways. I know that most places don't have correct fuel pump listings for our trucks so I'm wondering if anyone has a correct part number for my setup? I know the TBI has a lower pressure than the the renix 4.0, so I just want to make sure before I buy something. Search didnt come up with much. Thanks for the help.
  19. The 86 and earliers had external slave as well for both the 2.8 and 2.5. But when I changed mine over I found both bellhousings the same (internal and external) but the internal one didnt have the ball stud or the slave studs and spacer, otherwise they were identical.
  20. The Chrysler Dodge LX platform (300, Charger , Magnum, Challenger) wheels may have a little contoversy, but they are usable and Ive seen guys on Naxja using them. They also have the same hub diameter (at least the steel 17" one I tried before did). The police versions are equipped with an 18" steelie that I really like, but I ended up going with a set of 17" JK takeoffs, with Spidertrax adapters. That's another option for you, but sounds like you are looking for a budget priced set of bolt ons you don't have to worry about adapters with. Good luck.
  21. They are just a hot running engine. That leaves no buffer for overheating issues that might come up that and they are very sensitive to a lack or maintenance which is where the sludging up issues come from combined with hot running. Its just a poor design with poor longevity.
  22. I'm a Chrysler dealer tech, and there is NO way I would EVER put a 2.7 in a beloved vehicle of mine, even if it were free. It is a worse engine than the 2.8 V6 that came in the 86 Comanches. That engine should never have been put into the 300 or the Charger as it is too small for the platform. They suffer from running hot, sludging up, and letting the water pump leak into the crankcase. That being said, there is much demand for used 2.7's for people that want to fix their cars that were equipped with them (because they don't last very long). I'm betting you could get $1000 for the engine by itself to someone who needs one. Sell it, and buy yourself a complete 4.0 XJ donor vehicle and swap it all over. Youll be much happier in the long run.
  23. Some models do come with the at first troublesome 9 speed auto. They are supposed to have fixed the issues with them by the point of the renegade release so they might be ok. I am though starting to see issues with the 2.4 multiair engines wirh oiling issues... either low oil pressure or oil consumption. These engines are totally dependent on oil pressure for intake valve actuation. If oil gets too low it can lose prime and thus compression and quit running. This happens at just over 2 quarts left in the crankcase or at around 4 psi or less of oil pressure. Oh and the renegade is made in Italy if you didn't know. Let us know what you end up doing.
  24. This will be a slow project... just like my Comanche. The 57-60 models are considered a forgotten stage of the F series trucks and are nicknamed the Fridge due to the refrigerator door looking hoods. Surprisingly the axles are about the same width as an MJ XJ. I have a good pair of axles with a non disco front sitting under one of my parts trucks. I'm considering using them (temporarily) under this if the original axles are bad. I may convert it to Saginaw style steering too as the original style is weird. And obviously all the brakes need gone through too and trans and t case. A lot of work. Thats not to mention the rotted floors and fenders. Ill keep ya posted.
