Pete M
Administrators
    114
Everything posted by Pete M
  1. you... blacked out 2 locations you plastered onto your trailer?
  2. moving to Tech for a while so more eyes will see your question.
  3. depending on the part, that's absolutely true. that column was used in all sorts of 80s GM products.
  4. column shift MJs aren't impossible to find, but the floor shift XJs are super easy to find. I was really geeked when I discovered that the 2 cables had the same ends, then my spirit was crushed after wasting a lot of time trying to track down a non-existent wiring flaw when it was a mechanical issue all along. oh well. I've got a replacement now from Kody and learning occurred, so all is well.
  5. YJ, TJ, KJ, XJ, MJ, ZJ for sure have the same bolt pattern and backspacing (with a couple minor deviations). most are 15" rims.
  6. take some good pics of the insides so we can document the innards.
  7. Gorgeous work as always!
  8. any luck finding it?
  9. I'll be back from MI in 3 weeks and will likely pull the bed if it's still there. might as well, right?
  10. the cowl opening is a real bear to reproduce. the old one is crazy flexy and the new foam has to be practically the exact right height to fit in there. and it was still a real pain in the butt.
  11. possibly my new favorite genre of vids.
  12. there are a lot of vids out there on this topic. here's one. enjoy.
  13. Pete M
    New MJ video
    the whole west coast is just one long postcard picture.
  14. light vs dark has nothing on the sister vs brother rivalry.
  15. located an Eliminator decal for the wall.
  16. figured out that the issue isn't electrical, it's mechanical. turns out you can't swap a floor shifter cable with the column cable, even though the ends look identical. but I'm ecstatic either way.
  17. looks like I need one.
  18. sure enough, I disconnected the cable, got one more click out of the lever on the trans, and now she cranks. guess I gotta find a column shift cable.
  19. I love a stock rig! especially a gorgeous, well kept example! also I'm trying a new thing and dropping this into Tech for a bit so more eyes see the MJs of the Month.
  20. that's pretty dang cool!
  21. I would try searching that part number on ebay
